Catalytic Converter Acid Wash
Discussion in '2nd Gen. Tacomas (2005-2015)' started by libagui, Sep 29, 2012.
  1. Oct 2, 2012 at 12:49 PM
    #61
    medusa1066
    medusa1066 Well-Known Member
    Jonathan
    Morgantown, WV
    2007 4x4 TRD Sport
    Hey Libagui!! Don't EVER use that stove [edit: keg] for making beer, wine, or food in ever again. So much Heavy Metals have came from your Cat that you will turn into Ozzy Osbourne!!:eek:
  2. Oct 2, 2012 at 2:04 PM
    #62
    libagui
    libagui [OP] Well-Known Member
    Dominican Republic
    05 tacoma prerunner
    Bilsteins 5100 set at .085 Rear custom 1" add a leaf 265/70 R17 tires. Custom made aluminum tonneau cover with bike rack. 4x4 conversion with 4Runner transfer case.
    For sure, you are totally right, I was thinking on marking it with some sort of sign to make everybody else aware of it..!!
    Thanks for your advice..!
  3. Oct 2, 2012 at 3:09 PM
    #63
    gmcuajo
    gmcuajo Well-Known Member
    Puerto Rico
    Just -sylvania ZXE on head & fog lights -the tires
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/240419-new-catalytic-convertor-2.html#post5775237
    For what I learned from this other thread and the pictures, the thing is that the catalytics are built into the exhaust manifolds (something that you doesn't point out), that's why they want to charge you $1300 each, they are selling the exhaust manifolds (which have the cats on it), is not because they are any super special cats on tacomas...
    My advice, take it if you want, go to a muffler shop and make them put new cats on it. I am sure they will work fine and your truck won't throw any codes...
  4. Oct 2, 2012 at 5:18 PM
    #64
    libagui
    Dominican Republic
    05 tacoma prerunner
    You haven't make your homework, they are different, search a litter and maybe you understand they are different...!
  5. Oct 2, 2012 at 5:21 PM
    #65
    libagui
    Dominican Republic
    05 tacoma prerunner
    Well, I have a good news: 73.2 miles, the scanner says no more pending monitors, and the green light in the scanner is on, no exhaust problem detected...
    This shows potential of good results, cause you never get that green light in the scanner if there's something wrong with emision system..:)
  6. Oct 2, 2012 at 5:26 PM
    #66
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    That's good to hear. Once I swap mine out I'll setup to bathe my old ones.
  7. Oct 3, 2012 at 3:35 AM
    #67
    libagui
    Dominican Republic
    05 tacoma prerunner
    It was not plugged, exhaust gases came easy out of it. It was only throwing P0420 code...
  8. Oct 3, 2012 at 6:11 AM
    #68
    gmcuajo
    Puerto Rico
    I search and didn't find anything. Where to search, here?
  9. Oct 3, 2012 at 6:31 AM
    #69
    Sandman614
    Tim
    '06 SR5 Off Road
    You have attempted to do some of your own research. Try some of these threads. If you can't find what you want them create a new thread like I suggested asking specifically what you want.
  10. Oct 3, 2012 at 7:46 AM
    #70
    Utard
    Utard Well-Known Member
    Mark
    Tidewater, OR
    2019 Tacoma SR5
    What happens to the ones crack heads cut out? Maybe find a set on ebay?
    #70
  11. Oct 3, 2012 at 8:05 AM
    #71
    Sandman614
    Tim
    '06 SR5 Off Road
    They are hacked off and scraped for their weight in precious metal.
    #71
  12. Oct 3, 2012 at 12:19 PM
    #72
    racer1x
    racer1x Well-Known Member
    campbell ca
    05 Taco
    Too many
    I got the same code p0420, dealer said no way it was the 02 downstream sensors; they have their own codes, and tried to sell me cat assemblies for $1400. I said F that and threw in two new downstream 02 sensors, and haven't gotten a code for six months so far.
  13. Oct 4, 2012 at 11:56 AM
    #73
    libagui
    Dominican Republic
    05 tacoma prerunner
    100 miles and not check engine light.
    From now on, I'll be reporting the results in first post of this thread.
    I will also included some archives from EPA, regarding installing, selling, regenerating cats, this is very important, so you don't do something against law in the USA.
    EPA describe a procedure for testing and certifying regenerated cats, but no procedure to make the regeneration is described..
  14. Oct 4, 2012 at 4:43 PM
    #74
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    That is awesome
    Great job... This will save people tons of money.
  15. Nov 10, 2012 at 10:36 AM
    #75
    libagui
    Dominican Republic
    05 tacoma prerunner
    600 miles on acid washed catalytic and everything is going just right....
  16. Feb 6, 2014 at 3:53 PM
    #76
    ChrisM2097
    ChrisM2097 New Member
    I'm currently getting code P0430 (Bank 2 Cat failure), and am planning on cleaning out the catalytic converter (possible even all 4, just as a preventative). How much Citric Acid did you use for the solution?
    I just bought a 5lb bag on Amazon, and am hoping I can do this on Saturday. Got to get my truck emissions tested (California) at the end of this month, and don't want to spend $1,000+ on parts if I don't have to.
  17. Feb 6, 2014 at 6:10 PM
    #77
    libagui
    Dominican Republic
    05 tacoma prerunner
    Hi:
    First of all, this is not something you do for preventive maintenance, this is something you only do with a already faulty cat, so you don't run the risk of damaging something that is already working right. having said that, this is what you have to do.
    You need to make a 0.1 mol concentration misture, this is 21 grams per liter of water of citric acid and 12.5 grams per liter of water of oxalic acid.
    Do not exceed this concentration, cause you can take precious metals out of the cat.
    pour it all into water at 50 celcius degrees, and cook your cat for 3 or 4 hours. if you can use a device to recirculate the mixture you can have better results.
    be sure to back flush the cat with plenty of water after you finish.
    Hope you get the same good results I got.
    regards, libagui.
  18. Feb 10, 2014 at 4:41 PM
    #78
    ChrisM2097
    Unfortunately, I didn't get the same results. At first, it was looking good, when I charted the O2 sensor. After the engine warmed up, I was seeing a nice steady 0.6-0.7v. Both at idle, and when holding about 3,000rpm...then I went for a test drive and things went downhill. I started seeing the voltage all over the place again - jumping between 0.1v to 0.8v on the Bank 2 downstream sensor. The Bank 1 downstream sensor was looking great, staying steadily just over 0.5v.
    One thing I noticed, though, was that the Bank 1 & Bank 2 upstream O2 sensors weren't in sync. Bank 1 holds pretty steady at 0.3v, while Bank 2 holds pretty steady at 0.6v...both with rapid +/-0.05v fluctuation.
    Anyone have any ideas on what else I could look at?
  19. Feb 10, 2014 at 6:04 PM
    #79
    libagui
    Dominican Republic
    05 tacoma prerunner
    Did you try to check if it was a bad sensor in the first place?
