Center mount 4wd
Discussion in 'Long Travel Suspension' started by dirt designs, Dec 31, 2013.
  1. Mar 14, 2014 at 8:54 AM
    #41
    Supermoto
    Supermoto Well-Known Member
    Landon
    Fallbrook
    Looking killer man! The lower arm spread looks pretty close to the same as Mark McMillin's prerunner. That's pretty much the closest to center link I could see you getting with 4x4. His is bumped at 20", i got to ride in it a few years ago, so badass. Keep up the good work!
  2. Mar 17, 2014 at 6:08 PM
    #42
    dirt designs
    dirt designs [OP] Well-Known Member
    slo
    01 Tacoma race truck
    Only factory parts left is cab and frame rails
    Sort of. Cut out firewall+floor enough to clear engine (but try to get as much leg room as possible). Most likely itll be a steel tube structure around the engine and trans with removable sides and top aluminum pieces. A single large cover like the van is hard to actually get out when its filled with electonics, switches, and in such a tight vehicle.
    Thank you sir! Might have to get you a ride in this one so you can tell me which one is better *cough *cough
  3. Mar 17, 2014 at 7:10 PM
    #43
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    I'll ride in it and let you know. Then I'll have to ride in the other one I guess.
  4. Mar 18, 2014 at 8:40 AM
    #44
    dirt designs
    slo
    lol YUP
  5. Mar 20, 2014 at 12:04 AM
    #45
    Trifenix
    Trifenix Well-Known Member
    so cal
    99 LT 5 lug Taco
    looks awesome!
    random question..why are you recessing the engine into the firewall? 50/50 balance or clearance for the case and forward accessories?
  6. Mar 20, 2014 at 12:21 AM
    #46
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    I believe it's to allow the oil pan to clear the diff
  7. Mar 20, 2014 at 12:27 AM
    #47
    YotaOverAll
    YotaOverAll Backyard Performance
    Jessie
    Panama City, FL
    02 Prerunner SR5
    3" Toytec spacers, Bilstein 5100s in the back with add a leaf and overloads removed.
    Lawd Jesus
  8. Mar 20, 2014 at 3:35 AM
    #48
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    Yeah this. There's a reason the stock diff is offset to the side.
  9. Mar 25, 2014 at 3:55 PM
    #49
    DTFtacoma
    DTFtacoma Dezert Toy Fabrication Vendor
    Anthony
    Santa Maria, CA
    06 PreRunner D-cab
    DTF LT front & rear
    Better weight distribution.
    Hey Steve who owns this beast?
  10. Mar 25, 2014 at 4:02 PM
    #50
    kirkofwimbo
    kirkofwimbo Well-Known Member
    Clayton
    Wimberley, TX
    ‘21 Tundra SR 4x4
    Curious about the low pinion rear diff, is this to allow clearance with the trac bar? Or something else I'm missing?
  11. Mar 25, 2014 at 8:28 PM
    #51
    dirt designs
    slo
    ^^^^ This. I want the engine low. To clear the diff, i had to pull the engine back. It does also help with weight distribution so it was win win.
    Customer of mine from up north. He also owns that black work tacoma we built over the summer
    LT front and rear, with exocage+lumber rack, and flat bed
    Not sure what you mean. The solid rear axle being low pinion?
  12. Mar 25, 2014 at 8:29 PM
    #52
    dirt designs
    slo
    Some more progress. Picked up some parts from the Mint.
    Since we had such a beefy rack from Howe, we had to make a very beefy rack mount
    And good ol 20in of 4wd travel
    And first time ive used these bungs. They are a little oddball sized and need tubing 1 3/8 and 1 5/8? So did my thing with the lathe and machined the tubes to work out perfect.
  13. Mar 25, 2014 at 8:59 PM
    #53
    Supermoto
    Landon
    Fallbrook
    I think he wondering why it's not a high clearance 3rd....
    All race style 9" nodular 3rd members are not high clearance.
    The truck is looking amazing!
  14. Mar 25, 2014 at 9:26 PM
    #54
    01tacoprerunner
    01tacoprerunner 01 4WD Prerunner
    Brian
    Raleigh, NC
    01 4WD Prerunner
    Wow this truck does look amazing!!
  15. Mar 25, 2014 at 9:39 PM
    #55
    ttran
    ttran Expert Mallcrawler
    Tim
    Cary, NC
    06 DCLB Prerunner Sport
    TRD Sport Prerunner
  16. Mar 26, 2014 at 12:06 AM
    #56
    dirt designs
    slo
    Thats kinda what i was thinking, just never had anyone ask that for desert trucks (only crawlers).
    The lower pinion is what makes the gears strong. The 9in is one of the lowest pinion designs and the reason why everyone runs 9in axles in the desert for very heavy abuse.
  17. Mar 26, 2014 at 6:50 AM
    #57
    kirkofwimbo
    Clayton
    Wimberley, TX
    ‘21 Tundra SR 4x4
    Gotcha! Thanks for the info :thumbsup: Not that I plan on building a desert racer, sometimes inquiring minds just need to know lol
  18. Mar 26, 2014 at 4:52 PM
    #58
    05Aztacoma
    05Aztacoma Well-Known Member
    05 Tacoma 4x4
    This truck is going to be a beast when completed!
  19. Mar 31, 2014 at 12:35 PM
    #59
    05taco2.7
    05taco2.7 Well-Known Member
    JIMSTER
    omaha nebraska
    Soon to come
    Subbed holy shit
  20. Mar 31, 2014 at 4:24 PM
    #60
    yf19
    yf19 Well-Known Member
    Phoenix AZ
    1998 ExtraCab Limited V6
    Icon coil overs, Camburg UCA, 1" body lift, lots of trimming, Scion XB seats with Wet Okle covers, Alpine Head unit and amps with RF subs and Polk Momo in doors, and much more.
