cb radio
Discussion in 'Southern California' started by streetcustoms, Jan 19, 2010.
  1. Jan 19, 2010 at 3:17 PM
    streetcustoms
    streetcustoms [OP] Well-Known Member
    tujunga , ca
    prerunner sr5 trd off road
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/74196-my-build-so-far.html
    what else would i need besides the cb radio and the antenna and dos anyone have a writeup on how to install I've been searching but cant find any
  2. Jan 19, 2010 at 3:28 PM
    Re8elmonk0341
    Re8elmonk0341 "Kill BABIES"
    m0nk
    Skiatook, Oklahoma
    '17 Silver Tacoma SR 4x4
    I think I posted a thread on here on how to install a CB. I found a video on youtube
  3. Jan 19, 2010 at 3:41 PM
    streetcustoms
    tujunga , ca
    can you gimmie the link i couldnt find it
  4. Jan 19, 2010 at 3:44 PM
    MyToyTaco
    MyToyTaco ╒╪╕
    Nick
    wenatchee, wa
    09 DCLB 4x4
    what kind of equipment did you get?
  5. Jan 19, 2010 at 3:44 PM
    mreimann
    mreimann Well-Known Member
    Denver, CO
    '15 double cab Limited
    Icon C/O, Fox 2.0, All Pro Expo 2.0 leafs, Total Chaos UCA's, Airflow snorkel, Custom Built Bed Rack, Pelfrey aluminum front bumper and IFS skid, All Pro aluminum rear bumper, SmittyBuilt winch. RTT
    you'll also need a coax cable to run from the antenna to the radio.....not sure if when you said "antenna" you meant the cable also?
    but you'll also want to get an SWR meter, thats what you use to tune the antenna so it broadcasts better
  6. Jan 19, 2010 at 3:45 PM
    streetcustoms
    tujunga , ca
    i havent gotten it yet i wanna get one but im stuck between cb radio and light bar or icon reservoir rear shocks
  7. Jan 19, 2010 at 3:46 PM
    m771401
    m771401 Well-Known Member
    Go to Google and type the following
    Code:
    site:http://www.tacomaworld.com/forum "cb radio"
    Or just click this link
    Hope that helps... :)
  8. Jan 19, 2010 at 3:47 PM
    MyToyTaco
    MyToyTaco ╒╪╕
    Nick
    wenatchee, wa
    09 DCLB 4x4
    what kind of antenna you get depends on installation. If you get a magnet mount, it's pretty much plug & play. (minus calibration)
    I use a magnet mount w/ my CB so I can take the stuff out of my truck when im not using it (which i rarely do)
  9. Jan 19, 2010 at 3:50 PM
    streetcustoms
    tujunga , ca
    anyone know where they have kits that i can get the cb magnetic antenna and everything else all at once
  10. Jan 19, 2010 at 3:52 PM
    MyToyTaco
    MyToyTaco ╒╪╕
    Nick
    wenatchee, wa
    09 DCLB 4x4
    Amazon.com, radio shack, etc
    i dont know if you can get it all "in a package". Just make sure you get the cb radio, and antenna, and a coax (if it's not attached to the antenna).
  11. Jan 19, 2010 at 3:53 PM
    MyToyTaco
    MyToyTaco ╒╪╕
    Nick
    wenatchee, wa
    09 DCLB 4x4
    I'm using an old ass CB that's been in my dads garage for a billion years, and i bought a new antenna from radio shack. the combo works fine.
  12. Jan 19, 2010 at 3:58 PM
    Incognito
    Incognito No better friend, no worse enemy
    VA
    2012 Pyrite AC TRD OR
    Spacer lift, bumper stickers, ejector seat, etc.
    Not to hijack... But any ideas on how to mount without drilling into the plastic?
  13. Jan 19, 2010 at 3:59 PM
    MyToyTaco
    MyToyTaco ╒╪╕
    Nick
    wenatchee, wa
    09 DCLB 4x4
    you can use the bedrail system to make a mount
  14. Jan 19, 2010 at 4:02 PM
    Afwrestler1986
    Afwrestler1986 Well-Known Member
    Johnstown, NY
    01 trd 4X4 ex cab manual
    Gray wire, Some lights in the bed area, and some character marks throughout.
    Ahhh, still in the NO DRILL phase. Do you want it permanent or removable?
  15. Jan 19, 2010 at 4:10 PM
    xodeuce
    xodeuce mmmmmmbourbon.
    Alabama
    2004 UZJ100
    lol, the no drill phase. I have a 2m / 70cm ham rig I want to put in mine. Dude at the amateur radio supply place was like "yeah man, put an NMO mount in the roof." I'd had the truck for 1 month at that point and my response was, "yeah right!" I'm going to go with something I fab for a bed rail mount. It's pretty simple. Piece of metal stock, bend 90 degrees, 2 holes in the part that will be vertical to secure it to the bed rail, and one hole in the horizontal surface to mount the antenna through. It's pretty straightforward. I've thought about using steel angle and just spraying it with rustoleum.
    Totally stole this from Silverback's build page:
    Silverback's Tacoma Evolution
  16. Jan 19, 2010 at 4:13 PM
    Incognito
    VA
    :eek:
    Would like it removable, but open to permanent if need be.
  17. Jan 19, 2010 at 4:21 PM
    Afwrestler1986
    Johnstown, NY
    utilize your hitch receiver. or if you don't have towing package you should be able to get a ground off of the bumper towing holes.
  18. Jan 19, 2010 at 4:21 PM
    Re8elmonk0341
    m0nk
    Skiatook, Oklahoma
  19. Mar 15, 2010 at 10:18 AM
    ETAV8R
    ETAV8R Out DERP'n
    MGM 09 AC 4WD V6 TRD-OR w/ Tradesman Shell
    Just the basics
    Any suggestions on where to get a CB installed in Orange County?
