Castrol Hypoy C 80w-90?
Discussion in 'Technical Chat' started by Mossy, Apr 6, 2013.
  1. Apr 6, 2013 at 1:30 PM
    Mossy
    Mossy [OP] Mechanic for Honda
    billy
    san antonio, TX
    ProComp lift Borla exhaust Borla air filter Nfab bars
    Anybody using it? I have a 97 sr5. Any opinions or suggestions of something better?
  2. Apr 7, 2013 at 4:45 PM
    Mossy
    billy
    san antonio, TX
    Anyone?
  3. Apr 15, 2013 at 2:23 PM
    Mossy
    billy
    san antonio, TX
    Bump
  4. Apr 16, 2013 at 6:35 PM
    azreb
    azreb Geezer
    AZ mountains
    '20 SR5 crew cab. gray
    camper shell
    From what I have read on the web it sounds like an acceptable lube for differentials. The advertisements say it is intended for manual transmissions, also. However, it is a GL-5 lube. From previous research, I decided against using GL-5 gear oil in my manual transmissions. The sources I saw (sorry--no links. I did this research a year or so ago) said that the additives that make the GL-5 work well in differentials contain chemicals that are corrosive to copper and brass. The syncros in manual transmissions are brass.
    YMMV. I have seen other brands of GL-5 gear lube with manual transmissions mentioned in the application notes, but I choose to not take any chances. I found a synthetic GL-4 lube that has worked well for me.
  5. Apr 16, 2013 at 6:38 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    FYI Toyota owner's manual specifies GL5 for manual transmissions for all years Tacos.
    Can you even find GL4 easily in auto parts stores?
  6. Apr 17, 2013 at 12:37 PM
    azreb
    azreb Geezer
    AZ mountains
    camper shell
    The manual for mine recommends GL-4 or GL-5. For the reasons I mentioned above I will stick with the GL-4. I found Redline MT90 GL-4 on the web.
  7. Apr 17, 2013 at 4:53 PM
    BUZZCUT
    BUZZCUT Well-Known Member
    Georgia
    2007 AC TRD OFFROAD
  8. Apr 17, 2013 at 4:59 PM
    Jetman1979
    Jetman1979 Well-Known Member
    Michael
    North Texas
    2009 tacoma 4X4
    castrol makes some good lubes. I have used there engine oil for years I say go for it.
