Caster Pro Comp 6 inch
Discussion in 'Suspension' started by scottj, Aug 20, 2010.
  1. Aug 20, 2010 at 12:20 PM
    scottj [OP] Well-Known Member
    Jul 21, 2010
    York, PA
    12 DCSB TRD sport OME
    So I took my truck to get realigned after reading some alignment threads. They could only get the caster up to around 2. Is this common? Truck has Pro Comp 6 inch basic. The steering seems to bounce all around with every bump so I thought getting the caster up might help. I also dropped the Nitto Trail Grapplers down to 32psi. The guy at the local 4WD shop says the Tacoma is sensitive to M/T's and there will be steering wheel shake no matter what. Any ideas?
