cb swr raped my face
Discussion in 'Audio & Video' started by SpazzyB, Jun 16, 2011.
  1. Jun 16, 2011 at 5:48 PM
    SpazzyB
    SpazzyB [OP] Master of the Prius...
    Ryen
    neuf un six
    '04.5 vw stance machine
    checked my swr readings today, instantly shot to 3 haha wtf. trimmed a 1/4" off my antenna and pretty much made no change whatsoever.
    what changes should i make?
    cb setup:
    uniden 510xl
    18ft cable from frys(probably the problem)
    4ft Vanco knock off firestik
  2. Jun 25, 2011 at 3:50 PM
    03taco
    03taco Well-Known Member
    someplace
    03 tacoma lifted 6in on 35s
    fabtech 6in lift, 35.12.50.16s,on mt classics
    ok i have a question, how do you read the swr meter, like what would a good/excelent/bad reading be pretty much new to the consept of tuning my system all help is appreciated thank you
  3. Jun 25, 2011 at 4:13 PM
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Camburgs, Methods, Vision X, BFG
    Race radio
  4. Jun 25, 2011 at 4:24 PM
    horwitzs
    horwitzs Well-Known Member
    Seth
    Dayton, WA
    TX Pro
    Supercharger, OME lift w/ LR UCAs, running boards, toolbox, extinguisher mount, skidplate, N-Fab light bar, 40" R.I. LED bar, WO seat covers, TRD intake, Weathertech mats and visors, stubby antenna, hood struts, LED interior lighting, Hella Supertones, and other stuff I'm forgetting.
    The lower the reading the better.
    When you are installing your CB, get an inexpensive meter at radio shack, it will come with instructions.
  5. Jun 25, 2011 at 6:05 PM
    03taco
    someplace
    woot woot i owe you a beer. [​IMG]
  6. Jun 25, 2011 at 6:08 PM
    03taco
    someplace
    ok one more what is the best antenna to buy? ive heard alot about the firestikII
  7. Jun 27, 2011 at 4:14 AM
    Rellik01
    Rellik01 Well-Known Member
    Craig
    Windermere, Florida
    2012 TRD Sport 4x4 White
    Bull Guard powder coated white, chrome aftermarket tail lights,Led interior lights, Factory roof rack, Bug deflector, Factory tow package, Garmin GPS, Viper 5901 alarm with auto start, Weather tech window wind deflectors, , 3" Tube steps powder coated white, CB Radio, Radio Scanner.
    Wierd thing happened to my SWR. I changed springs on my firestick from medium duty to heavy duty and my SWR went from 1.5 to 2+. Any suggestions appreciated.
  8. Jun 27, 2011 at 11:48 AM
    03taco
    someplace
    once again which antennas are the best
  9. Jun 27, 2011 at 11:56 AM
    Namyo
    Namyo -
    this...
  10. Jun 28, 2011 at 4:36 AM
    03taco
    someplace
    has anybody mounted there antenna up front with the hood channel mount? if so how well did it work out for you
  11. Jun 28, 2011 at 4:39 AM
    03taco
    someplace
    looked for a wilson superflex and the closest i could get was a k40 superflex not sure if thats a wilson brand but well see how it works
  12. Jun 28, 2011 at 4:40 AM
    Namyo
    Namyo -
    That's where mine is....I like the location but doesn't work as well as a roof mount Wilson. Maybe it's the anti or wiring....I will try to rewire and maybe a Wilson flexaroo :notsure: or cut to the chase and mount pon me roof...
  13. Jun 28, 2011 at 7:38 AM
    budd4766
    budd4766 Well-Known Member
    LaGrange, GA
    '11 Tacoma
  14. Jun 28, 2011 at 7:41 AM
    BradleyScottETC
    BradleyScottETC Class IV Category 8 Elite VIP Member (Only)
    Bradley
    Lake County, FL
    10 4.0 AC 4x4
    Running the antenna in the back corner of your bed will yield better SWR results. Getting it back away from the cab of the truck is very helpful. Also, make sure you don't have your extra coax coiled tightly- it needs to be wound in a very loose figure-8.
    Furthermore, trimming the antenna is usually for getting a uniform SWR between channels (check SWR between ch1,ch20,ch40), not for achieving good SWR on your first test. If your SWR is too high on all channels, it's time to troubleshoot your setup.
    Generally if your antenna is mounted behind the cab you should put at least 12" between the two.
  15. Jun 28, 2011 at 7:44 AM
    Matic
    Matic Locked and Lifted "02" DC TRD.
    Rich
    Greenville,sc
    1 owner 2002 TRD, SR5, DC, 2.7. Full OME suspension, STT pro's.
    OME 881 coils with OME nitrochargers shocks up front. TC UCA's OME Dakars with extra leaf in the rear. Warn 8000 winch with 80ft custom braided synth line. Custom 60ft synth extension. All pro tube bumper, Hi-lift jack, Safari Snorkel, Wilco tiregate.
    Make sure your antenna is mounted with the nylon washer/lock washer in the propper position. I went 3+ for 2 yrs without knowing this and couldn't get beyond a mile.
    An astute cb tweaker saw this, fixed it and now my swr is under .001 and tweaked and soldered it for 7 miles. nice.
  16. Jun 28, 2011 at 7:45 AM
    BradleyScottETC
    Bradley
    Lake County, FL
    10 4.0 AC 4x4
    You wouldn't be able to get 3:1 with the washers out of order. That would be an SWR of infinity because it directly shorts the antenna to ground. I'm surprised you didn't fry your radio using it like that!
  17. Jun 28, 2011 at 7:58 AM
    cc350
    cc350 Retired Member
    With an 18ft cable , it may be your problem, never never loop the wire! Looping an antenna wire will do more harm than good. You can also tune the radio yourself using the meter. Lots of info on-line to do this tweak.
  18. Jun 28, 2011 at 8:11 AM
    Matic
    Rich
    Greenville,sc
    Sure did. Ran 3+ with them being out of order. 2 diff shops looked at it and had no idea why. Took it to a 3rd in ft wayne indiana and he easily recognized the problem.
    Went thru 2 firestix and a wilson trying to figure it out.
    Finally bought an "Astatic" with tunable washers.
