Catalytic converter
Discussion in '2nd Gen. Tacomas (2005-2015)' started by luk8272, Jul 2, 2008.
  1. Jul 2, 2008 at 7:24 AM
    luk8272
    luk8272 [OP] Poodoo
    Lucas
    Kaplan, Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners.
    Anyone remove there second set of converters and kept the rest factory?
    I was wondering if there would be any reason to do that, or just wait until I am ready to do the full system?
  2. Jul 2, 2008 at 7:27 AM
    Hotdog
    Hotdog My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    people install the URD y-pipe which removes the last two cats. There is some performance gain but you also don't have to worry about people stealing your cats and doing other damage in the process.
  3. Jul 2, 2008 at 7:28 AM
    Hotdog
    Hotdog
    Wet Okole Underwear
    I don't know if Kaplan is as strict as B.R. with emissions. I think B.R. checks for your last two cats.
  4. Jul 2, 2008 at 7:38 AM
    luk8272
    luk8272 [OP] Poodoo
    Lucas
    Kaplan, Louisiana
    Nope they don't really care we are too small of a town takes 7 minutes to drive through on hwy 14. We only have 2 red lights. But hey we have what counts 8 bars and 5 gas stations. I'll look into that "Y" pipe.
  5. Jul 2, 2008 at 8:09 AM
    roxspin72
    roxspin72 Enjoying my addiction
    NC
    Speedway Blue, TRD, 4X4,
    Oh Yeah!!!
    Selling my moded stock pipe w/no cats. Saves you money, and all you got to do is switch back to your stock if emissions becomes an issue.
    http://www.tacomaworld.com/forum/buy-sell-trade/10781-moded-stock-y-pipe.html
  6. Jul 2, 2008 at 8:59 AM
    roxspin72
    NC
    Oh Yeah!!!
  7. Jul 2, 2008 at 10:53 AM
    tacoskim
    tacoskim Tuned By Gadget
    Los Angeles, CA
    09 TRD 4x4 Pyrite Mica
    Stock
    i removed my 2nd set cats with the pipe bomb and sounds good. but if your completely stock as of right now, theres other mods u probably would want to consider first before getting a y-pipe
  8. Jul 2, 2008 at 10:56 AM
    Hotdog
    Hotdog
    Wet Okole Underwear
    I went for the intake and MAF calibrator first. Next will be long tube headers.
  9. Jul 2, 2008 at 11:24 AM
    luk8272
    luk8272 [OP] Poodoo
    Lucas
    Kaplan, Louisiana
    Tacoskim My exhaust is factory what mods would yall recommend first.
  10. Jul 2, 2008 at 11:25 AM
    Hotdog
    Hotdog
    Wet Okole Underwear
    I love the sound of an intake.
  11. Jul 2, 2008 at 11:27 AM
    tacoskim
    Los Angeles, CA
    Stock
    get a straight through muffler before u get the y-pipe. also as isosceeeee said, intake works. if u wanna go all out get some long tubes
  12. Jul 2, 2008 at 11:29 AM
    Hotdog
    Hotdog
    Wet Okole Underwear
    I doubt you'd get a good performance bump by changing out the muffler.
  13. Jul 2, 2008 at 11:33 AM
    tacoskim
    Los Angeles, CA
    Stock
    maybe not too much performance but the engine will definitely breath alot better and wont sound as baffled once the y-pipe is put in
  14. Jul 2, 2008 at 11:34 AM
    luk8272
    luk8272 [OP] Poodoo
    Lucas
    Kaplan, Louisiana
    What intakes would yall recomend? Then a MAF Cal. followed by the y pipe. I was looking at the pipe Roxspin is selling. It would remove one set of cats, If I later install the DT headers they would remove the other cats. Does the O2 sim take care of this also. I do realize his is not the urd pipes but they should suit my needs I would think.
  15. Jul 2, 2008 at 11:36 AM
    Hotdog
    Hotdog
    Wet Okole Underwear
    I like my URD for ON-road use. The o2 sim is necessary if you remove the front two cats, not the rear two.
  16. Jul 2, 2008 at 11:37 AM
    tacoskim
    Los Angeles, CA
    Stock
    if ur gonna get the maf cal, i would do that last after all ur other planned mods, that way u only have to tune it once... if u get that first, then all ur other parts, ur gonna have to end up tuning it again.
  17. Jul 2, 2008 at 11:37 AM
    luk8272
    luk8272 [OP] Poodoo
    Lucas
    Kaplan, Louisiana
    I don't really care for the TCAI. I don't want to cut in the front of the truck. I do however see that it is superior to the others. I would more likely be interested in leaving the intake the same, yet add the headers and Y pipe.
  18. Jul 2, 2008 at 12:00 PM
    roxspin72
    NC
    Oh Yeah!!!
    Dude here is your best bet in regards to performance bang for your dollar:
    Reusable Drop in Air Filter, ie... AFE dry flow. (Your stock box is sufficient enough getting Ambient air from the fender well)
    MAF Calibrator. URD basically calibrates for stock intake & or URD TCAI shipped. (So, w/your stock set up you will see improvements upon install)
    After you get these two, then free up your exhaust in this order.
    1) High flow Muffler or (Cat-back if desire stainless steel mandrel bend piping)
    2) Headers
    3) Y-pipe (if so desire)
    I did not know you were completly stock when you PM'd me. I would increase Airflow to the engine first then free up the exhaust end.
  19. Jul 2, 2008 at 12:04 PM
    tacoskim
    Los Angeles, CA
    Stock
    ^^^^^^ well said
    but i would do the maf cal last, that way u only need to tune it once
  20. Jul 2, 2008 at 12:06 PM
    luk8272
    luk8272 [OP] Poodoo
    Lucas
    Kaplan, Louisiana
    I am still waiting on the AFE from the Group buy. I am pretty happy with the way the trucks get their air but not so much with the way they discharge it. Sounds like a plan to me. Thanks for sharing your experiences Roxspin, Isocoee,Tacoskim.
