Carrying an Inflatable Boat on the Roof
Discussion in '2nd Gen. Tacomas (2005-2015)' started by nameaneh, Feb 22, 2018.
  1. Feb 22, 2018 at 10:36 AM
    nameaneh
    nameaneh [OP] Active Member
    Eddie
    2014 White Tacoma TRD Off Road
    Looking for some advice here. I have an inflatable raft (Hydro-Force Mirovia Pro from Costco). It's about 130" long. I'm trying to find a way to transport it fully inflated. I have a tonneau cover that got scratched up pretty bad when I tried putting the boat on top of it last time so I'd like to avoid trying that again. I was thinking of getting a Warrior Platform Roof Rack (I have a DCSB) and throwing it on top of the cab (strapped down of course). Not sure if that would leave far too much of the boat hanging off. I'm estimating it would leave about 35" of the boat hanging off the front and 35" off the back of the cab. You guys think this is a good idea? I'd never drive it too far (15 or so miles max). I really don't want to deflate and inflate every time as it takes forever. Any other suggestions as to what you'd do? Thanks
  2. Feb 22, 2018 at 10:54 AM
    Pigpen
    Dan
    Northwest Montana
    Drove this 2 and a half hours at 70 mph after taking it off the Missouri River.
    Yakima rack on the cab and a 2x4 across the topper. Hillbilly AF
  3. Feb 22, 2018 at 10:55 AM
    nameaneh
    Eddie
    Haha love it!
  4. Feb 22, 2018 at 11:07 AM
    black coffee
    black coffee A is A.
    Glenn
    509
    2010 AC 4x4 SR5 V6
    What kind of pump do you use for inflation? My inflatable kayak only takes a few minutes. It might be better to get a more robust pump instead of a rack.
    Just my 2¢.
    DoorDing, KB Voodoo and stickyTaco like this.
  5. Feb 22, 2018 at 11:23 AM
    nameaneh
    Eddie
    I use the one that came with the boat. It's a good sized pump, but there's A LOT to fill up. I've checked in to trying to find a good electric pump, but the only ones that'll work well are fairly pricey. Thanks for your input!
    KB Voodoo likes this.
  6. Feb 22, 2018 at 11:25 AM
    nameaneh
    Eddie
  7. Feb 22, 2018 at 11:33 AM
    Muddinfun
    Muddinfun Well-Known Member
    If you're going to buy a compressor, buy one that will air up tires also. That one you posted has a max pressure of 8.5 lbs.
  8. Feb 22, 2018 at 11:42 AM
    nameaneh
    Eddie
    Unfortunately you cannot use a high flow air compressor for an inflatable so I'd have to get one like I posted that's low pressure. High flow puts too much pressure on the seams
  9. Feb 22, 2018 at 11:44 AM
    Muddinfun
    Really? You can't just stop airing it up when if feels about right? You can't air it up at the gas station?
    tcjacado likes this.
  10. Feb 22, 2018 at 11:48 AM
    truchador
    truchador Well-Known Member
    Otto
    WV
    15 DC OR
    weathertech, seat covers, scratches
    Also don’t forget if u leave ur boat on top of ur truck on a hot day u might come out to u a big pile of shredded vinyl lol
  11. Feb 22, 2018 at 11:50 AM
    black coffee
    Glenn
    509
    2010 AC 4x4 SR5 V6
    A tire pump needs high pressure. A boat pump needs high volume.
    DoorDing, truchador and ChadsPride like this.
  12. Feb 22, 2018 at 11:55 AM
    Muddinfun
    Hmmm. I guess you're right. I don't know anything about rafts. I just thought if you're gonna have a compressor, have one that will serve double duty.
    "The raft can be inflated by using a foot pump, hand pump, or any other low-pressure pump. HIGHPRESSURE DEVICES SUCH AS A SERVICE STATION COMPRESSOR SHOULD NOT BE USED!"
  13. Feb 22, 2018 at 12:27 PM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    black coffee likes this.
  14. Feb 22, 2018 at 12:30 PM
    spitdog
  15. Feb 22, 2018 at 1:46 PM
    truchador
    Otto
    WV
    15 DC OR
    he’s trying to inflate a big balloon to like 3-4 psi not a little balloon to 32
    Viair or any other tire pump is a no go for inflatable boats lol
    OP it’s ok to let your boat hang off the front and back of your truck just make sure it’s inflated enough to be rigid at road speeds lol
    get a cheap 12v air mattress inflator at Walmart to blow the boat up and a decent hand/foot pump to top it off.
  16. Feb 22, 2018 at 1:55 PM
    black coffee
    Glenn
    509
    2010 AC 4x4 SR5 V6
    Yeah, low pressure high volume for boat and high pressure low volume for tires.
    I don't have a PSI gauge for my kayak, but I guess it is around 5 PSI when fully inflated. It is just a single seat kayak, so I can use a double action hand pump that fills each section with 20-25 strokes. A raft will be larger and more pumping.
    I have a small 12v compressor for tires in my truck. It would take forever to fill the kayak with that.
    This is under inflated and needs 2-3 more PSI.
  17. Feb 22, 2018 at 2:19 PM
    L J
    L J Well-Known Member
    Illinois
    07 4X4 SR5 TRD Sport DCLB
    The google says this works for inflating boats etc. Under $20. Made by Sevylor.
    You could inflate it part way and still put it under the bed cover then pull it out near the water and top it off.
  18. Feb 22, 2018 at 2:55 PM
    Tacosail
    Tacosail Well-Known Member
    Jerry
    Hermanville Heights, Ohio
    '13 white ACLB
    '17 wheels,int. Wipers , bed mat , relocate trailer plug , husky floor liners , Lund nerf bars, wet Okole seat covers- heat & lumbar.
    This is the way to go. I have one and it fills up a queen size air bed in less than 3 minutes . I have the battery one, too, but haven't used it since I got the 12 volt pump. It comes with adapters for small inflatables. You can also hook it up backwards to deflate quickly and completely.
  19. Feb 22, 2018 at 2:59 PM
    nameaneh
    Eddie
    Good tips everyone thank you
    DoorDing likes this.
  20. Feb 22, 2018 at 3:03 PM
    Drainbung
    Drainbung Somedays you are the show....
    Bob
    Fallabama, NV
    10 DCLB
    TRD Fleshlight
