CB specifics
Discussion in '3rd Gen. Tacomas (2016-2023)' started by johntoyota, May 31, 2016.
  1. Nov 21, 2017 at 4:55 PM
    #1301
    Flytmech
    Flytmech Well-Known Member
    Jase
    Geneva Alabama
    2016 Tacoma TRD OFFROAD 4x4
    All Pro Offroad bed rack Defender Basket OME/Dakars Total Chaos ucas C4fabrications LoPro Smittybilt 9.5 comp Uniden 520xl (tuned) CVT Mt. Shasta Black Oak 50 curve led
    Looks great! Very similar to my setup. I recommend a remote Mic jack so your mic cord doesnt get damaged by the lid. Have a remote jack on my Ham also. Cleans the cockpit up a little more . Bells CB sales them in a couple of lengthsIMG_20170217_130700.jpg
  2. Nov 23, 2017 at 8:14 PM
    #1302
    Technique
    Technique Well-Known Member
    Alex
    Utah
    2017 Silver Offroad DCSB
    -285/70/17 Toyo AT3 -Tuned
    I'll have to get me one of those so I can run my mic cord out of the center console nicely.
    Another question I have for you guys...I got everything installed but I'm not sure if my antenna is grounded 'well' or properly. I made a steel bracket that attaches to the bed rail then goes up and over the side of my bed (I have a tonneau cover). I've made sure to clean off paint where the antenna touches the bracket and also where the bolt/ground wire is connected on that bracket. I then ran the wire down to my frame, where I've made it bare for the ground to go. I tested my SWR with a spare CB that has a tester built in..and it was reading 2-3..which I've read is too high. What can I do to get that down? I plan on ordering a SWR meter here soon.
  3. Nov 23, 2017 at 8:16 PM
    #1303
    chrisrocks300
    chrisrocks300 War Eagle
    Brandon, MS
    2016 4x4 Tacoma DCSB Trd Off-road Superwhite
    Total Chaos UCA's, Raceline Raptor wheels (16x8) 4.5 BS, 285/75/16 Cooper S/T Maxx tires, Icon Stage 2 Lift Kit, Sos sliders w/ fill plates, exhaust reroute, mobtown offroad skid plates (ifs, transmission, transfer case), and diff breather mod
    Scrape more paint off, gotta get it to bare metal
    Bastek likes this.
  4. Nov 23, 2017 at 8:25 PM
    #1304
    Technique
    Alex
    Utah
    I've scraped the paint off where all my connections are already, should be good there.
  5. Nov 23, 2017 at 8:26 PM
    #1305
    chrisrocks300
    Brandon, MS
    What gauge is your ground wire
  6. Nov 23, 2017 at 8:28 PM
    #1306
    Technique
    Alex
    Utah
    I wanna say 10 or 12, is that too thin?
  7. Nov 23, 2017 at 8:29 PM
    #1307
    chrisrocks300
    Brandon, MS
    Mine is 14 and my swr is 1, mind posting a pic of the mount?
  8. Nov 23, 2017 at 8:34 PM
    #1308
    Technique
    Alex
    Utah
    Mind you I haven't cleaned up the wiring yet.
    So the top part of the mount, where the nylon washer is, there is paint still there. But under, its been cleaned where it contacts the antenna.
    Bastek and chrisrocks300 like this.
  9. Nov 23, 2017 at 8:37 PM
    #1309
    chrisrocks300
    Brandon, MS
    That looks fine, I’d wait until you had a more reliable swr meter it might be misreading
    Bastek likes this.
  10. Nov 23, 2017 at 8:38 PM
    #1310
    Technique
    Alex
    Utah
    Sounds good. Just ordered one from Amazon, will be here next week on Tuesday. Hopefully it gets a good reading. I'm not looking for perfect, but something under 2.
    chrisrocks300[QUOTED] likes this.
  11. Nov 23, 2017 at 8:39 PM
    #1311
    chrisrocks300
    Brandon, MS
    Actually I just had a thought, is the ground wire running to an unpainted bolt?
  12. Nov 23, 2017 at 8:41 PM
    #1312
    Technique
    Alex
    Utah
    Yes, same as the one you see in the picture.
  13. Nov 23, 2017 at 8:41 PM
    #1313
    chrisrocks300
    Brandon, MS
    I wouldn’t worry too much about it then
    Technique[QUOTED] likes this.
  14. Nov 23, 2017 at 8:44 PM
    #1314
    Technique
    Alex
    Utah
    Thanks for the help, man.
  15. Nov 24, 2017 at 5:09 AM
    #1315
    Flytmech
    Jase
    Geneva Alabama
    I wouldn't DO any adjustments till you get a reliable swr meter, and I wouldn't transmit If you're hitting 3's. You need to know which end of the spectrum that your swr is high on..Is Ch1 higher than Ch40? Or is Ch40 Higher than Ch 1? Here's the sight I used to tune mine. It talks loud and proud
    https://www.rightchannelradios.com/blogs/installation-guides/18330687-cb-antenna-tuning-instructions
  16. Nov 24, 2017 at 5:12 AM
    #1316
    Flytmech
    Jase
    Geneva Alabama
    This article is a.must read also. Learned a lot from thishttps://www.rightchannelradios.com/blogs/troubleshooting-guides/18473439-high-swr-troubleshooting-guide
  17. Nov 24, 2017 at 7:26 AM
    #1317
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Where's the other side of the ground wire running to? Any ground wires should run directly to the frame for the best ground.
    And don't transmit with an SWR that high because you'll fry your radio.
  18. Nov 24, 2017 at 8:03 AM
    #1318
    Technique
    Alex
    Utah
    That's where its running to, my frame.
  19. Nov 24, 2017 at 8:59 AM
    #1319
    JdevTac
    JdevTac Well-Known Member
    Josh
    MD/GA
    2nd gen
    How long is your ground wire? Like 3-4feet? Too long and it starts doing funky shit. And optimally would be flat ground strap, not insulated braided wire like you have. To ground my rail mounted antenna mount for a better SWR I took apart a leftover length of coax and removed the ground braid and flattened that out as a diy ground strap. Crimped the ends and my SWR went down to <1.5
    But bed mounted antennas can be an issue. Works for some and then some can’t get a good SWR no matter what they try. Id also check to see if you have continuity to ground from your mount to frame with a multimeter.
    EatSleepTacos likes this.
  20. Nov 24, 2017 at 11:02 AM
    #1320
    Flytmech
    Jase
    Geneva Alabama
    If your swr is 2-3, I would say your grounds are fine. Your antenna length needs adjustment.
