CB Radios
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kidthatsirish, Jan 30, 2008.
  1. Jan 30, 2008 at 7:00 PM
    kidthatsirish
    kidthatsirish [OP] Well-Known Member
    2006 Tacoma Access Cab, 2.7L, 4x4, Manual Transmission
    President McKinley w/KLM 203P and threw the roof antenna, ICON RXT leaf spring packs (position 2), Bilsteen 5100s, ARE Camper Shell, Pop & Lock tail gate, Dash Cam
    Ok, so after some searching I cam up empty handed.
    Does anyone have a CB radio in there tacoma? Im gonna mount one in but would like to keep as clean a look as possible.
    Any suggestions? Pics would be helpful.
  2. Jan 30, 2008 at 7:03 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    15 Lariat Sport 5.0L
    there's a few of us on here....i've got mine simply mounted on the drivers side center console by the cig lighter. here's a previous post on the discussion.....cb linky
  3. Jan 31, 2008 at 2:09 PM
    The_Hodge
    SC
    i think banshee has it
  4. Jan 31, 2008 at 3:01 PM
    kidthatsirish
    Ive decided that I will probably get a single din aftermarket install unit for and aftermarket headunit....Then, with the extra space available, I should then have plenty of room to make a very clean looking instal for a CB. Not completley sure how it will all work out, and the mic might present some problems, but overall, Im confident that it can be done.
  5. Jan 31, 2008 at 3:40 PM
    chad68
    chad68 Master Jedi Member I am...
    Chad
    In a (Toyota) van down by the river! Sonoma Cownty
    2009 4x4 reg cab. Modded with more to come
    Polished 16x8 Pro Comp 1069's 4" BS Nitto Mud Grapplers 305/70/16 Magnaflow & glasspack muffler Stainless tip K&N 63 series Aircharger Vent visors Autometer volt and dig. temp. gauge custom mounted Factory chrome rear bumper (not black factory, one) TRD pedal covers TRD skid plate Hurst T handle shift knob Rear Tint Clear bra on the sides Chrome extinguisher Icon non resi coilovers, ICON RR shocks, black seat covers. And some other crap
    The Cobra will be the easiest to install because you can just mount the unit under the seat and clip the mike wherever you want.
    I was thinking of getting one of these Cobras but where I want to mount the anttena, I would have to remove the entire bed liner to do it and it's just way to much of a hassle, at least looks like it would be to remove??? I don't want to mount it in the roof either.
    So I have a new Midland 40 channel talkie rubber antenna with weather channels too that I never use, so I'm just going to pick up a cig adapter and keep it in the glove box, until I get bored enough someday to take the bed liner crap out.
    I also have a umm export model (sounds better than illegal) mobile radio but I'd have to hack up the dash to do that, which I did to my current truck, so I'm going to use that one at home.
  6. Jan 31, 2008 at 3:51 PM
    piercedtiger
    piercedtiger Devout Atheist
    Jon
    Southern Tier, NY
    2015 F150 3.5EB SCEW 6.5ft
    What do you mean by "bed liner"? These trucks have a plastic bed.... Not a plastic covered metal bed.
  7. Jan 31, 2008 at 9:43 PM
    chad68
    Chad
    You mean those 6 really big alan or torx head bolts on the bottom don't release the plastic bottom?
    The bed itself has to be metal. The black plastic thing should be removable??
  8. Jan 31, 2008 at 10:09 PM
    natrlyst
    natrlyst Well-Known Member
    No they attach to the frame.
    It isn't the bed is made of the composite material.
    It isn't it is the bed.
    I have my yaesu operator programmable two way radio mounted next to my right leg and no it doesn't get in my way, surprisingly. I was really quite surprised it doesn't get in my way but I use it every day and it also acts as a scanner.
  9. Feb 1, 2008 at 3:26 AM
    chad68
    Chad
    Wow really. Anybody have any pics of the bed removed? Now I will have to take it out, just to see what the hell is under it LOL.
  10. Feb 1, 2008 at 5:31 AM
    piercedtiger
    Jon
    Southern Tier, NY
    No metal. That's what they mean by "composite bed". The bottom and sides are a fiberglass/plastic-like material.
    Poke your head under the truck or look through a rear wheel well. You can see the ribs on the bottom of the bed. It looks like one big injection molded piece.
    Why do you think people talk about these beds never rusting? There's nothing to rust! :laugh: (aside from the occasional nut or bolt)
  11. Feb 1, 2008 at 8:53 PM
    chad68
    Chad
    weird I'm going to check it out tonight.
  12. Feb 1, 2008 at 8:55 PM
    natrlyst
    So what did you find?
  13. Feb 1, 2008 at 9:32 PM
    natrlyst
    Thats exactly what he will find I am just wondering if he did or not...
  14. Feb 2, 2008 at 12:05 AM
    rallyandbosox
    rallyandbosox Member
    Tempe, AZ
    07 DC 4x4 SR5 TRD Sport Speedway Blue Debaged
    3" Revtek Spacers, Toytec AALs, CB Radio, Grille Guard, Fog Light, BFG ATs
    I have the Cobra Cobra 75WXST Remote CB & Weather Radio
    It was unbelievably easy to install, and it is pretty much 2" long and fits under the seat. It took 45 minutes to install and everything's on the handset. Also I have the Wilson 500 antenna...works like a charm off-road in remote areas!
  15. Feb 3, 2008 at 7:14 AM
    chad68
    Chad
    Huh, learn something new every day. The sum beech is all composite.
  16. Feb 3, 2008 at 8:35 AM
    The_Hodge
    SC
    i think the only actual metal part is the rear support right at the tailgate
