CB stealth install..
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 2006KJ, Mar 19, 2013.
  1. Aug 16, 2013 at 8:53 AM
    Bengland25
    Bengland25 Never Forget! 343
    Bradley
    Southern California
    09 Tacoma TRD
    MB Chaos 6 17" wheels, BF Goodrich All-Terrain TA/KO LT265-70R17, Anytime Fog Lights, Anytime Backup Camera, Bed Lights, Tailgate Lock, Light bar with 3 Hella 700FF's, Realtree Camo arm-rests, Anytime DTRL (With Switch), Blue Seas Fuse Block and Circuit Breaker, Custom Bed Light-Bar, Cobra 29 LTD Chrome, 4' Firestik, Masterlock Hitch Key Safe, Bed Storage Compartment Locks, Custom Shovel Bracket Mount, Flag Pole Mount (RED SOLO CUP FLAG!), DIY Washable Cabin Filter, URD MAF Cal., Homelink Garage Door Opener, Volant CAI w/ Ram Scoop, AeroTurbine 3030XL, URD Short Throw Shifter, Custom Satoshi, Blitzpro 21S, 2 Blitzpro 6LZ's, Blitzpro 6D, BAMF Sliders
    Hey, just picked up one of these radios and wanted to see if you'd be able to give some more information on how you mounted that plate with the connector in it. Don't want to have to go under the seat each time I plug my cb in..
  2. Aug 17, 2013 at 5:40 AM
    2006KJ
    2006KJ [OP] Well-Known Member
    Front Royal VA
    I took out the console piece that I mounted it in. Took the metal piece that has 3 holes in it. Placed it where I wanted it and traced the holes with a center punch/scribe just to scratch the plastic where they go. Drilled one screw hole. Put in that screw. Drill the other screw hole. Then drill out the large center hole and dremel it till it fit flush (hole has to be larger for the rubber grommet). Sounds complicated but very easy when your doing it
    Also where I mounted it there were plastic ridges on the back. I just cut those off with side cutters then dremeled them smooth
  3. Aug 17, 2013 at 8:11 AM
    Bengland25
    Bradley
    Southern California
    09 Tacoma TRD
    So you just have that secured in the hole with a rubber grommet? It doesn't fall out or anything?
  4. Aug 18, 2013 at 4:14 AM
    2006KJ
    Front Royal VA
    There are two small bolts that hold the metal plate in place. The wire that goes through the rubber grommet to plug in the CB is a very tight fit and is larger on the plug in end so it can't fall through
  5. Aug 18, 2013 at 8:53 PM
    Bengland25
    Bradley
    Southern California
    09 Tacoma TRD
    Alright sounds good! Thanks for the info, and if you could snap a few up close pictures of that I would appreciate it. Might get this done tomorrow. Will post pictures if I do.
  6. Jul 16, 2014 at 5:49 PM
    CowboyTaco
    CowboyTaco $20 is $20
    North Georgia
    11 TRD Sport
    Did you do an install thread? I want to mount mine in the same location.
  7. Jun 15, 2015 at 12:55 AM
    sddarkman619
    sddarkman619 Well-Known Member
    Larry
    San Diego
    2015 Tacoma Sport TRD
    None(Yet)
    Where exactly is the junction box? I'm accessing the cig lighter too but had to pull the dash apart as the place I put the junction box was hitting something and I couldn't close the dash all the way.
    The mic cable where it's mounted is nice but those are short so I'm wondering where to put the junction box.
  8. Jun 15, 2015 at 2:18 AM
    2006KJ
    Front Royal VA
    The junction box sits right in front of the cup holders. Not mounted to anything it fits in there pretty snug. If you mount the mic hook up in the same place I did that's really the only place for it to go.
  9. Jun 15, 2015 at 5:48 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Please note the OP's mount has no giant ground wire it is not centered over a ground plane and works in his opinion quite well. So much for the myth. Clean install OP nice job.
  10. Jun 15, 2015 at 6:59 AM
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    You can tune an antenna to low SWR with out a ground plane. It needs a ground but that's it. A ground plane helps as far as TX but the biggest factor in a mobile setup is ground losses as in earth ground not a ground plane. That is one reason height makes a difference. I tune multi band verticals and beams on wooden saw houses before they go on the tower, the only ground is the coax back to the meter. When you tune a CB antenna tune it to the center frequency or CH 20 if you don't the ends CH 1 and CH 40 will be off If your meter says other wise it is not a very accurate meter. It's probably safe to say most people tune it on CH 19 but if it is tuned on CH 1 I guaranty CH 40 will be higher and so will CH 19 to some extent. By the way all though a 1.1:1 match is good a 2:1 match will have little noticeable effect and will not have any effect on the radios finals.
    Ugly Betty likes this.
  11. Jun 15, 2015 at 7:12 AM
    LEX
    LEX --- --- --- - ----
    Houston, Texas
    100 Series LC
    Where can I get this plug for the antenna on the console? Can't find it.
  12. Jun 15, 2015 at 10:15 AM
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    It's not for his antenna.
  13. Jun 15, 2015 at 10:39 AM
    LEX
    Houston, Texas
    100 Series LC
    It shows how new I am to CBs. I just got a Midland 75-822 and has a similiar plug to hook up an external antenna. At least I'm pretty sure it's what it is.
  14. Jun 15, 2015 at 3:49 PM
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
  15. Jun 30, 2015 at 12:08 PM
    #35
    fake4x4
    fake4x4 Well-Known Member
    Los Angeles, California
    3rd Gen Tacoma TRD Off-Road DCSB
    Cool stuff
    Hi
    I like your setup , did you have to take out the lower dash to tap the 12v accessory outlet? I want to do a setup like yours but I was thinking if I draw power from the battery i wouldn't have to dissassemble the lower dash parts. Am I correct in thinking that?
  16. Jun 30, 2015 at 12:20 PM
    #36
    fake4x4
    Cool stuff
    I haven't taken the lower dash apart yet do just wanted to see if I could avoid that at all costs
