CB specifics
Discussion in '3rd Gen. Tacomas (2016-2023)' started by johntoyota, May 31, 2016.
  1. Nov 14, 2017 at 2:31 AM
    #1281
    Bastek
    Bastek Average Member
    Seb
    SI NY
    '17 OR dcsb
    KDMaxP10, plastidip
    Found the problem. The antenna base is shorted out it closes the loop between the whip and the ground /base thread. Anyone have similar experience? Maybe it's intentional and I just don't know how to deal with it ( by the way there are no installation instructions provided).
    For now used a 3' firestik with a spring, mounted on nmo adapter. I was able to tune into the 2.0 Swr.
    Edit. I still have to work on grounding my hood a little bit better
    Edit: typos
  2. Nov 14, 2017 at 5:19 AM
    #1282
    DaveInDenver
    DaveInDenver Not Actually in Denver
    David
    Grand Junction
    2008 Super White TRDOR AC 6MT
    Unexceptional
    Was the base itself shorted or the antenna? The base shouldn't have any sort of shorts but antennas may appear to have a DC short depending on the design.
  3. Nov 14, 2017 at 6:07 AM
    #1283
    Bastek
    Seb
    SI NY
    '17 OR dcsb
    KDMaxP10, plastidip
    Turns out the antenna has DC Grounding... Or whatever you'd call it. So looks like the "short" has been done on purpose! This "feature" is news to me, and at this point between work, home, kids and trip coming up this weekend, I don't have time to look into it... So for now I chose a safe way with an adapter and standard fiberglass antenna.
    I would like to find out more about it, and how to tune the antenna properly, since I like the way it looks and I've read good things of it
  4. Nov 14, 2017 at 6:13 AM
    #1284
    DaveInDenver
    David
    Grand Junction
    Unexceptional
    The DC short is actually a shunt. It's put there intentionally to bleed static that builds up on the antenna, which is particularly useful for a mobile antenna. Some antennas also will appear to have a DC short due to the design of their matching network, but in this case I suspect it's just a simple shunt for static. Key here is to remember we're dealing with impedance on RF (since it's an AC), which may or may not have a DC resistance component.
  5. Nov 14, 2017 at 6:29 AM
    #1285
    Bastek
    Seb
    SI NY
    '17 OR dcsb
    KDMaxP10, plastidip
    Yeah, I'll try to remember that! Lol
    Unfortunately I have never heard of that type of a design, nor the rf impedance... I thought resistance was It! Yeah, a bit above my league, lol
    I guess I was looking for a guidance or a short answer, how to deal with that :notsure::annoyed:
    DaveInDenver[QUOTED] likes this.
  6. Nov 15, 2017 at 6:28 AM
    #1286
    JaxJim
    JaxJim Well-Known Member
    Jim
    Jacksonville, FL
    13 TRD Sport, DCSB, 4x4, JBL, NAV
    Exterior: Duratrac 265/70/17, SpiderTrax 1.25" wheel spacers, BAMF sliders, DiamondBack SE Tonneau Cover, Pop&Lock, Tail Gate guard, Bed Mat, Bullaculla Trailer Harness bracket, Front Side Windows tinted to match rear, Removed all chrome and dealer badges, Toyota OEM Roof Rack/Rails, SOS Concepts Front Recovery bracket Under Hood: Redline Tuning Quicklift Hood Struts, Foglight anytime mod, UniFilter for Secondary Air Pump Interior: Seat bell Chime disable (TechStream), WeatherTech floor liners, ImMrYo rearview mirror relocation bracket, 12v Always-on Power port in console Radios/Comms: AntennaX 14", Escort Passport MAX Radar Detector, Yaesu 2900 Ham Radio, Uniden 980SSB CB Radio, Relentless Fabrication hood antenna mount, BAMF tailgate antenna mount, FireStik 2m and CB antennas, FireRing coax
    Since the NMO adaptor and a FireStik seems to have a reasonable SWR, it can be assumed the mount and coax are fine. I'd still like to see if there is impedance on the coax and mount without an antenna and radio attached just to be sure.
    Next I'd like to see if you can borrow an NMO antenna somewhere and see if it tunes. If it does, there's something funky with your antenna.
  7. Nov 15, 2017 at 8:34 AM
    #1287
    Bastek
    Seb
    SI NY
    '17 OR dcsb
    KDMaxP10, plastidip
    I didn't have time to check it yet, I just read up some stuff and it might be issue with me and following directions. I'm supposed to cut a trip to certain length not just try to adjust within the mount.
    This is not a regular CB antenna, but then again even with regular ones sometimes the ship has to be cut down.
    If I find some time this evening, I'll try to install it
  8. Nov 15, 2017 at 10:09 PM
    #1288
    Bastek
    Seb
    SI NY
    '17 OR dcsb
    KDMaxP10, plastidip
    Short version. I'm a dumbass...:anonymous: So, I read a few things up, including a whip lenght chart provided with the antenna, and after a few cuts, I was able to bring SWR down to below 1.5. Granted, I also installed a ground strap between the hood and the body, but cutting off 2+ inches did the trick!
    Thanks for your attention and patience! Unfortunately I don't know how to measure impedance, so no info on that.
    House Forsaken and EatSleepTacos like this.
  9. Nov 16, 2017 at 4:19 AM
    #1289
    JaxJim
    Jim
    Jacksonville, FL
    Very cool you figured it out.
    Bastek[QUOTED] likes this.
  10. Nov 16, 2017 at 7:22 PM
    #1290
    Technique
    Technique Well-Known Member
    Alex
    Utah
    2017 Silver Offroad DCSB
    -285/70/17 Toyo AT3 -Tuned
    Been scrolling through all the pages with no luck....has anybody found an antenna mount for the bed that will work with the OEM bed cover? I want to mount it on the rails behind the cab..so I need to find an L bracket of sorts that will bolt to the rail then go up and over the side of the bed if that makes sense. Does anybody have any recommendation or will I need to fabricate one of my own somehow?
  11. Nov 16, 2017 at 9:49 PM
    #1291
    Bastek
    Seb
    SI NY
    '17 OR dcsb
    KDMaxP10, plastidip
    You can check this thread as well Clean VHF/CB radio installs
    If nothing there, fabricate it yourself. Try to use stainless steel, so you wouldn't have to paint the bracelet.... aand make sure to ground your bracket to the frame, since the rails are not grounded (as far as I know). Good luck!
  12. Nov 17, 2017 at 7:53 AM
    #1292
    Technique
    Alex
    Utah
    Thanks, I'll take a look in that thread.
  13. Nov 18, 2017 at 9:31 AM
    #1293
    Technique
    Alex
    Utah
    Sorry for the double post....but I"m going to wire my CB today and I'm running it directly to the battery (unless told otherwise) for no interference and to be able to use it with the vehicle off. My question is since the CB already has an inline fuse, do I need to fuse the cable again right near the battery? If so, do I remove the other inline fuse? Which size fuse would I use near the battery?
  14. Nov 18, 2017 at 10:42 AM
    #1294
    DaveInDenver
    David
    Grand Junction
    Unexceptional
    You'd want a fuse near the battery. You don't have to remove ones down the line but I would just so there's only one place to check if it's not working.
  15. Nov 19, 2017 at 3:50 PM
    #1295
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I personally didn't bother. I know best practice is to have it close to the battery, but it's a short enough run into the cab it should be fine.
  16. Nov 19, 2017 at 6:11 PM
    #1296
    Bastek
    Seb
    SI NY
    '17 OR dcsb
    KDMaxP10, plastidip
    Your truck, so it's your choice... 5 Amp fuse close to ghe battery, and leave CB's inline fuse alone, lol. That fuse close to the battery is a safety thing, in case your wire gets chafed somewhere along the way (or whatever) and creares a short. Good luck with your choice.
    You're a brave man, lol.
  17. Nov 19, 2017 at 6:12 PM
    #1297
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I like to live dangerously :D
  18. Nov 19, 2017 at 6:20 PM
    #1298
    Technique
    Alex
    Utah
    I got it wired straight to the battery for now but I will be getting a fuse for it just to be safe. PA speaker and CB installed, just need to get my antenna bracket finished up and she'll be good to go. Hopefully I'll finish that tomorrow. Here is my CB and speaker installed in the truck.
  19. Nov 20, 2017 at 5:26 AM
    #1299
    BrotherBudro
    BrotherBudro Well-Known Member
    David
    Nashville
    2017 SR5 Access Cab, V6 4X4
    Leer 100XR, Dual Battery, Dog Platform, Sleeping Platform, Ham, CB, Light Bar, Rear Lights,
    This looks good. Do you have any more pics of the radio mounting process? I plan on doing something very similar (hoping to put a different radio on the passenger's side of the console) and could use some inspiration.
  20. Nov 20, 2017 at 7:42 AM
    #1300
    Technique
    Alex
    Utah
    I don't have any other pictures, but it was pretty straight forward. I drilled a hole at the bottom of my center console, so I could run the cords down there to the antenna/battery. I used the provided bracket that came with my CB and just used two screws to mount it inside my center console. The CB mounts on the bracket with some thumb screws that came with it.
