CB Antenna location?
Discussion in '1st Gen. Tacomas (1995-2004)' started by 2001tacoma4life, Feb 4, 2010.
  1. Feb 4, 2010 at 10:32 PM
    2001tacoma4life
    2001tacoma4life [OP] 2001tacoma4life
    Tony
    Baton Rouge, LA
    01PreRunner SR5 Off-Road
    3 inch Readlift, line-x spray-n bed liner, spyder black led taillights, euro headlights, 265/75/16 bfgs allterrain, rancho off-raod shocks
    I just purchased a cobra ltd 29 cb radio. I want to mount a 3-4 foot fire stik in the bed of my 01 tacoma. I cant find a mount for the bed that doesnt require me drilln into the bed. ideas or suggeetions? thanx
  2. Feb 4, 2010 at 10:42 PM
    thekidcatcher
    thekidcatcher Well-Known Member
    Waco, TX
    05 TRD offroad SR5
    Legs- --Helo rims --Duratrac 285/75/R16 --Bilstein 5100 in front with OME 886 --Dakar with extra leaf --Total Chaos UCA's --5165's Bilstein in the rear Electronics- --Warn M8000 w/ Warn wirless remote --Cobra 29LTD CB, --12in sub with alpine amp , --Dual Battery, --Warn Air compressor --URD MAF sensor, --touchscreen cd player hooked up to front and rear cameras Armor- --All-Pro offroad front/rear/rocksliders --AP skid plate, diff armor Cajones- --JBA headers, midpipe, exhaust --Safari Snorkel --4.56s Misc- highlift jack --UWS toolbox --u bolt flip kit --Tepui Kukenam Custom- --in dash inverter --on-board shower system --dvd anytime mod --custom bed rack and tiregate.
    Check out Alientx and Silverback07. they have non hole drilling methods im pretty sure
  3. Feb 5, 2010 at 8:05 AM
    2001tacoma4life
    Tony
    Baton Rouge, LA
    yea i like how they mounted it, but i dont think they make that bed rail for 1st gen. tacomas
  4. Feb 5, 2010 at 9:11 AM
    thekidcatcher
    Waco, TX
    05 TRD offroad SR5
    Aww shit, I looked over that fact lol, sorry man.
  5. Feb 5, 2010 at 9:21 AM
    mikesdoublecab
    mikesdoublecab LT Chase Truck
    Mohawk Mike
    Glendale, CA
    01 Tacoma DoubleCab V6 Prerunner
    Engage Offroad long travel front and rear with some fat tires.
    Walcott CB has a couple bolt on brackets that dont require drilling...
    There is a bracket that clamps onto the bed rails and one for the rear bumper...
    My truck is all cut up and drilled out so can't say what the part numbers are...
  6. Feb 5, 2010 at 1:21 PM
    2001tacoma4life
    Tony
    Baton Rouge, LA
    haha its cool man, thanx anyway
  7. Feb 5, 2010 at 1:45 PM
    mikesdoublecab
    Mohawk Mike
    Glendale, CA
  8. Feb 5, 2010 at 5:26 PM
    pmbazus
    pmbazus Well-Known Member
    AZ
    2015 TRD Sport 4WD
  9. Feb 5, 2010 at 5:59 PM
    4x4Runner
    4x4Runner Now with more Oi Vey! Moderator
    Drunken Sailor
    Somewhere between Maine and Florida
    2017 4Runner Smashed Ass Edition
    KDSS
    I used a fender mount on my 2003 Tacoma. The part number it T1L.
  10. Feb 6, 2010 at 8:24 PM
    csxrailfan
    csxrailfan Active Member
    Texas for now.
    2002 Toyota Tacoma Access Cab TRD
    I run a CB and a dual band ham radio in my Tacoma. I have always loved my trucks too much to drill on them. I used the tie down brackets located in the front of the bed for my mount. They are bolted to the bed with very sturdy bolts so you don't have to worry about them coming loose. What I did was make my cb mount out of a old fire extinguisher bracket. I cut up the bracket so that I had only a L shaped bracket that was a little longer on one end than the other. I slid this under the tie down bracket and marked and drilled the holes in the new bracket. I then gave it a coat of paint and after drying I slid it in behind the tie down and tightened it back up. I now had a sturdy antenna bracket that mounted just inside the bed and also kept the tie down so I could use it if I needed to. NOW..... I have a tool box and I have all my antennas mounted to it. If it wasn't for that I would post some pics.....hope this helps.
  11. Feb 7, 2010 at 3:39 PM
    2001tacoma4life
    Tony
    Baton Rouge, LA
  12. Feb 7, 2010 at 3:41 PM
    2001tacoma4life
    Tony
    Baton Rouge, LA
    i like the idea, seems easy and no drilling :D
    thanx!
  13. Feb 7, 2010 at 5:45 PM
    devilsalmostfree
    devilsalmostfree Well-Known Member
    Carl
    Loudon, Tn
    99 Tacoma 4X4, 5 spd, 2.7 ltr
    Deck plate mod, intake silencer removed, AFE Pro Dry S Air Filter, debadged, Goodyear Duratracs 265/75R16. Flowmaster knock-off muffler!
    i like it! did u make the bracket for ur antenna or did u buy it somewhere, if u bought, do u have a link for the place?
  14. Feb 13, 2010 at 8:39 PM
    cameronlane
    cameronlane Well-Known Member
    cameron
    Anywhere but there
    2014 Dbl Cab TRD OR 4x4
    How do you ground the antenna if you mount it in the side of the bed?
  15. Feb 13, 2010 at 8:53 PM
    csxrailfan
    Texas for now.
    Well my 02 Tacoma has an all metal bed so the bolts holding the cargo tabs to the bed make a great ground. As far as the second gen. Tacomas I am guessing you would have to run a ground wire to the metal chassis in order to ground it. Seems like the cargo rail system would be mounted through the plastic bed into the chassis but I could be wrong on that.
