Cars you never knew existed! Anti Car Porn
Discussion in 'General Automotive' started by Red03Taco, Jun 13, 2017.
  1. Mar 27, 2021 at 2:07 AM
    #741
    Sand Dog
    Sand Dog Well-Known Member
    2018 SR, 4x4 DCSB MGM
  2. Mar 27, 2021 at 2:46 AM
    #742
    MDFM31
    MDFM31 Well-Known Member
    Chester Co, PA
    16 DCSBOR
    62 Tempest? I love Pontiacs. Had a 68 firebird but I like the earlier cars now. Keeping my eye out for a 63 389 Tempest.
    FastEddy59 likes this.
  3. Mar 27, 2021 at 8:06 AM
    #743
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
    My neighbor bought one of those for their 16 yo son. It was a fast car as I recall. I found an Olds variant with the 215 aluminum v8 engine.
    The one that got away. I should have kept it. 3-speed manual transmission. No A/C. It was a screamer.
  4. Mar 27, 2021 at 9:58 AM
    #744
    Sand Dog
    cosmicfires and CS_AR like this.
  5. Mar 27, 2021 at 10:17 AM
    #745
    CS_AR
    Was that originally a Checker Marathon or aan International Travelall?
  6. Mar 27, 2021 at 2:42 PM
    #746
    Sand Dog
    I don’t think it was either. I think it was made as protection for a Middle East high value target; but not really sure.
  7. Mar 27, 2021 at 2:57 PM
    #747
    Sand Dog
  8. Mar 27, 2021 at 3:09 PM
    #748
    SOSHeloPilot
    SOSHeloPilot My 1st Muscle Car
    S.E USA & S.E. Asia too
    2024 4Runner SR5
    Missing My Last Tacoma --- Had 11 Toyota trucks in the past and many other Toyota cars too.
    ...^^^... I was not aware that the 63 Tempest could be had with a 389 as OEM.
    I knew that the 4 cylinder 1963 Tempest engine was 1/2 of a 389.
    IIRC .. I thought that 1964 Tempest with a 389 engine was called the "GTO option" ... and the 1965 was a true "GTO Model" with a 389 (had one of those new).
    Doing this from memory and I may be wrong.
    MDFM31[QUOTED] likes this.
  9. Mar 27, 2021 at 6:51 PM
    #749
    BKill
    BKill AKA Threadkiller
    Bill
    College Station, TX
    2013 Tacoma PreRunner
    I’m pretty sure that the ‘63 Tempest’s biggest production engine was a 326. Remember, the 61-63 models came with an independent rear suspension that was designed for 195 c.i. four cylinder, which as you pointed out was half of a 389. You wouldn’t think it would stand up to the torque of a 389, but that’s exactly what they used when they built the 1963 421 Super Duty Tempest. Pontiac built about 12 or 14, pretty evenly divided between the two door coupe and the wagon. More probably would have been built, but GM pulled the plug on all auto racing in January of 1963.
  10. Mar 27, 2021 at 7:05 PM
    #750
    MDFM31
    Chester Co, PA
    16 DCSBOR
    You could be right. I have come across a few 389 "Le mans" which I think was a trim level on the tempest in 63? Like this one-https://youtu.be/DgIpiIoSrO4
    They said it was a 389, I guess we have no way of verifying from the video that it wasn't a 326. But damn I love this car.
    SOSHeloPilot[QUOTED] and nDub like this.
  11. Mar 27, 2021 at 8:14 PM
    #751
    BKill
    Bill
    College Station, TX
    The 326 and 389 are based on the same block. For that matter so is the 421, 428, and 455, so just about everything is interchangeable. I think any of them would bolt right in. I bought a wrecked ‘65 Tempest with a locked up 326. It had gotten water into a couple of cylinders which resulted in deeply rusted cylinder bores. To rebuild it would require boring the block and going with new pistons. I had access to a 389 from a ‘64 Catalina which also needed to be bored out, so or course I went with the 389. Funny thing is, new pistons for the 389 cost less than oversized 326 pistons.
    I mentioned transmissions not standing up to the 389, and that’s exactly what happened to my Tempest. It had a 2 speed automatic, and I could not keep a transmission in it. Went through 3 of them before I finally gave up, sold the engine, and junked the car. Should have converted it to a standard.
  12. Mar 28, 2021 at 6:18 AM
    #752
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    What the heck is that. Looks like a child’s rendering of a jeep.
    TacoHank1998 likes this.
  13. Mar 28, 2021 at 6:36 AM
    #753
    MDFM31
    Chester Co, PA
    16 DCSBOR
    You are right except the main journal size increased above the 400, so you cannot swap cranks without turning the mains on the crank from the bigger engine. You also could not use heads from larger engines on the 326 and 350 bc the combustion chamber was larger than the bore. Externally they all had the same dimensions-cylinder spacing more like a SBC and V more like a BBC. They also had the 7" BOP bellhousing pattern, so a chevy trans with the 9" pattern would not bolt up directly unless it was a dual pattern model.
    I had a 68 firebird that I got a 428 for out of a Catalina. One of the cylinders came back cracked beyond repair and I wound up with a 4 bolt 400. I was able to use the #62 heads from the 428 though. They were a pretty good spec from the factory. My car had a 2bbl 350 from the factory. When I started looking into building that up, I found the same thing you did- the parts were more expensive, and much rarer, than they were for the 389+ engines. Man I love Pontiac engines though, and that 135* turn in the exhaust runner.
    SOSHeloPilot likes this.
  14. Mar 28, 2021 at 8:10 AM
    #754
    Sand Dog
    I believe it is a Crosley Farm-o-Road.
    Not to be confused with the much sexier Crofton Bug...
    strider98, nDub and TacoHank1998 like this.
  15. Mar 28, 2021 at 8:29 AM
    #755
    BKill
    Bill
    College Station, TX
    I was not aware that the main journal size had increased. I’ve never worked on anything but the 389, so my experience is rather limited.
  16. Mar 28, 2021 at 9:00 AM
    #756
    MDFM31
    Chester Co, PA
    16 DCSBOR
    Yeah 3" on 326-400 and 3.25" on 421+. People do turn the bigger cranks down to fit into their 3" blocks tho.
  17. Mar 28, 2021 at 1:59 PM
    #757
    SOSHeloPilot
    2024 4Runner SR5
    ...^^^... Very cool Tempest and I learned something new ...
    As a matter of fact ... I learned more about '60's HiPo Pontiacs on this Toyota Tacoma site o_O ... than I did in real life ... :)
    FWIW ... that car is on the other side of town from me ... maybe 50 or 60 miles to visit that car and/or company showroom.
  18. Mar 28, 2021 at 5:54 PM
    #758
    MDFM31
    Chester Co, PA
    16 DCSBOR
    Man I am so jealous. That car sold a while ago but it really pulled my heartstrings. I love BOP cars and engines, though I don't know very much at all about the B's and O's. Pontiacs were always great on the exhaust side of the head, and deficient on the intake side...the opposite of Chevy's. You can tell a Pontiac block from a chevy very quickly by the angle that the header flange meets the exhaust ports.
    SOSHeloPilot[QUOTED] likes this.
  19. Oct 23, 2023 at 5:07 PM
    #759
    Championsumo
    Championsumo Well-Known Member
    Tulsa, OK
    2015 DCSB 4X4 TRD Sport
  20. Oct 29, 2023 at 7:24 PM
    #760
    TacoHank1998
    TacoHank1998 Well-Known Member
    Will
    Panama City, FL
    1998 Green Tacoma Base
    Welcome back thread.
    I always enjoyed it. Let's keep it alive this time.
    HomerTaco and strider98 like this.
