CB install Help
Discussion in '1st Gen. Tacomas (1995-2004)' started by TRDMadness, May 3, 2011.
  1. May 3, 2011 at 10:10 AM
    TRDMadness
    TRDMadness [OP] Well-Known Member
    Chandler
    Clovis,CA
    1999 Toyota Tacoma TRD
    Eibach coilover with bilstein shock, Dakar Old Man Emu leafs with 5125 billies. Total Chaos uniball upper control arms. AFe cold air intake. Trail-gear stinger, rear tube bumper and slider.Debadged, chrome demolished.
    Recently purchased a Cb from a thrift store, don't know the exact model, but it has the little GE symbol on it. Just couldn't pass it up for $10. I have looked and searched around to find how to install it, but no luck. all I need to know is the black and red wires coming from it, which one goes to a ground and which one needs power? Also, I helped my stepdad install his on his FJ a while back, and we had to put in a Add-a-fuse. Will I need to do this on the Tacoma as well?Any advice will be helpful. Thank you.
  2. May 3, 2011 at 10:14 AM
    TRDMadness
    Chandler
    Clovis,CA
    Great thanks! should I tie the power into an existing power line? or run a line to the battery?
  3. May 3, 2011 at 10:21 AM
    davidpick
    davidpick NWXPDTN
    David
    Snohomish, WA
    2004 Xcab 4x4 TRD
    red is hot, black is ground. you may also want to run it through a relay to a switched power source (i.e. clock) so that you can't accidentally leave it on and drain your battery when you turn the truck off.
  4. May 3, 2011 at 10:23 AM
    TRDMadness
    Chandler
    Clovis,CA
  5. May 3, 2011 at 10:24 AM
    TRDMadness
    Chandler
    Clovis,CA
    Ok, Thanks. Did you have this problem? (draining the battery)
  6. May 3, 2011 at 10:30 AM
    joerussell610
    joerussell610 When all else fails read the directions
    Him
    Making myself at home in your house
    2005 DC Sport Edition 4x4
    K&N, fog light mod, remote rear halogen fogs mounted under rear bumper, TRD skid plate, Flux Capacitor, Mr. Fusion upgrade soon
    Really? Oh how I weep for the future! :facepalm:
  7. May 3, 2011 at 10:35 AM
    davidpick
    davidpick NWXPDTN
    David
    Snohomish, WA
    2004 Xcab 4x4 TRD
    well it's not so much a power "bleed," it's just that i could see myself accidentally leaving the cb switched on, so i put a relay in so that even if the cb is left switched on, it will turn off when i turn off the key in the truck.
  8. May 3, 2011 at 10:53 AM
    Mod
    Mod Well-Known Member
    CR, WA
    1999 8 port 3RZ 4WD SR5
    stock
  9. May 3, 2011 at 10:54 AM
    TRDMadness
    Chandler
    Clovis,CA
    hahaha I know, I know. I even took an electronics class in high school..shows how much I was paying attention.
  10. May 3, 2011 at 10:56 AM
    TRDMadness
    Chandler
    Clovis,CA
    Dang that would take me a whole less than five minutes. And the CB would be able to be unplugged and moved out the way if needed. Thanks for the help dude!!
  11. May 3, 2011 at 11:03 AM
    TRDMadness
    Chandler
    Clovis,CA
    Yeah when I helped my stepdad with his in the FJ we didn't ground it properly and had to tear the console off again. To ground the antenna can't I just bolt the mounting plate to the bed? How did you ground it?
  12. May 3, 2011 at 11:03 AM
    Mod
    CR, WA
    stock
    Yup, no problem. I have had one of those powering my CB for the past 10 yrs. With my $50 Uniden and good Firestik antenna I can talk 10 miles.
    Keep your coaxial antenna wire as short as possible and buy a tunable tip antenna (firestik). Use a swr meter to tune it in.
    Good info in the "tech help" as you go along with the install.]
    http://www.firestik.com/
    You'll have more money in the antenna,cable and mount that you paid for the CB,,but that is the biggest part of the battle.
  13. May 3, 2011 at 11:10 AM
    TRDMadness
    Chandler
    Clovis,CA
    My stepdad said that the wire from antenna to CB NEEDS to be 19ft. I don't know why at the moment, but he said that. Yes, I plan on going to 4wheelparts for Firestik and mount. Thanks I'll make sure I check that out this weekend when I wire it up. haha yeah I know, but it will be worth be able to talk when im stranded in the mountains. Again, thank you very much for the quick response and info!
  14. May 3, 2011 at 3:27 PM
    ecupcar
    ecupcar Well-Known Member
    20 miles south of nowhere
    09 Tacoma and 99 4Runner Limited
    Leer color match cap, prodigy break controller, Thule rack, window tint, bed mat and bug deflector
    Where did you mount your cb? I am 6'5 and I hit my break controller all the time, would like to see where you put yours.
  15. May 23, 2011 at 10:28 PM
    Rhino
    Rhino Well-Known Member
    Laurel, Mississippi
    03 TRD SR5 4x4
    gray wire mod, blacked out, debadged, toolbox foglights, cb in dash, system, bilstein 5100's in front wrapped in eibach coils, 5125's in the rear with 2 inch aal and 1 inch shackle, diff drop kit, extended rear brake line, 8000 lb smittybuilt winch on a custom winch bumper, 2 4 inch 100 watt kc's and 2 6 inch 100 watt kc's on the bumper, sometimes a ladder rack,much more to come
    i have 2 ten inch subs in my backseat and i wired it into my amp and it runs fine and doesnt pull any power from my subs
