carrier bearing
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kubota man, Sep 12, 2010.
  1. Sep 12, 2010 at 8:04 AM
    kubota man
    kubota man [OP] Well-Known Member
    hazard ky
    08 trd off road dc 4x4
    how much movement is normal for the drive shaft in the carrier bearing. iwas greasing my ujoints and grsded the shaft to check it and the best i can tell its between 1 eight to 1 quarter of a inch. this may be normal
  2. Sep 12, 2010 at 9:35 AM
    clintonjeffries
    clintonjeffries Well-Known Member
    Clinton
    Wenatchee, WA
    07 4x4 SR5 super white
    6" stage 1 Procomp lift, 18" matte black XD Monsters, 33" Nitto Trail Grapplers, AMP Research Electric Steps, Grillcraft upper and lower grill, Paint matched tailgate handle, Black headlights w/ black corners & reflectors, 6k HID in heads and fogs, tint, RED badges, red brake calipers, black brake drums, flowmaster exhaust, black shorty antenna, remote start, iPod interface, Weathertech floormats front and rear
    movement in the carrier bearing??? like if you grab your rear driveline and push on it, it wiggles within the carrier bearing?
    I don't think any amount of play is normal...
  3. Sep 12, 2010 at 11:15 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Flexing of the rubber inside the mount is normal. Replace it if the rubber is rotted or mushy, or the bearing is noisy.
    The mount absorbs driveline vibrations instead of transmitting them through the frame.
  4. Sep 12, 2010 at 11:21 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    X2
    To the Op, since you have an 08.....I wouldn't worry about it. If you're still under warrantee, take it to the dealer and voice your concerns. They'll probably tell you its normal (and it is) but atleast you'll have it documented in case something happens and it gets worse.
  5. Sep 12, 2010 at 11:47 AM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    this
  6. Sep 12, 2010 at 12:15 PM
    gjbonner
    gjbonner Well-Known Member
    Guy
    Northern Idaho
    07 Tacoma Off Road TRD
    Rhino Lined exterior,Fab Tech 6", 1.25" SpiderTrax spacers, Wheels painted Rustoleum Hammered Black, All Pro front plate bumper, Warn 9.5 ti winch, BHLM, Cig lighter constant on, Door beep toggle switch, Locker mod, Lock/unlock beeper Mod, Rear tailights smoked, 750w inverter with the outlets and on/off switch wired to rear of the console, Blacked out badges, blacked out rear bumper.
    yes play there is normal. you have no concerns. its rubber man!
  7. Sep 12, 2010 at 12:44 PM
    supralight
    supralight Well-Known Member
    Dan
    Earth
    2013 4Runner limited
    I can feel the play of the carrier bearing in my 2011 when starting from a full stop and accelerating normaly. It's a slight vibration that does not last more than 1/2 to 1 second. And i've read it's "normal".
  8. Sep 12, 2010 at 2:16 PM
    kubota man
    hazard ky
    thanks guy just worred about it
  9. Sep 13, 2010 at 8:18 PM
    gjbonner
    Guy
    Northern Idaho
    Have you added the spacers to your carrier bearing yet? I did and you could really tell a difference. taking off and while shifting is much smoother with less vibration. something you should look into. Some use a shim i used 3 washers on each side. came out to be the same measurement.
