CB Radio (Cobra 29) Mod & Mount in Center Console
Discussion in 'Audio & Video' started by DDD, Aug 25, 2009.
  1. Sep 30, 2015 at 4:05 PM
    #101
    Coorsdudex24
    Coorsdudex24 Member
    casey
    magnetic grey 2015 tacoma off road
    3" lift, 33" toyo RT'S on 17" black rhino wheels.
    DDD what is that wire you used with the blue shield around it? Ive been looking for it but cannot find it so i can do this..also what guage is it?? Or what is best to use do ya think..ive never soldered before and have talked to a few big cb guys and one said to be careful to not creat any defects or something that will creat a loss of signal or signal strength..
  2. Nov 27, 2015 at 6:32 PM
    #102
    Elevated
    Elevated Well-Known Member
    Sergey
    Tracy, CA
    97 Tacoma Extended Cab. 3.4L
    Original Tacoma: 6" lift, air bags in the rear, 17x9.5 XD Series rims w/ 35" Cooper STT Pro tires. Body Armor rear bumper with swing arm tire mount, TRD Exhaust, URD True Cold Air intake, TRD Front Brakes, RIGID INDUSTRIES grill and LED bar installed in it, LED Rear Lights, TracRack rack system, tool box. Sold the truck. Bought 2016 ram 2500 Laramie diesel. (7/2016) Picked up 97 Tacoma 4x4 Extended Cab 3.4L. Building motor now. (8/2017)
    Nice! I just mounted mine in the upper console area. Had to fab up mounts and delete overhead lighting, but it looks good, and isn't in the way.
    Chipskip likes this.
  3. Nov 28, 2015 at 3:49 PM
    #103
    DDD
    DDD [OP] Shine bright like a hymen
    Derek
    Santa Clarita, CA
    It's just Cat5 Ethernet cable. It comes in any color. Sometimes called UTP or unshielded twisted pairs. There is 8 solid copper wires in the cable. It's probably not the best for this application but I had a lot of it so I tried it and it worked.
    I think the wires between the mic and the circuit board should be a larger gauge but it's working as is for me.
  4. Nov 29, 2016 at 10:38 AM
    #104
    Spencer97TJ
    Spencer97TJ Well-Known Member
    Spence
    CT
    stock
    Do you think my 2012 DC Has this same hole? I could go look lol, but it's raining :)
  5. Dec 10, 2018 at 10:48 AM
    #105
    tacoma.jpg Well-Known Member
    Colorado
    2018 TRD OR Access Cab
    Matte Silver Metallic Vinyl Wrap 2.5" Icon Stage 3 Total Chaos UCA's Rear AAL + Shims 17" Jet Black SCS Ray 10's 285/75/17 Cooper's RCI Offroad Bed Cage RCI Offroad Skid Plates Decked Drawer System C4 Fabrication DOM Welded Sliders Nitro 4.88 Gears ARB Front Air Locker (Not hooked up yet) PIAA SMR 520 6" Lights (Hidden Behind Grill) Prinsu Access Cab Roof Rack
    Hey! Just seeing this thread for the first time, but I love the idea. I was trying to figure out a way to split the cb head and body for my install as well. Did you consider adding connectors to the wire ends so if you ever needed to take it out to repair you could quickly just disconnect it all?
