CB Antenna Mount with Shell
Discussion in '1st Gen. Tacomas (1995-2004)' started by Rdy2offrd88, Mar 13, 2012.
  1. Mar 13, 2012 at 7:58 PM
    Rdy2offrd88
    Rdy2offrd88 [OP] Well-Known Member
    Nick
    St. Louis, MO
    02 DC TRD
    Deckplate, CB w/ 4ft Firestick, Bedrug
    Hi everyone I am planning on putting a CB in my truck in the near future and am looking for some advice on where to mount my 3 ft firestick antenna. I have a camper shell on my truck so my options are somewhat limited. I was thinking about a metal plate that is pinched in between the bed rail and the camper or on the rear bumper corner so that it does not interfere with the tailgate opening. But with the antenna only being 3 ft would I have a problem getting good signal with the tip of the antenna not sticking out above the cab top. Also with this position would that leave a gap inbetween the bed rail top and camper bottom or would it pinch tight? Thanks for all help responses!
  2. Mar 13, 2012 at 8:05 PM
    IGO4LOW
    IGO4LOW Well-Known Member
    Zach
    Fullerton, CA
    2011 DCLB TRD SPORT 4x4 w/ JBL Audio
    3" Procomp lift, 285/70 R17 Nitto Terra Grapplers on Procomp series 6005 wheels, Fog lights on Anytime mod, illuminated oem fog switch, bed mat, all weather floormats, CB Radio in dash, alternating turn signal mod, automatic center console light. Blacked out badges, D2s in the grille.
    Ideally you want at least 2/3 of the antenna above your cab. Best location is center of the roof. Cb antennas direct their signal down and it reflects off of the metal surface. I don't have a shell but I mounted mine drivers side right behind the cab. My antenna is a 4' so it sticks up quite a bit past the roof. Still not ideal tho.
  3. Mar 13, 2012 at 8:13 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    +1
    Need a good ground, and you need elevation above the ground plane.
    If mounting on the roof is not an option, then go with a 102" whip mounted to the end of the bumper, but secure a tennis ball to it to keep it from touching the body of the bed.
  4. Mar 13, 2012 at 8:39 PM
    TacomaJPP
    TacomaJPP To secure peace, is to prepare for war
    East TN
    03 4WD TRD XTD Cab
    Snugtop Camper Brushguard
    On my 97 I had a Firestik mounted to the rear bumper on the very corner and I ran with a camper shell on it. I tuned the antenna and receiver and never had a problem.
