cb in dash help/questions
Discussion in '1st Gen. Tacomas (1995-2004)' started by Rhino, May 23, 2011.
  1. May 23, 2011 at 10:34 PM
    Rhino
    Rhino [OP] Well-Known Member
    Laurel, Mississippi
    03 TRD SR5 4x4
    gray wire mod, blacked out, debadged, toolbox foglights, cb in dash, system, bilstein 5100's in front wrapped in eibach coils, 5125's in the rear with 2 inch aal and 1 inch shackle, diff drop kit, extended rear brake line, 8000 lb smittybuilt winch on a custom winch bumper, 2 4 inch 100 watt kc's and 2 6 inch 100 watt kc's on the bumper, sometimes a ladder rack,much more to come
    i want to mount a cb in my dash..i know i want a cobra..i absolutely adore the 25 but im not sure if it would fit in my dash, i want it right under my radio like tacomazach's or either under the ash tray where the 2 extra cigarrete lighter outlets are
  2. May 23, 2011 at 10:43 PM
    bellassaiw10
    bellassaiw10 Formally afroman5015
    Currituck NC
    09 LMM 2500HD Duramax
    I wanted ot put mine there put after further research it wouldnt fit so i just put it under the parking brake
  3. May 23, 2011 at 11:23 PM
    Rhino
    Laurel, Mississippi
    03 TRD SR5 4x4
    that might be where i end up puttin mine. i have a cobra 29 right now and i wired it to my speaker amp in the back seat and i just dont like the wires everywhere
  4. May 23, 2011 at 11:56 PM
    DIRT YOTA
    DIRT YOTA Aka EL ROJO
    Cory
    Camarillo, CA
    03' dbl cab with some stuff
  5. May 24, 2011 at 12:02 AM
    SpazzyB
    SpazzyB Master of the Prius...
    Ryen
    neuf un six
    '04.5 vw stance machine
    mounted mine in the exact same spot, the mic is mounted under the hazards.
  6. May 24, 2011 at 8:09 AM
    01Tac0ma
    01Tac0ma Bash Fabriction & Off-Road
    Chad
    West Columbia, SC
    SAS 01 TRD 4x4
    Look at build!
    x3 same exact spot and flush with the dash, but i mounted my mic to the right of the air vents.
  7. May 24, 2011 at 8:17 AM
    DWreck
    DWreck Famous Retrieval Vendor
    Derek
    Las Vegas, NV
    2004 Tacoma Smurf Truck
    Plasti-dip paint, TRD S/C, MCM Fab LT kit, bunches of my fab
    Get a dx19
  8. May 24, 2011 at 9:14 AM
    DIRT YOTA
    Cory
    Camarillo, CA
    Put the mic down out of way....
  9. May 30, 2011 at 8:44 PM
    Rhino
    Laurel, Mississippi
    03 TRD SR5 4x4
    so how do i go bout doin this?
  10. May 30, 2011 at 9:04 PM
    ttran
    ttran Expert Mallcrawler
    Tim
    Cary, NC
    06 DCLB Prerunner Sport
    TRD Sport Prerunner
    subbed
  11. May 30, 2011 at 9:31 PM
    DIRT YOTA
    Cory
    Camarillo, CA
    Wish I did a write up when I did it but I describe some steps, It was real easy. Get the antenna, cb, and cable. Basic install can be found on this site and ttora. The part that may require extra work is mounting the cb unit. Take that part of dash apart, the blk shell where ash tray, radio and all mounts to comes out. I dremelled the back out of the ash try area so the cb would sit further back. I bought a right angle connecter for the antenna cable which helped a bit. The way I mounted it was using a piece of metal braket that u use on heating duct and such, it comes in rolls with pre drilled holes on it. Very common at hardware stores. Cut it to length, bent both ends at a 90*(looked like a big staple), use that to bolt it in to the black part of the dash. Without pics its hard to descibe. The cb radio fit pretty snug anyways, so there are many ways to make it stay. I just didn't want it bouncing out on hard offroading. Hope this helps a little bit :) it really was easy, hard part was put antenna cable under carpet. I'll try to find the links to threads I used. When I get around to putting in a head unit I will snap some pics of my macguyver install.
  12. May 30, 2011 at 9:44 PM
    DIRT YOTA
    Cory
    Camarillo, CA
  13. May 31, 2011 at 9:47 AM
    Rhino
    Laurel, Mississippi
    03 TRD SR5 4x4
    thanks it helped alot actually i have an aftermarket head unit in my truck so i knew the black part came out i just couldnt figure out how to make the cb stay there so when i get paid i'll be gettin a cobra 19 to replace my 29
