CB Ground Plane??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bendbolden, Oct 9, 2011.
  1. Oct 9, 2011 at 7:20 PM
    bendbolden
    bendbolden [OP] Come and take them.
    Ben
    Moscow, TN
    07 FJ Cruiser
    None but soon......
    I tried my best to search for my answer but in all the CB threads I couldn't find it. I bought a 3' CB antenna kit from my local truck stop and have a question or two. I mounted the antenna in the front left corner of the bed. I did not use the bed rail mounts some members are using but rather bolted it into the front wall of the bed. It is not one of the NGP antenna's and the mount itself is made of aluminum and therefor not conductive. I am wondering if I run a small ground wire from the base of the stud to the frame (maybe a self tapping screw under the bed caps) if I will get decent results out of this. I know I will have to tune the antenna with a SWR meter. I have been reading alot on this and am just getting more confused with conflicting explanations. If someone could answer these few questions and elaborate on it a bit more I would appreciate it. Thanks and I will try to get a picture of my mount up tomorrow.:help:
  2. Oct 9, 2011 at 8:09 PM
    oledragoon
    oledragoon Well-Known Member
    Don
    Oklahoma City
    06 Super White Tacoma TRD Off Road 4x4
    Super White Grille, and rear bumper on Off Road, TRD Intake System, TRD Cat Back Exhaust System, Custom bed bar for Emergency light bar, Overhead Console Temp/Compass Fix,rcbs Illuminated 4x4 Switch, ImMrYo Rear-View Mirror Lift Bracket, Jumpers LED's in cab, Jotto Computer desk, Cobra 29 CB & Uniden Scanner on custom dash pad, Autometer gauges(oil press, oil temp, trans temp, Batt/amp), Front bush guard, Rear bumper guard, BamaToy1997 4x4 Custom Front Hubs, OTW Mod One Touch Windows.
    I use a CB daily, escorting oversize loads. I have a Wilson 1000 antenna, mounted back center of my roof. Mine is thru the roof, however they make a magnetic mount that is just as good. Antenna height is really important for good transmission. Best ground plane for CB is the flat roof, hood, for around signal(forward, sides and back). Behind the cab will lose some strength forward. Make sure SWR is properly tuned AFTER having a pro check the antenna mounted in/on your truck. I have had excellent results with my Cobra 29 LTD, and the Wilson 1000. I'm not a radio guy, but have used 'em for years. Good Luck
  3. Oct 9, 2011 at 9:23 PM
    hamNswiss on rye
    hamNswiss on rye ¡Yo Quiero Taco World!
    Nick
    Scottsdale, AZ/Portland, ME
    '07 4x4 Access Cab
    OME 885's and billies all around, allpro apex front bumper, Nfab tire carrier, black magic rallye 1000 driving lights, custom back to the future light rack, KC LED Daylighters, PIAA 510 fogs, bed lights, satoshi, 285/70/17 Duratracs
    the wilson mag mounts are the best way to go, for sure. i run a firestik 4' the same place as you (behind the cab, drivers side) and grounded like youre saying. i bought a thick battery cable like this one: http://www.autozone.com/autozone/pa.../N-8gcx6?counter=4&itemIdentifier=571464_0_0_ for my ground. i get a decent SWR ratio, but not the greatest. most here will tell you that a wilson on the roof is always going to be #1
  4. Oct 10, 2011 at 1:26 AM
    Rellik01
    Rellik01 Well-Known Member
    Craig
    Windermere, Florida
    2012 TRD Sport 4x4 White
    Bull Guard powder coated white, chrome aftermarket tail lights,Led interior lights, Factory roof rack, Bug deflector, Factory tow package, Garmin GPS, Viper 5901 alarm with auto start, Weather tech window wind deflectors, , 3" Tube steps powder coated white, CB Radio, Radio Scanner.
    Bought a Firestik no ground plane antenna. Works not fine.
  5. Oct 10, 2011 at 6:57 AM
    bendbolden
    Ben
    Moscow, TN
    07 FJ Cruiser
    None but soon......
    What ratio are you getting if you don't mind. If I can't make this setup work I am just not going to have one. I don't really like the way they look an the roof and I just really won't use it that much other than hunting. I may do the NGP option but since i've already bought this 3 ft I want to try and make it work if I can get a useable setup. I don't even have a radio yet as I'm still trying to figure out my mounting options.
  6. Oct 10, 2011 at 6:57 AM
    bendbolden
    Ben
    Moscow, TN
    07 FJ Cruiser
    None but soon......
    You mean it does work fine??
  7. Oct 10, 2011 at 11:56 AM
    Rellik01
    Craig
    Windermere, Florida
    Thanks for the catch........does work just FINE.
    Thanks Again
  8. Oct 10, 2011 at 3:54 PM
    SCFirefighter
    SCFirefighter on idiot patrol ;)
    Stephan
    Cary, NC
    Silver 2010 DC TRD Sport 4x4 5'
    MagnaFlow Performance Exhaust, ScanGauge II, Map, dome and license plate LED's, Custom Fire/Rescue decals, Weathertech deflectors, Removed mud flaps, Rear spring TSB, Spidertrax spacers, Tinted windows (5%/27%), Black Tacoma badges, 5100 Billstein x4, ToyTec Coilovers, ToyTec TSB AAL, Devil horns, Hose clamp tailgate mod, OEM bed mat, HomeLink module, Hardwire GPS, Weathertech digital fit floor lines, Front Diff drop, Rear Diff breather mod, 4xInnovation welded sliders, Pioneer AVH-X5800BHS+SiriusXM.
    Is it true this antenna needs special coaxial cable? I'm considering a quick firestik setup for next month's trail run and would love not to have to worry about ground in our bed rail.
  9. Oct 10, 2011 at 4:48 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Any CB antenna that is an electrical 1/2 wave does not need a ground plane. Most fiberglass antennas are wound with 5.5 meters of wire some are center feed with the bottom half being the ground plane. If you are going to ground it to the frame (a good ideal) use a braded wire it won't resonate. The roof is the best place it won't slew the pattern any thing else is a compromise.
  10. Feb 26, 2016 at 8:08 PM
    Rawlins
    Rawlins Clandestine Member
    Andrew
    Colorado
    2010 Black Sand Pearl DCSB TRD-OR
    Full RCI Trail Armor, 3" Toytec Lift, TC UCAs
    Sorry to resurrect this but...
    For those arriving from a search engine or some other happenstance, aluminum IS a conductor, conductivity is even better than iron and steel and almost as good as copper. So the aluminum mounts ARE conductive
