Cat delete
Discussion in '1st Gen. Tacomas (1995-2004)' started by Jnicolai, Aug 15, 2017.
  1. Aug 16, 2017 at 6:29 AM
    1997tacomav6
    Denver
    Supercharged???
  2. Aug 16, 2017 at 6:31 AM
    Holy schmidt
    Holy schmidt Well-Known Member
    Wyatt
    Nebraska
    Sadly no. So still might be a benefit for you
  3. Aug 16, 2017 at 10:42 AM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    you can have a test pipe made for under $100 i would say. or weld in some pipe yourself. I can almost guarantee there will be SOME gain up top end. be cheap hp. get an o2 sim if cel bothers you.
    1997tacomav6[QUOTED] likes this.
  4. Aug 17, 2017 at 8:58 AM
    Wulf
    Wulf no brain just damage
    rock raisin
    I guess it depends on the headers, mine are 2.25" at the collector before the cat so it will always be limited there even if I increase the diameter after.
  5. Feb 18, 2019 at 7:48 AM
    1997tacomav6
    Denver
    Ordered both of those last Friday to see if there is a big difference.
    LCE has a direct fit test pipe for 80.00
    My OEM cat still looks ok, So I put it back on.
    I returned the Magnaflow, it sounded terrible and now my higher rpm power is back with the OEM cat.
    If you have a supercharger definitely DONT buy the Magnaflow cat!!
  6. Feb 18, 2019 at 9:03 AM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    weird I have 2 Magnaflow cats and noticed no difference in sound or power with them versus the OEM ones. They make a few different options so I guess it depends, I had to get the CA spec ones.
    Going on 2 years since I had them installed and they've been fine, although I do notice the front one has a bit of rattling inside of it now. Might not last too much longer but can't really expect aftermarket cats to last very long.
  7. Feb 18, 2019 at 9:56 AM
    1997tacomav6
    Denver
    I have the single cat, so maybe it’s larger and different
  8. Feb 18, 2019 at 10:00 AM
    1997tacomav6
    Denver
    It did notice the Magnaflow cat was 2” Or so smaller across and the weight was half or a third lighter and the inside
    filter was only 3/4 in side, where as the OEM cat the filter screen was end to end
    eon_blue[QUOTED] likes this.
  9. Feb 18, 2019 at 10:04 AM
    eon_blue
    Azusa, CA
    yeah unfortunately it's impossible to get an aftermarket cat that'll function and perform as well as OEM, but that's why OEM is so much more expensive...more valuable catalyst material. I'm not looking forward to having to replace the front one again, since this time I got the bung for my AFR O2 sensor welded into it. Gonna have to have that re-done when the time comes to replace the cat
  10. Apr 30, 2020 at 9:24 AM
    lenoxluda
    lenoxluda Well-Known Member
    09 Sport
    How does it sound after removing the secondary cats? You running aftermarket exhaust too?
    SC2SC[QUOTED] likes this.
  11. Apr 30, 2020 at 9:49 AM
    SC2SC
    SC2SC Likes Pineapple on Pizza
    Jonathan
    South of Charlotte
    2014 DCSB MGM TRD OR 4X4
    Icon Custom Build Custom Exhaust • SOS Sliders• RokBlokz
    Sound is mostly the same, but is more enhanced. The truck drives much “lighter” and can coast much farther on city traffic 35-45mph. When I lift off the gas- truck mostly maintains speed for several seconds before slowing. Here is what I had done for my 2014:
    Full custom 2" stainless exhaust with re-route design from Charlotte Speed Shop.
    TRD Cat-back exhaust (now with larger diameter stainless Y and pipes to input)
    Rear catalytic converters removed, no check engine light on.
    Started with TRD cat back- then changed everything forward from muffler to front cats. I believe the Y connector is Magnaflow- much larger Y than OEM. TRD exhaust opens up 2500- 3500 rpms or so. Interstate speed is fairly quiet.
    I have now completed 3 cross country wheeling trips, still zero issues and no CEL.
    Hope this helps!
    lenoxluda[QUOTED] likes this.
  12. Apr 30, 2020 at 9:53 AM
    lenoxluda
    09 Sport
    Nice bro!!! Yeah this info helps!! I have a URD cai and TRD muffler. Looking for a little more sound without spending 500+ for aftermarket y pipe. Local shop said they'd remove the secondary cats for 250. Think that's a deal??
    Thanks man!!
  13. Apr 30, 2020 at 7:24 PM
    SC2SC
    Jonathan
    South of Charlotte
    Sounds good! With mine they removed and remade the exhaust. Sooo, mine was a little more spendy. Enjoy!
  14. Sep 22, 2022 at 6:55 PM
    Ž@¢K
    Ž@¢K Farts a lot..
    Ky
    2003 Tacoma TRD 4dr Prerunner 4wd conversion
    6”rough country lift, 35” bfg mud terrain, step bars, home made solid 5" bull bar frame mounted top and bottom with gussets ( used an excavator to completely suspend the truck in the air held only by the bull bar), 180k, no rust, no leaks, no cel's, no issues. 4wd conversion with front and rear e-lockers.
    Why do the people with 2nd gen keep posting on the first gen shit? Its a totally different system from intake to exhaust.. the ecu is different and sensors are all different in different locations and all..
    But everybody is always asking why anybody would want to remove a cat.. the oem cats wont be restrictive much at all but are restrictive a bit with turbulence creating backpressure. But deleting even 1 changes the exhaust sound and makes it more throaty. Stock exhaust sounds really restricted and quiet like factory crap should be. But if looking for hp gains then headers to true dual pipe would be the way to go because the factory collector takes the 2 - 2" pipes and shapes em into a D and butts em together which reduces the overall diameter down to a single 2.5" tube that goes into the first cat at the bend.. that collector is whats gonna keep backpressure if cats are removed but will open up the sound. As far as the cel after removing, ive had good luck always with welding in those spark plug arrestors and extending the sensor out with 2 or three stacked together adding another 1.5" standoff for the o2 sensor o not pick up all the stuff the cats would normally stop.. the first o2 can be left with or without headers or cats. 2nd is one that will throw the p0420 smokers code.. but even with stock big ass muff on the truck the cat delete gives it a better sound.. and not a loud trashy sound.. in my opinion.. i deleted mine thinking they were clogged up because my acceleration was surging pretty bad but turned out the damn muffler rotted from the inside out and was the blockage but now i got a 3" header back with a fart can on the back with a glasspak and sounds perty gewd.. not too loud but loud enough so people know it when they pull a dumbass and you wot it past em with the finger flying and smoke rollin..
  15. Sep 22, 2022 at 6:58 PM
    #35
    Bishop84
    Bishop84 Well-Known Member
    I know some wheelers that won't go out with catless trucks.
    V6's aren't so bad, but some v8s really make your eyes water when you're behind them for 3 hours.
    I never saw a 3.4 catless, but saw lots of the older 3.0 v6's with no cats, and zero change in power. Just noise.
    Most healthy cats are zero restriction. Just a few of the old days of cats melting caused people to think they cause power loss.
  16. Sep 24, 2022 at 9:13 AM
    #36
    Ž@¢K
    Ž@¢K Farts a lot..
    Ky
    Yea the cats i had wouldnt restrict like you said but they do have an effect on sound so guess theyre kinda like a women. Theyre better for you when you have em, they can make your eyes water when you go without em but damn it sounds good at the time when you get rid of em, but when you do have em and want em to stay theres always a chance some fuckers gonna come by in the night and steal em from you...
    Lol..
  17. Nov 7, 2022 at 7:26 AM
    #37
    W.terry619
    W.terry619 Chano leyva
    Chano leyva
    Mexico
    2011 Tacoma
    Exhaust, intake, lift kit.
    How does it sound? You like it overall?
