CB specifics
Discussion in '3rd Gen. Tacomas (2016-2023)' started by johntoyota, May 31, 2016.
  1. Mar 13, 2017 at 12:50 AM
    #921
    Dragonaut
    Dragonaut Well-Known Member
    Dennis
    SoCal
    2017 TRD OR AC (MGM)
    Does anyone know of a reputable CB Installer in the Los Angeles area ?
    There is a family owned shop in Montebello called CB Radio Viking that has been great to work with in the past but I'm not sure they would know how to tackle a clean install on a newer truck.
    I'm sure I could tackle the job of drilling a few strategical holes and routing the wire but I don't know enough about tuning and electronic setup in regards to the CB to have a logical plan.
    Would be nice to find a knowledgeable shop to do a turn key install.
    :sawzall:
  2. Mar 13, 2017 at 5:59 AM
    #922
    WileECoyote
    WileECoyote Well-Known Member
    SoCal
    1st Gen 4WD 2.7L RegCab
    Yaesu FT-1900R w/ 2m/70cm Comet SBB-224 antenna, Cobra 19 DX IV w/ 4ft Francis CB24 Hot Rod antenna, Uniden Bearcat BC355N 800Mhz mobile scanner (analog), an external BNC mount routed to inside the cab for a handheld fire/police scanner or HAM HT's, Rancho RS5000 front struts and rear shocks, 6in KC Daylighter (pencil beam), 15x7 Black Rock Wheels Series 942, 31x10.50R15 Firestone Destination AT, fog lights, COBRA antenna hood mount (this is used to mount the GoPro on to)
    Hmmmm, indicating ant is too short. Not much can be done in this case. Where is your ant located and can you possibly move it to a different location? Do you have a good ground contact as well? A picture MIGHT help???
    Since both readings are fairly decent though, I wouldn't really worry too much about it. I'm only saying this because all that tells me is that ch20 will be below a 2.0 as well, which is a good thing!!! :thumbsup: My guess, ch20 should be around 1.5? It's a guess, but this is based off of your readings and more to the point of what I'm getting at, you are still going to be below 2... or you SHOULD be. :thumbsup: However, with that said, I do understand that it would be nice to have the radio ant system setup to where the readings are roughly the same on about ALL channels.
    Also, "0.2"? Shouldn't there be a "1" instead of a "0"??? :notsure:
    LOL, I've been up since 1am?! :annoyed: So, my thinking isn't all too clear at the same time!!! :bored::frusty:
  3. Mar 13, 2017 at 8:02 AM
    #923
    Subway4X4
    Subway4X4 Shameless Copy Cat
    Lloyd
    NY/NJ
    05 Speedway Blue DCSB OR TRD
    Everything TW members recommend
    My first setup was a Cobra 75WXT. I had the exact cable, Firering, mount, spring, quick disconnect and antenna and my SWR was less than 1 and very balanced between channels 1 and 40.
    I switched out the Cobra for the Uniden 520XL because I didn't like the "feel" of the Cobra 75's mic/combo. It was just to big and heavy for me.
    Why would the SWR be so different when all I did was change out the head unit?
    I will check the ground again today. I'll scrape more paint at the mount point and also add a ground wire from mount to frame.
    And yes, the reading was 0.2
    Thanks!
    WileECoyote[QUOTED] likes this.
  4. Mar 13, 2017 at 8:40 AM
    #924
    WileECoyote
    SoCal
    Ohhh, okay. Yeah, agreed that just changing the head unit is a bit odd??? If I remember correctly, you no longer have the COBRA, correct? Also, admittedly I was hesitant to blame the Francis because I haven't come across with hearing a similar issue with them and I know I don't. Makes me want to recheck my setup, but, again, my shi* is scattered ALL OVER God's creation right now because my move didn't quite go as smoothly as I had hoped!!! :frusty::goingcrazy:
    Anyways, yeah, I wish I was there to be able to help troubleshoot!!! Maybe from manuf to manuf a radio will react a bit different from one another, but by THAT much is beyond me???!!! As far as I'm concerned, to a radio's output, in this case an 11m freq band, 11m is 11m... as far as from one radio to the next, the antenna is the same to all of them???!!! So, again, agreeing with you that why would it change so dramatically?! :notsure:
    Seriously wish I could help other than "text" bro!!! :(:pout:
  5. Mar 13, 2017 at 8:45 AM
    #925
    Subway4X4
    Lloyd
    NY/NJ
    Thanks.
    I'm gonna beef up the ground with a ground strap directly to frame and re-check SWR.
  6. Mar 13, 2017 at 10:01 AM
    #926
    Thyces
    Thyces 2 seater taco
    Ontario
    2009 DCLB TRD Sport
    Custom painted 6112's Fox 2.0 12" in the rear Allpro expedition leafs (garbage) Pelfreybilt aluminum single hoop front Full size pickup bedslide modded to fit Satoshi grill Ubolt flip kit Archive garage shackle flip 5" Sumo supersprings 1500lbs SPC uca's Full set RCI skid plates Weld on sliders ABS killswitch Pop'n'lock power tailgate lock Falken Wildpeak mt on FJ rims Plastidipped emblems Ebay projector headlights Smoked aftermarket tail lights High output led reverse lights Hella horns 330w 5d led bumper bar 18w spots on track facing rear (fuck you lights) B&m trans cooler Bussmann fuse box ECGS bushing Big 4 (0 gauge ofc wire) upgrade Mechman 240 amp alternator Jl 10w7 in a 1 1/2" thick wall custom box Alpine 1000w rms mono amp Group 31 AGM battery installed next to sub Yaesu 2800 Bearcat 980 in dash with wireless mic and stainless whip Diff breather mod Hilux snorkel Turbine pre filter Baja Rack low profile cab rack Rifle case on rack Shovel and axe on quick fists in bed Flat and spade shovel mounted in bed Highlift mount in bed Tech deck with magnetic ram mount Tab s7 on ram mount
    Some better pics. Also torque pro app is the shit.
    WileECoyote likes this.
  7. Mar 13, 2017 at 10:24 AM
    #927
    Subway4X4
    Lloyd
    NY/NJ
    I'm gonna do this today and see if my SWR improves.
  8. Mar 13, 2017 at 12:29 PM
    #928
    WileECoyote
    SoCal
    I like your setup. Pretty sweet! :thumbsup:
    Btw, I think you need to invest in a Trasharoo for your empty Starbucks cups :notsure::boink::rofl::rofl::rofl:
    Thyces[QUOTED] likes this.
  9. Mar 13, 2017 at 1:45 PM
    #929
    Braves95
    Braves95 Go Clemson Tigers
    David
    Central PA
    17 MGM TRD Off Road DCSB P&T 6MT
    Fab Fours Bumper Block Heater Dual Exhaust Flow Master Smittybilt 12k Winch Synthetic Rope Bed Mat Roof Rack Puddle Lights 17" Rockstar Wheels NittoTerra Grapplers Power TailGate Lock Tonneau Cover w/lights Mobtown sliders MT Remote Start Tinted Windows Front And Rear Camera BRC Competition Diff Breather Bed Step Weather tech Floor Mats TRD Pro Tail lights TRD MT Shift Knob ARB dual compressor URD short shifter Kings 2.5 OEM W/remote resi. Click adjuster.
    How did you fair? Did my or @WileECoyote advice help u out?
  10. Mar 13, 2017 at 2:13 PM
    #930
    WileECoyote
    SoCal
    I'm wondering if it is something with the GND? :notsure::confused:
    The thing that kills "ME" is that he just changed the "head unit", meaning the CB... well, shi*, you know what I mean, HAHAHAHA!!! That's what's kill'n me about all of this? If the SWR readings were fine before and just by changing the CB unit, it ALL goes to hell in a hand basket, doesn't make any sense??? o_O:confused::notsure::frusty:
  11. Mar 13, 2017 at 2:22 PM
    #931
    Braves95
    David
    Central PA
    Maybe not seating right when he puts the end on? What I would do is grab the other cb and verify. Then switch to new one and check again. Is the SWR switch on cb on SWR not on something else? If all is good. Maybe the radio is no good?
    Just have both side by side and check.
  12. Mar 13, 2017 at 4:16 PM
    #932
    WileECoyote
    SoCal
    I don't think he has the other unit anymore? That would be the best thing to do, which is why I stated the same/similar question a few posts back. Either way, I guess, we will just have to wait and see WTHeck is going on when he reports back.
    LOL, the suspense is KILLLLLING ME!!! HAHAHAHAHA!!! :rofl::rofl::rofl:
  13. Mar 13, 2017 at 4:18 PM
    #933
    WileECoyote
    SoCal
    :wave:
  14. Mar 13, 2017 at 4:22 PM
    #934
    Braves95
    David
    Central PA
    So am I. It's all I can think about. Can't concentrate.
  15. Mar 13, 2017 at 4:32 PM
    #935
    WileECoyote
    SoCal
    Now THAT is what I call "professionalism"!!! HAHAHAHA!!! :rofl::rofl::rofl: I'd lose my job immediately if that was me! LMAO!!! :rofl::drool::goingcrazy::frusty::boom::lalala::hungry:
  16. Mar 13, 2017 at 7:57 PM
    #936
    Subway4X4
    Lloyd
    NY/NJ
    Sorry guys for killing ya on the wait. LOL.
    I had to do some pre-Blizzard prep around the house and with all the vehicles.
    Finally got to the antenna issue at 10PM ....
    It WAS the GROUND gents. The bolt that attached my antenna mount to my rear bedside corner was slightly loose.
    I removed the entire mount, wire brushed all contact points with my drill attachment and then re-tightened the two bolts. I'll add lock washers to the bolts at a later time.
    SWR readings are now a beautiful 1.0 (Ch 1) and 1.5 (Ch 40) and 1.2 (Ch 19)
    Thanks guys!!!!!
  17. Mar 13, 2017 at 8:09 PM
    #937
    Braves95
    David
    Central PA
    maytime, Subway4X4 and WileECoyote like this.
  18. Mar 13, 2017 at 8:26 PM
    #938
    WileECoyote
    SoCal
    :thumbsup::bananadance::cheers::drunk::dancingbacon::broccoli::jellydance::kona::headbang::rockband::yes::yay::woot::taco::humble::proposetoast::oldglory:
  19. Mar 13, 2017 at 11:45 PM
    #939
    Nexusix
    Nexusix Well-Known Member
    2017 Toyota Tacoma TRD Offroad 4x4
    The one in Montebello doesn't seem too professional, I was referred to Milo over at New Age Audio in Anaheim, I heard he has lots of experience installing CB's and HAM. Check them out too.
  20. Mar 14, 2017 at 2:14 PM
    #940
    MeefZah
    MeefZah -----------
    Mark
    Lexington, Ohio
    2020 GX460
    Deleted the Cobra 75 and reinstalled my venerable "been cross country with it" Uniden 510. The color is about a perfect match for the interior. It's small enough to not cause issues with passenger legroom. Paired with a Wilson 'Little Wil'.
    I don't normally leave the mic installed, only when I am using it.
    Flytmech likes this.
