CB install question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by HolyReptar, Mar 21, 2012.
  1. Mar 21, 2012 at 3:42 PM
    HolyReptar
    HolyReptar [OP] Well-Known Member
    Bry
    Ventura
    17 TRD Offroad 4x4
    Stock for now
    So I am trying to figure out the best way to connect my CB, I would love to direct connect it to the battery but I really don't want it to be able to be on if the ignition is on. I know I will forget to turn it off at the wrong moment:eek:
    If I added an aux fuse box would I be able to set that fuse box to not have power if the ignition isn't on.... any ideas would be helpful.
    Thanks
  2. Mar 21, 2012 at 4:15 PM
    SodakTaco
    SodakTaco Well-Known Member
    Wyoming
    2011 DCab TRD Sport
    Floor mats
    I don't know much about CB's, but I'm sure you can tap in to any switched power source in the stock fuse box to power your radio. With a multimeter, you should be able to easily determine which ones have power when the ignition is on. From there you can wire in your own fused circuit. I have an old Uniden I picked up at a garage sale, and from reading on here, the most challenging part will be mounting and running the antenna wiring.
  3. Mar 21, 2012 at 4:24 PM
    Junebug55210
    Junebug55210 2011 TRD Sport 4x4
    Kyle
    Gainesville, FL
    11 DC TRD Sport 4.0
    Cat back magnaflow, toolbox, camo seat covers
    You can wire to a fuse that cuts off with the ignition. I have left mine on accidentally for 2 days before and never drained the battery at all. They dont draw much power unless you have a linear and are talking a bunch on it.
  4. Mar 21, 2012 at 4:28 PM
    trdNick
    trdNick Odie
    Texas
    07 Trd Off Road AC PreRunner Grocery Getter
    0956x1__21413_zoom.jpg[​IMG]
    Just plug this into your fuse block behind the dash and will only come on with the key turned on
  5. Mar 21, 2012 at 4:30 PM
    HolyReptar
    Bry
    Ventura
    17 TRD Offroad 4x4
    Stock for now
    picture didn't work bud
  6. Mar 21, 2012 at 4:41 PM
    trdNick
    trdNick Odie
    Texas
    sorry should be there now
  7. Mar 21, 2012 at 4:43 PM
    NYCO
    NYCO go explore...
    bOb
    Colorado
    Blue Betty - '06 TRD OR
    dents & scratches
    tied my cb into the mirror adjuster...12v source that turns on with the key
    mirror adjuster isn't used that often and you don't need to run wires all over
  8. Mar 21, 2012 at 5:09 PM
    LUSETACO
    LUSETACO Here for the Taco Pron
    Dennis
    South Central Pee A
    2002 Sliver-ade-o 2008 P71
    Yes
    Run it straight to the battery for best performance. Like already stated it draws very little power and won't drain your battery.
  9. Mar 21, 2012 at 5:17 PM
    trdNick
    trdNick Odie
    Texas
    you get the least amount of noise through the radio by running your ground directly to the battery as well, no engine noise
  10. Mar 21, 2012 at 5:24 PM
    HolyReptar
    Bry
    Ventura
    17 TRD Offroad 4x4
    Stock for now
    Ive heard that if you connect it directly to battery you get engine noise... thanks for the heads up there
  11. Mar 21, 2012 at 5:30 PM
    trdNick
    trdNick Odie
    Texas
    I had better luck going to the battery, was grounded to the body, but thats just my experience.
  12. Mar 21, 2012 at 5:32 PM
    trdNick
    trdNick Odie
    Texas
  13. Mar 21, 2012 at 5:32 PM
    saundern
    saundern Swerve for nothing
    Nick
    Greenville, SC
    2005 TRD Sport
    this is out of my 1st gen but you get the jist
  14. Mar 21, 2012 at 5:35 PM
    Seabass
    Seabass Chrome won't get you home
    Adam
    AZ
    '06 Sport 4x4
    Let's be honest... you really only care about your own rig.
    Ran mine through a lit switch and direct to the battery. Put the switch right next to the cup holder by the shifter. If I accidentally leave it on, I see the light on the switch when I'm getting out. Gets full power, best ground, and gives me a quick way to turn it on without having to reach behind the center console and fumble around.
  15. Mar 21, 2012 at 5:44 PM
    LUSETACO
    Dennis
    South Central Pee A
    Yes
    That's a great idea I may just need to steal it :D
