catalytic converter theft
Discussion in '2nd Gen. Tacomas (2005-2015)' started by slowmod01, Feb 1, 2012.
  1. Feb 1, 2012 at 10:42 AM
    slowmod01
    slowmod01 [OP] Active Member
    This is becoming big in my neck of the woods. I know of 3 people this has happened to in just the last two weeks. I'm trying to be pro-active here and prevent mine from disappearing, as they are too easy to access on these trucks. I'm debating on forming a steel plate to run from one frame rail to the other covering both the cats as well as the oil pan (this would ofcourse be removable with torx bits), but before i go there i would like to know if there is someone out there already that is producing skid plates in the aftermarket scene that may accomplish the same thing? My truck is a prerunner.
    Thanks!
    slowmod01
    2010 TuRD Sport
  2. Feb 1, 2012 at 10:50 AM
    98tacoma27
    Ben
    Not Beech Creek
  3. Feb 1, 2012 at 10:53 AM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    thats cool, havent seen that before!
  4. Feb 1, 2012 at 10:53 AM
    Aw9d
    Aw9d That one guy
    Get a skid plate for the bottom of your truck.. Protects the cat's and also is useful for other reasons :)
  5. Feb 1, 2012 at 10:57 AM
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    That's EXACTLY what i was thinking. Seems like the best excuse to buy one I can think of!
  6. Feb 1, 2012 at 11:02 AM
    jsmarine
    jsmarine Well-Known Member
    Jeff
    Dallas, TX
    2005 Tacoma SR5 Crew Cab 4x4
    ARB front & rear lockers ARB bull bar Warn XP9000 winch IPF lights
  7. Feb 1, 2012 at 11:04 AM
    98tacoma27
    Ben
    Not Beech Creek
    The cable goes around a crossmember. Ever try to cut aircraft cable with a sawzall?
  8. Feb 1, 2012 at 11:06 AM
    slowmod01
    this is what i'm looking for. I just havent seen one yet that covers that area. I have seen a tranny plate, front bumper plate, transfer case palte and rear diff plate, but not one specifically for the oil pan region.
    the cable thing is an issue for me, the one's that i know of were done with a saw. I did read some post on the net about ones in california taking the time to wrench them off, I'm not a cat theif, but if i were i would not be spending that kind of time underneath a vehicle. Of course if you brought a wrench set you could unbolt the cable cover too, at least it appears that way from the pics.
  9. Feb 1, 2012 at 11:07 AM
    Cmurder
    Cmurder 2011 TX TRD Offroad
    B.C.
    Kansas City
    2011 TX TRD Offroad
    nothing cool
    you'd have to buy 2 of them correct? one for each side? If so I guess $200 if better than new cats.
  10. Feb 1, 2012 at 11:08 AM
    slowmod01
    Good point, I would just be concerned they wouldn't try to cut the cable until after they cut off the cats. Cats wouldnt be much good any more after dangling from the cross member bouncing down the road all the way to the muffler shop:)
  11. Feb 1, 2012 at 11:09 AM
    98tacoma27
    Ben
    Not Beech Creek
  12. Feb 1, 2012 at 11:14 AM
    Cmurder
    B.C.
    Kansas City
    2011 TX TRD Offroad
    nothing cool
    if anyone reading this thread has pics of the Cat Lock installed on their Tacoma, please post. I've seen a thread of the ******** on a Tacoma. It seems waayy bulky with cables everywhere (look it up). But the Cat Lock looks a little more simple and clean.
  13. Feb 1, 2012 at 11:16 AM
    Cmurder
    B.C.
    Kansas City
    2011 TX TRD Offroad
    nothing cool
    whoa.. guess i can't use the name of the other Catalytic converter locking system?! i'll give a hint then.. it's a "Clamp" system
  14. Feb 1, 2012 at 11:19 AM
    slowmod01
  15. Feb 1, 2012 at 11:35 AM
    98tacoma27
    Ben
    Not Beech Creek
    Why wouldn't you pass? Because the rears would be missing?
  16. Feb 1, 2012 at 11:39 AM
    Utard
    Utard Well-Known Member
    Mark
    Nyssa, Oregon
    2012 DC LB 4WD TRD SPORT NAVI
    ------------------------------------------------------------ Stabilus.EZDown.Tailgate http://www.ezdown.com/home.php ----------------------------------------------- Tekonsha.Primus.IQ.Trailer.brake http://www.tekonsha.com/content/default.aspx---------------------------------------------------------------- Leer 180 CC http://www.leer.com/Truck-Caps#------------------------------------------------ Firestone Air Rite Air Bags--------------------------------------Kargomaster Rack
    That cat loc is not going to stop a thief with a sawzall. It will what add an extra 10 seconds to cutting it out. Skid plate would be the way to go.
  17. Feb 1, 2012 at 11:45 AM
    Oury
    Oury Texas Taco
    Oury
    Austin, Tx
    07 TRD Offroad
    stuff and more stuff
    Buy the URD O2 Sim and buy some skids. They won't notice a difference.
  18. Feb 1, 2012 at 11:45 AM
    98tacoma27
    Ben
    Not Beech Creek
    He won't need the sim. The rears aren't monitored by the ECU. Only the fronts are.
  19. Feb 1, 2012 at 11:49 AM
    Oury
    Oury Texas Taco
    Oury
    Austin, Tx
    07 TRD Offroad
    gotcha
  20. Feb 1, 2012 at 11:54 AM
    jsmarine
    Jeff
    Dallas, TX
    That cable only looks to be maybe 3/8". You could cut through the cable with a sawzall, if your could hold the cable still. That would be the hard part.
    But I would just cut through those eye bolts attaching the cable to the device, that wouldnt be hard to do.
    EDIT: Cordless 4" angle grinder would make quick work of this as well.
