CB specifics
Discussion in '3rd Gen. Tacomas (2016-2023)' started by johntoyota, May 31, 2016.
  1. Jul 5, 2017 at 9:26 AM
    #1061
    YDCtaco
    YDCtaco Well-Known Member
    Alexandria, VA
    2016 DCSB TRD OR 4x4-Auto
    I had it set up that way, but you also had to ground where the stud attaches to the mount, and that is what was rusting. So instead, I just took everything apart, repainted, and stuck my ground wire up where the negative part of the coax touches the mount. Essentially I'm getting the same SWR, just without the rust issues. I am just wondering what else I could do to increase it. I know its a pretty lame setup but I'd like to get at least to 1.5
    edit: Oh and there is a poly bushing/washer that prevents the wire from riding up on to the center bolt when everything is snug
  2. Jul 5, 2017 at 10:05 AM
    #1062
    Benzdriver81
    Benzdriver81 Making it fool-proof will just make a better fool
    Kevin
    PNW
    05 DCLB Sport
    I have the same radio, and I'm getting an SWR of 1.2:1.9 (my antenna is a little too short). My Uniden 505XL got 1.2:1.3 with the same antenna, so our Midlands may inherently be running a little high. :notsure:
    YDCtaco[QUOTED] likes this.
  3. Jul 5, 2017 at 10:29 AM
    #1063
    Metalhead514
    Metalhead514 Darth Taco
    Nate
    Washington State
    '16 TRD Off Road
    MBRP catback, Magnuson TVS 1900 Supercharger, Injen Evolution intake, Race Louvers RST hood vent, Avid front and rear guards and side steps, Cali raised front/ rear LED's, TRD Pro Skid plate, custom aux fuse box, Bak Flip tonneau.
    Mine is just a std. headphone jack. It is powered by the radio's internals.
  4. Jul 15, 2017 at 8:14 PM
    #1064
    blackcloud08
    blackcloud08 Well-Known Member
    WNC
    Which mount did you get? Also, do you have any mounted pics?
  5. Jul 17, 2017 at 10:49 AM
    #1065
    MikeyD.25
    MikeyD.25 Well-Known Member
    The problem is the 'FIRERING'! I would replace that with 2 spade lugs on the coax - one for the center conductor and the other for the shield (braided conductor). The shield gets grounded to the mount or the vehicle. Then try rechecking your SWR. The FIRERING has tendency to make poor contact over time and it corrodes/rusts easily. Been there, done that.
  6. Jul 17, 2017 at 10:53 AM
    #1066
    BrotherBudro
    BrotherBudro Well-Known Member
    David
    Nashville
    2017 SR5 Access Cab, V6 4X4
    Leer 100XR, Dual Battery, Dog Platform, Sleeping Platform, Ham, CB, Light Bar, Rear Lights,
    Do you have any pictures of how you would do this? I was planning on going the FireRing route but have seen some issues around here. What is the best way to get the lowest profile (right angle?) connector without the FireRing?
  7. Jul 17, 2017 at 11:01 AM
    #1067
    MikeyD.25
    That's the best I could do. The BIG lug goes to the antenna stud under the white bushing on your mount. The LITTLE lug goes to a ground point near the mount. Hope the pic is self explanatory.
  8. Jul 18, 2017 at 6:20 AM
    #1068
    Jack0928
    Jack0928 Kind of a Well-Known Member
    Jack
    Huntington Beach, CA
    2013 MGM DCSB 4x4
    IG: Jacksoverland
  9. Jul 18, 2017 at 6:22 AM
    #1069
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I don't actually have this set-up. I never got around to it.
  10. Jul 18, 2017 at 6:34 AM
    #1070
    Jack0928
    Jack
    2013 MGM DCSB 4x4
    IG: Jacksoverland
    Do you happen to know what wiring is needed for the amp? Going to order my CB today and want to make sure I account for everything, so far have the CB, Firestik, amp, outdoor speaker, COAX cable. Am I missing anything and do I need a wiring harness for the CB?
    Also do CBs have built in speakers? or do you need an external to hear people over coms?
  11. Jul 18, 2017 at 6:38 AM
    #1071
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    A mount for the antenna, and an antenna stud if the mount doesn't come with one. A stud is what connects the antenna to the Coax. To wire in the CB is just a positive and a negative, so no wiring harness needed. I just ran mine directly to the battery. You will need some basic electrical connectors, and maybe some extra wire depending where you mount the radio.
    To wire the amp, it's similar. Just a positive and a negative. It's such a small amp you can use the same guage wire that you use to wire up the CB.
    Jack0928[QUOTED] likes this.
  12. Jul 18, 2017 at 6:56 AM
    #1072
    Jack0928
    Jack
    2013 MGM DCSB 4x4
    IG: Jacksoverland
  13. Jul 18, 2017 at 6:59 AM
    #1073
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
  14. Jul 18, 2017 at 7:11 AM
    #1074
    Jack0928
    Jack
    2013 MGM DCSB 4x4
    IG: Jacksoverland
    Edited
    Approve? :bananadance:
    MikeyD.25 likes this.
  15. Jul 18, 2017 at 7:16 AM
    #1075
    Metalhead514
    Nate
    Washington State
    '16 TRD Off Road
  16. Jul 18, 2017 at 7:17 AM
    #1076
    Jack0928
    Jack
    2013 MGM DCSB 4x4
    IG: Jacksoverland
    I need the amp, looking for a very loud PA system. Without an amp its weak
    mwc273 likes this.
  17. Jul 18, 2017 at 7:17 AM
    #1077
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I approve! I have one recommendation though. I have that same exact mount on my passenger side tailgate, and the 4 screws that are holding it in tend to get loose, so I'm going to be replacing them with nuts and bolts. Other than that it looks good! Again, aside from misc. wire and electrical connectors, but those can all be bought at an autoparts store.
    Those speakers are pretty weak. He wants something much louder.
    MikeyD.25 and Jack0928[QUOTED] like this.
  18. Jul 18, 2017 at 7:20 AM
    #1078
    Jack0928
    Jack
    2013 MGM DCSB 4x4
    IG: Jacksoverland
    Are you just going to go through the taillight to secure the nuts?
  19. Jul 18, 2017 at 7:22 AM
    #1079
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Yeah, exactly! So if you can wait, a mount made for our trucks (like one that @Shmellmopwho offers) will be much more secure.
    Shmellmopwho likes this.
  20. Jul 18, 2017 at 7:29 AM
    #1080
    Jack0928
    Jack
    2013 MGM DCSB 4x4
    IG: Jacksoverland
    I cant remember but Ryan's utilizes the factory bolts right?
