CEL came on, PO420...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by memario1214, May 25, 2010.
  1. May 25, 2010 at 10:38 PM
    memario1214
    memario1214 [OP] Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    Well, check engine light came on the other day as I start the truck up to leave work and I am like WTF? Took it in and hooked it up and the machine came back with PO420 (which is catalytic O2 sensor code). So... Do I just cut the fronts out? Or what do I do here, could I actually have a problem? I have noticed no negative changes in the trucks performance since I got it.
  2. May 25, 2010 at 10:40 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    well if you end up having a bad cat, you can just get doug thorley long tube headers and delete the first 2 cats
  3. May 25, 2010 at 10:42 PM
    memario1214
    Colton
    Missoula, MT
    I am not a huge fan of the DTLT's... Simply because of the rasp that is associated with them (otherwise I would be all over it). Really wish XRunnit would hurry up and come out with something... Feck!
  4. May 26, 2010 at 7:22 AM
    ktmrider
    Junk
  5. May 26, 2010 at 7:31 AM
    98tacoma27
    Ben
    Not Beech Creek
  6. May 26, 2010 at 7:32 AM
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    you just have a bad cat, most likely, or a bad 02 sensor...if you have a bad cat, the repair costs will most likely be as much as a set of brand new DTLTs
    EDIT:
    or not...
  7. May 26, 2010 at 9:20 AM
    tacobox
    tacobox Evasive Maneuvers PMKMS
    In the mean time you could try spacing out the rear o2 sensor with a spark plug anti-fouler. They come 2 in a pack and you drill on out to 1/2 inch. Place that one on the sensor. Then screw both of them into the pipe. It slows down the flow across the sensor thus not tripping a code. You can get them at your local auto store. It's a $10 fix temperary or permanent, till you decide what you wanna do. GL
