CB problems... any ideas
Discussion in 'Audio & Video' started by uscg2008, Oct 29, 2012.
  1. Nov 10, 2012 at 6:13 AM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    Your HIDs are in a harness right? Which means that ground is goes off to somewhere else in The truck. I would look into terminating the ground at the light or as short as possible. Might be the issue since I doubt the truck was designed with HIDs in mind.
  2. Nov 10, 2012 at 6:18 AM
    jdk52
    jdk52 Bro do you even 'Merica?
    Utah
    11 SR5
    3 inch OME lift kit, rear diff breather mod, cb install, sliders, brute force fab front end.
    this may be a dumb question since I browsed through this and I've never hooked up HIDs..your besides the battery, what do your HIDs and CB share as far as wiring?
  3. Nov 10, 2012 at 6:19 AM
    jdk52
    Utah
    11 SR5
    damn..I need to work on my timing.
  4. Nov 10, 2012 at 6:43 AM
    brian
    Elizabeth City, NC
  5. Nov 10, 2012 at 6:21 PM
    uscg2008
    uscg2008 [OP] Well-Known Member
    coby
    San Diego, CA originally from Huntington Beach, CA
    06 trd sr5 four door 4x4
    CLICK ON SIGNATURE>>>>
    my ground is at the same spot that the battery ground is hooked to on the inside of the engine bay on the side next to the battery. would it help to have the ground from the HIDs straight to the battery ground terminal?
    the only thing that they both share is the power side of the battery
  6. Nov 11, 2012 at 7:38 AM
    jdk52
    Utah
    11 SR5
    if they are sharing the same ground, you're probably going to get feed back. Where is your antenna mounted?
  7. Nov 11, 2012 at 10:12 AM
    4x4Runner
    4x4Runner Sam’s gone, man. Moderator
    Drunken Sailor
    Not north, not south, not west, mostly east
    1WD
    nuttin fancy
    I'd recommend a power filter or something I'm going to try to eliminate the interference I have. I'm going to take the power wires out and rerun it with COAX. I'll probably work on that tomorrow and let everyone know how it turns out.
  8. Nov 11, 2012 at 4:43 PM
    uscg2008
    coby
    my antenna is mounted on the back of my truck on a metal bracket mounted straight to the metal spot between the tail gate and the side of the bed. i think im gana run my ground for my cb and lights straight to the negative side of my battery and see if that helps at all.
    where would i get one of these so called power filters?
  9. Nov 11, 2012 at 5:17 PM
    LUSETACO
    LUSETACO Here for the Taco Pron
    Dennis
    South Central Pee A
    2005 PIMP MOBILE
    Yes
    Don't bother, they don't work.
  10. Nov 11, 2012 at 5:19 PM
    uscg2008
    coby
    roger roger. gana ground everything out better tomorrow
  11. Nov 12, 2012 at 6:06 PM
    uscg2008
    coby
    so even grounding all the HIDs straight to the battery terminal still a shit ton of interference.
    anyone have any ideas??????
  12. Nov 12, 2012 at 6:36 PM
    LUSETACO
    Dennis
    South Central Pee A
    2005 PIMP MOBILE
    Yes
    What about the ground on the CB?
  13. Nov 12, 2012 at 6:56 PM
    jdk52
    Utah
    11 SR5
    Run the ground to the antenna coax (I have mine right where it hooks into the CB). And just playing dumb here but, have you disconnected the HIDs?
  14. Nov 12, 2012 at 7:06 PM
    Large
    Large Red
    As long as the connection is good. & you are using the proper rates wore there should be no issues. I would interlace all the grounds though to a clean spot on your frame.
  15. Nov 13, 2012 at 10:57 AM
    #35
    uscg2008
    coby
    i moved it from inside the cab to straight to the negative side of the battery.
    ya i have disconnected the hids and turned on the cb and no interference. im only getting it when i turn the HIDs on. do you have any pics of your ground set up?
    i tried to see if doing that would change anything and it didnt. i ran all my grounds for the HIDs and the CB to the negative side of the battery and it is exactly the same amount. no change at all. :confused:
  16. Nov 13, 2012 at 11:07 AM
    #36
    jdk52
    Utah
    11 SR5
    Let me take some tonight and I'll post them.
  17. Nov 13, 2012 at 11:17 AM
    #37
    SoCaltaco65
    SoCaltaco65 Well-Known Member
    2011 DCSB 4x4 Offroad TRD
    Your best bet is direct to the battery, run a larger then needed quality multi multi stranded wire, I have a full coverage Ham radio in the truck that is very sensitive , I have a few small engine on issues but nothing else. Likewise Pyramid makes an inexpensive power line filter that I have used in the past that actually works.
    On another note make sure your coax is not running in parallel with a power source wire, always cross over as perpendicular as possible.
    http://www.bing.com/images/search?q...B04B5CAC78CE44D53322739FE7F17771F9E37&first=1
  18. Nov 13, 2012 at 11:20 AM
    #38
    Bobbb
    Bobbb "Rumors of Bob, but never Bob. It is Bob, right?"
    Bob
    Bob
    Bob
    Tundra TRD/OR
    I assume the only ground on your CB is from the wiring harness correct? If so, you might also try running a secondary ground straight from the CB housing and see if that helps. Not saying it will, but that may be where you're picking up the noise if the radio itself is not properly internally shielded.
  19. Nov 13, 2012 at 2:06 PM
    #39
    jdk52
    Utah
    11 SR5
    that's what I did
  20. Nov 14, 2012 at 9:28 AM
    #40
    uscg2008
    coby
