catalytic converter clamps
Discussion in 'General Automotive' started by NetMonkey, Jan 28, 2009.
  1. Jan 28, 2009 at 10:00 AM
    NetMonkey
    NetMonkey [OP] Well-Known Member
    Geogetown, TX
    2010, 4x4, DC, off-road, shortbed, automatic
    Toytec Ultimate Lift @ 3", Mickey Thompson MTZ's 285/75/16, Moto Metal 955b, rear 2" ALL, Marlin Crawler sliders
    hey guys,
    i read about this in the latest Truck Trend magazine.
    it is called CatClamps and it prevents your catalytic converter from being stolen. costs about $150 (which is cheaper than a new converter):
    http://www.catclamp.com/
    The CATCLAMP[SIZE=-4]TM[/SIZE] has two specially designed split collars with a security bolt and key design that lock tight to the exhaust pipe on either side of the converter, similar to a muffler clamp except it uses a key (included). This feature allows the CATCLAMP[SIZE=-4]TM[/SIZE] to be removed for adjustment, converter service or other mechanical work the vehicle may need that requires the exhaust to be removed from the vehicle. This feature also allows the CATCLAMP[SIZE=-4]TM[/SIZE] to be used on more than one vehicle. The CATCLAMP[SIZE=-4]TM[/SIZE] is made entirely from stainless steel so it will virtually last forever. These are all features exclusive to the CATCLAMP[SIZE=-4]TM[/SIZE] and not offered by the competition.
    Specially designed heavy duty wire ropes are permanently attached to the collar halves. The top section of collars with the wire ropes is placed over the top of the catalytic converter, and the bottom section of collars with the wire ropes is placed underneath the converter. This unique design allows the CATCLAMP[SIZE=-4]TM[/SIZE] to protect all size and shape converters.
    The two collar halves are bolted together and tightened securely to the exhaust pipe. This creates a heavy duty cage around the entire converter. The cage is then locked to the vehicle frame or cross member with the same heavy duty wire rope. Two stainless steel springs are then put around the CATCLAMP[SIZE=-4]TM[/SIZE] to eliminate the chance of the wire ropes rattling against the converter.
    The specially designed wire rope is nearly impossible to cut without using industrial machines creating too much work for a thief in a hurry. The CATCLAMP[SIZE=-4]TM[/SIZE] will not affect the function of the catalytic converter. The CATCLAMP[SIZE=-4]TM[/SIZE] can be installed by anyone with basic mechanical knowledge in 20-30 minutes with a 3/8” ratchet and the CatKey installation/removal tool (included). There is no cutting drilling or welding involved in the installation process.
  2. Jan 28, 2009 at 10:05 AM
    98tacoma27
    Ben
    Not Beech Creek
    That won't work. If I want your CAT that bad, I will cut through the exhaust pipe and take the clamp with me. Then cut the clamp off with any oxy torch.
  3. Jan 28, 2009 at 10:07 AM
    harshest
    harshest I am the Sofa King
    Michigan
    05 PreRunner SR5
    Fog Light On, Hidden Garage Door Opener, Scanguage II, Weathertech Liners, Cig lighter always on, Door buzzer removed from dash- Upcoming: 5100s for front and rear, set fronts to 2.5" and Toytec AALs.
    What kind of neighborhood do you live in where your CC is being stolen? I have never heard of such a thing. I have heard of airbags being stolen but this is a new one to me.
  4. Jan 28, 2009 at 10:16 AM
    NetMonkey
    Geogetown, TX
    the clamp runs through the frame of the vehicle so you would have to use your oxy torch under the truck.... i think that would be very obvious.
  5. Jan 28, 2009 at 10:17 AM
    NetMonkey
    Geogetown, TX
    there are some threads here about cats being stolen. apparently, it is becoming more prevalent.
  6. Jan 28, 2009 at 11:03 AM
    98tacoma27
    Ben
    Not Beech Creek
    Haha. Missed that part. Personally I wouldn't want that cable hanging down under my truck.
    There was a dealership (Hundai I think) that had over 20 of them stolen on the lot. CAT contain two rare/expensive metals; platinum and rhodium. Rhodium being worth around $10000 an ounce as of last June. it has since fallen off to around $800 an ounce. Granted, they don't use alot of it in CATs. SOURCE
    Salvage yards were paying good money for used CATs.
  7. Jan 28, 2009 at 11:11 AM
    06Bluez
    06Bluez Well-Known Member
    Phoenix, Arizona
    06 4x4
    Icon Coil-overs, TC UCA, with Bilstein 5150 and Icon 3 leaf pack. 17" Moto Metal 951 4.5" Backspacing wrapped in 285/70/17 BFG AT's. Demello front bumper and Avid offroad sliders.
    I live in good area and my Cat was stolen.
  8. Jan 28, 2009 at 11:34 AM
    06Bluez
    Phoenix, Arizona
    06 4x4
    If you are concerned about your Cats getting jacked just replace them with a URD Y pipe. Its nice, I have one.
  9. Jan 28, 2009 at 11:50 AM
    AK27
    AK27 Well-Known Member
    bunch of rental places were getting nailed, and air port parking lots
  10. Mar 26, 2015 at 8:05 AM
    floatingfortress
    floatingfortress New Member
    california
    2015 prerunner 2wd
    does the URD Y pipe replace the cat?
