Catalytic Converter stolen from my truck.
Discussion in '1st Gen. Tacomas (1995-2004)' started by ssjostrom1980, Mar 6, 2010.
  1. Mar 6, 2010 at 5:41 PM
    ssjostrom1980
    ssjostrom1980 [OP] Taco Love
    Phoenix
    1998 SR5 4x4 v-6 5 speed
    I have put a K&N Air intake, 1500 series bilstein shocks set at 2.5, with a procomp add a leaf to the rear springs giving 1.5 inch lift to the rear. Kenwood Excelon Deck with USB Port 4.0 V Pre Outs! Infinty Ref 4 channel amp for mids and highs Infinity Kappa Perfect component 6.5 in the front and kicker 6.5 two way in the rear. Alpine mono amp for 2 kicker 10 inch competition Subs in a custom Tacoma box. Gold Plated battery Terminals. BFG All Terrain 31's.
    I went to start my truck and it sounded like a dam race car!! Ilooked underneath and there were bolts laying on the ground and my cat was missing! Has this happened to anyone else? Whats the best choice for replacement etc... 49 or 50 state legal... Should I have it welded to prevent future theft? will it trip the ecu if it is not 50 state legal?
  2. Mar 6, 2010 at 5:45 PM
    godofspeed
    godofspeed Washington State.
    2010 4x4 TRD OR DC
    Body Armor front bumper Body Armor rear bumper 17x8.5 Method Bead Lock 35x12.50 Camburg LT Fox coilover All Pro 11 pack leaf Fox rear shock with DSC Allpro frame slider Smittybuilt 9500 winch Cobra CB w/firestick antenna. Hi-lift Smittybuilt air compressor
    That sucks. People are going around and stealing the cats to sell. There was a news article on it recently. The theft ring got caught. I will try to look for it.
  3. Mar 6, 2010 at 5:48 PM
    mikesdoublecab
    mikesdoublecab LT Chase Truck
    Mohawk Mike
    Glendale, CA
    01 Tacoma DoubleCab V6 Prerunner
    Engage Offroad long travel front and rear with some fat tires.
    thats been going on for over a year now...
    almost happened to me, but a neighbor walked out to his truck and interrupted the thieves after they jacked the cat from the truck next to mine and were crawling under mine to hit me next...
  4. Mar 6, 2010 at 5:52 PM
    bakerla
    bakerla Man, Myth, Legend
    Lyndall
    Pearland, TX
    '10 4wd OR
    CBI Moab front and CBI Trailrider rear, Budbuilt skids, Shrockworks sliders, OME Dakars w/ OME Nitros, OME 886x w/ OME Nitros, Light Racing UCAs, stainless steel brakelines F/R, Cobra 75 w/ Firestik antenna, 255/85/16 Cooper ST Maxx on 1st gen alloys, Weathertech liners, Engo 9000S winch, stickars and other shit.
  5. Mar 6, 2010 at 5:54 PM
    matthew5olson
    matthew5olson Well-Known Member
    matthew
    pittsburgh, PA
    04 ext cab 3.4L 5spd 4x4 sr5
    K&N cold air intake, doug thorley headers, rear sensor simulator, flowmaster 40 series, magnecor plug wires, Royal Purple synthetic gear lube, airaid throttle body spacer, Hyperground system, flex-a-lite elec fan.
    I have the 3.4L and I removed both cats. I replaced it with a magnaflow high flow cat that was guranteed to be 49 state legal and would not trip the CEL. It did like 2 weeks later. I asked my exhaust shop about it and he said he sold like 20 of them and they all came back bad. When he tried to get the warranty filled for them he was denied. I figured if a reputable shop was denied then I had no chance. It has since started rattling real bad. I gutted it and bought URD's rear sensor simulator. No CEL.
    BTW I didn't remove both cats at the same time. I removed the front one first, the one on the bend after the y pipe. I replaced it with straight pipe. I never had the CEL come on. I'm guessing the second one was stolen from yours (easier to access) but maybe you can just weld a staight pipe in its place and not worry. Keep in mind if a shop does a thourough visual emmissions inspection (not sure of your laws out there) they will see you are supposed to have 2 cats and can fail you for not having them.
    Also the stock cats have an inlet outlet of 2" while the rest of the exhaust is almost 2.5". The stock cats are highly restrictive, thats why i removed them.
    hope this helped. ask any questions you have. And sorry about your cat.
  6. Mar 6, 2010 at 5:57 PM
    matthew5olson
    matthew
    pittsburgh, PA
    I saw this on the news too. Aparently 8 cats over in china is worth a couple million dollars after all the precious metals are extracted. Almost make me want to steal a few. You can sell your old junk ones for at least 35 a piece on ebay. I sold both my good ones from my truck for over 100 on ebay. (it is illegal to sell used cats for use. they must be sold for scrap only) just so you know.
  7. Mar 6, 2010 at 6:54 PM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren bump stops, Crown braided/extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch,
    If I'm not mistaken, my 07 has a total of 4 cats, the aft 2 being the most accessible. I do alot of fishing, and didn't want to come back after a day on the water and discover the cats had been cut off by some assholes having a party under my truck. I decided to go to a metal fabrication shop to have a custom plate made to protect the cats. One thing you need to keep in mind is to make sure you leave alot of room for the cats to breath...they get very hot. Also, wrap the 02 sensor wires with additional heat retardant wrap. My plate was made to be removable, but had a few extra pieces welded in place to where even if they were somehow able to cut the pipes leading into and out of the cats there's no way they are comeing out. I incorporated a master lock into the design, and used some bolts that need a special key to remove. Generally, if you can have something made that will slow em down a few minutes they'll look elsewhere. From what I've read welding them in place won't work, they either unbolt the cats, use a sawzall, or a cutting tool they just run around the pipe kinda like a glass cutter.
  8. Mar 6, 2010 at 6:58 PM
    ssjostrom1980
    Phoenix
    It does suck dam bastards LOL! thanks for the reply!
  9. Mar 6, 2010 at 6:59 PM
    ssjostrom1980
    Phoenix
    I wish someone would have caught this guy! I especially wish I caught him!!
  10. Mar 6, 2010 at 7:01 PM
    ssjostrom1980
    Phoenix
    Thank you for the info man greatly appreciated! So did you notice any change in performace running just a straight pipe with the urd sim? I hear to much flow can cause a loss in power.
  11. Mar 6, 2010 at 7:02 PM
    ssjostrom1980
    Phoenix
    LOL thats a lot of money dam!! Dont they have platinum or something in them?
  12. Mar 6, 2010 at 7:06 PM
    ssjostrom1980
    Phoenix
    Thats a bad ass idea man! Thank you for sharing! hah hah I can just inagine how funny it would be for one of those theifs to get under there and see a plate and master lock blocking their precious cat scrap!! Thanks for the deatiled information I greatly appreciate it!!
  13. Mar 7, 2010 at 12:02 PM
    WhatThePho?
    WhatThePho? Greg Graffin 2016
    Andre
    HCMC, VN
    2006 STi
    The things required to pull bitches
    I have a pipe in place of my cats, It's been 400 miles and I haven't seen the CEL come on yet.
  14. Mar 7, 2010 at 4:30 PM
    t33gee
    t33gee aka Tg
    Tyler
    Riverside, CA
    03 prerunner
    k and n CAI, magnaflow exhaust, NOS
    by CEL do you guys mean MIL? just wondering?
  15. Mar 7, 2010 at 4:32 PM
    godofspeed
    2010 4x4 TRD OR DC
    CEL = Check engine light.
  16. Mar 7, 2010 at 4:36 PM
    t33gee
    t33gee aka Tg
    Tyler
    Riverside, CA
    03 prerunner
    malfunction indicator lamp (MIL) = correct term :D
    but thats just me i guess
  17. Mar 7, 2010 at 4:36 PM
    SC4333
    SC4333 Well-Known Member
    Grant
    FL
    SOLD - 2016 TRD Off-Road 4x4 DCSB
    Yes, its all the same. Check Engine Light, Malfunction Indicator Light; Toyota, Ford, Etc...
  18. Mar 7, 2010 at 4:42 PM
    matthew5olson
    matthew
    pittsburgh, PA
    I believe they do actually. I think thats what the reporter said. I'm guessing the extraction process is very complicated.
  19. Mar 7, 2010 at 4:47 PM
    matthew5olson
    matthew
    pittsburgh, PA
    better gas mileage, slightly less torque. There are many very long threads on back pressure. My basic understanding is less back pressure = less torque but more hp. If you went to a 6 inch straight pipe it would be noticeable. I have not had any trouble removing my cats in the power area.
  20. Mar 7, 2010 at 11:16 PM
    pdxwhiteout
    pdxwhiteout monster taco in the snow
    coty
    pdx
    monster tacoma
    3-inch body lift, 6-inch fabtech lift, 17-inch procomp black alloys wrapped in bfg 37s. trd v-6.
    this happend to a guy i work with that has a 4runner, 86 or 87 i think. same story, went outside and started the truck to the sound of a drag car:eek:. he bought a in line pipe from napa for like $30.
    that sucks man. hope that guy gets whats coming to him!!!!
