Centering A Tacoma Front Differential
Discussion in 'Long Travel Suspension' started by blackhawke88, Sep 12, 2012.
  1. Sep 12, 2012 at 4:36 PM
    blackhawke88
    blackhawke88 [OP] wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    Hey Guys,
    I've been thinking about this for a while. I want to toy with the idea of centering the front differential up front and running center mount A-arms down the road. I have made the following considerations:
    - Engine may have to be pushed back or to the side, or even pivoted to allow room for front drive shaft to the centered diff
    - A carrier bearing can be used to change the direct of the front drive shaft as well
    - Inner A-Arm pivots need to be at the same location and distance apart as the inner CV pivot to avoid axle plunge.
    - Obviously fully custom arms would be needed, almost center mount, but inner pivots the same distance apart as the flanges on the center mounted diff
    Now, my question is, can the stock tacoma from differential be modified so only the center section is used as a centered front differential? Here's a picture to clarify:
    Let's discuss, im looking for good ideas.
  2. Sep 12, 2012 at 4:37 PM
    blackhawke88
    SGV, CA
    07 TRD Offroad
  3. Sep 12, 2012 at 4:43 PM
    DTFtacoma
    DTFtacoma Dezert Toy Fabrication Vendor
    Anthony
    Santa Maria, CA
    06 PreRunner D-cab
    DTF LT front & rear
    I think if you want to center link get rid of the taco front diff
  4. Sep 12, 2012 at 5:10 PM
    FearNothing321
    FearNothing321 You gonna eat that taco?
    Tony
    Knoxville, TN
    2019 Audi S3
    What about using a Supra diff? [​IMG]
  5. Sep 12, 2012 at 5:15 PM
    blackhawke88
    SGV, CA
    07 TRD Offroad
    putting a rear diff in the front will not be as strong. By putting a standard cut in the front, it’s ring & pinion would ride on the coast side of the gears. Basically, it is not as much gear contact as it would be in the rear.
  6. Sep 12, 2012 at 5:34 PM
    tostidos
    tostidos Well-Known Member
    Apple Valley, CA
    07 LT 6spd
    Are you planning on doing anything different with the rear? there was that jeep in the LT BS thread with a 9"(I think) up front with center mount.
  7. Sep 12, 2012 at 5:44 PM
    atvlifestyle
    atvlifestyle Well-Known Member
    Michigan
    01 trd tacoma
    supercharged with MCM front kit
    If it is a low pinion rear wouldn't you just be able to flip it and run it high pinion in the front and stay on the drive side of the gears?
  8. Sep 12, 2012 at 5:45 PM
    Defined
    Defined Well-Known Member
    mike
    southern california
    you can get by a little bit with a 2 piece driveshaft.
    im thinking custom oil pan , or have a drysump system designed for the 1gr with a high clearance pan.
    the motor isnt moving anywhere but back and that dosent help much.
    the oem diff may cost some serious coin to modify . it may look easy in theory but you might be better going with a different diff. but anything else is taller than whats in there.
    i thought about making a better 4wd lt setup for awhile now and its just not sensible or financially feesable. better to take your plans to a tube chassis, but thats just my opinion.
    good luck with the adventure
  9. Sep 12, 2012 at 5:56 PM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    Currie makes a front center diff section..used by Shannon Campbell in both his IFS KOH rig and his full time 4wd class 1 buggy.
  10. Sep 12, 2012 at 6:07 PM
    blackhawke88
    SGV, CA
    07 TRD Offroad
  11. Sep 12, 2012 at 7:13 PM
    MonkeyProof
    SoCal- SGV
    thats the one..
  12. Sep 12, 2012 at 7:17 PM
    Defined
    mike
    southern california
    spidertrax is also making a unit that going in a penhall rig
  13. Sep 12, 2012 at 7:25 PM
    RJALLDAY702
    RJALLDAY702 U MAD? OH U MAD
    RJ
    Las Vegas
    2014 Toyota 4Runner
    6" Ruff Country DBL
  14. Sep 13, 2012 at 8:52 AM
    DTFtacoma
    Anthony
    Santa Maria, CA
    06 PreRunner D-cab
    DTF LT front & rear
    This whole thread is full of win!
    I hope you/your fab guy figure this out I wanna see a 4WD center link second gen taco!!!
  15. Sep 13, 2012 at 9:26 AM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
  16. Sep 13, 2012 at 10:38 AM
    goomba
    goomba It is a Fluid Situation
    Josh
    San Antonio Fl
    96 White Ex. Cab Tacoma TRD 4X4
    3" lift Up front(Donahoe Racing ext. travel coil overs, Camburg UCA's), 1.5-2" lift in the back(aal and some billy 10" stroke short bodies), Bushwhacker Cut-Out fender flairs, 16"x10" Procomp Street locks, and 305/70 Procomp X-Terrains.
  17. Sep 13, 2012 at 10:40 AM
    98tacoma27
    Ben
    Not Beech Creek
    Awesome sauce :popcorn:
  18. Sep 13, 2012 at 11:23 AM
    Supermoto
    Supermoto Well-Known Member
    Landon
    Fallbrook
    The longer the arms the less camber change you have through travel. Making the arms longer usually makes the vehicle wider. By moving the pivots inward you can lengthen the arms without making the vehicle too wide.
  19. Sep 13, 2012 at 1:18 PM
    blackhawke88
    SGV, CA
    07 TRD Offroad
    got a really nice response from RCV on the subject:
    Looks like Currie 9" is the best choice to go with, along with RCV CVs and Axles.
    Oh, and Im not going to be doing this anytime soon, this is just out of curiosity. However, if I do decide to do something extravagant down the road to my truck, it would definitely be center mount 4x4 and links. No dirty hooker travel or twin traction beams for me :eek:
  20. Sep 13, 2012 at 2:40 PM
    tostidos
    Apple Valley, CA
    07 LT 6spd
    :D LINKS! that currie 9" is goin to be 'spensive
