Center (Carrier) Bearing Assembly Question
Discussion in '1st Gen. Tacomas (1995-2004)' started by wrat, Feb 21, 2014.
  1. Feb 21, 2014 at 4:15 PM
    wrat
    wrat [OP] Well-Known Member
    Wyoming
    2004 Tacoma Xcab 4x4 TRD
    My carrier bearing was going out so I decided to tackle it this evening. The problem is that after using the impact to remove the staked nut I tugged gently on the carrier bearing and the whole thing pulled straight off (no puller required). Now I have three washers (one slightly larger in diameter than the other two) and I don't know what order to put them back on since everything came out of there at once. If anyone knows the order please let me know.
    I'm pretty sure that it goes bearing, washer A, washer A, flange, washer B, nut.
    It is off this diagram that I draw that conclusion:
    http://www.villagetoyotaparts.com/s...ukey_driveline=0&ukey_trimlevel=0&modelYear=0
    It is for a 2004 Tacoma Xtra cab 4x4 V6.
