Ch. 7 Bankruptcy Filed 9/6/18
Discussion in 'Pelfreybilt Off-Road' started by T4RFTMFW, Sep 8, 2018.
Thread Status:
Not open for further replies.
  1. Feb 24, 2019 at 9:00 AM
    #4181
    TWTaco
    TWTaco Well-Known Member
    Dave
    Thanks for all your effort!
  2. Feb 24, 2019 at 9:01 AM
    #4182
    kakwvu
    kakwvu Almost Heaven
    Kyle
    WV
    ‘24 JLURX
    Don’t see how it would be against anything anyways as it was publicly available before.
    I guess I’m more shocked that no one has paper / digital copies.
    Drainbung likes this.
  3. Feb 24, 2019 at 9:02 AM
    #4183
    Porter707
    Porter707 Well-Known Member
    James
    Ohio
    2020 F-250 Powerstroke
    Is time machine not working for people? I was able to pull the PDF instructions for skids off it. :notsure:
    Slashaar and Marioso like this.
  4. Feb 24, 2019 at 9:03 AM
    #4184
    TWTaco
    Dave
    No it doesn't have the the 3rd gen HC.
    kakwvu, Marioso and Porter707[QUOTED] like this.
  5. Feb 24, 2019 at 9:04 AM
    #4185
    Porter707
    James
    Ohio
    Ahh, got'cha. Bummer man.
    TWTaco[QUOTED] likes this.
  6. Feb 24, 2019 at 9:08 AM
    #4186
    kakwvu
    Kyle
    WV
    ‘24 JLURX
    There are videos on YouTube of various installs, and I can’t really imagine the instructions for cutting are vastly different given the similarities between models.
    Or checking other vendors’ instructions. I mean .. they all bolt up at the same place.
    tcjacado likes this.
  7. Feb 24, 2019 at 9:11 AM
    #4187
    eccracer104
    eccracer104 O.G. Member
    San Diego, CA
    2016 Tundra 4x4
    You can only cut your bedsides off once haha. Worth while to wait a few days and see if some measurements show up prior to cutting it.
    The 2nd gen and 3rd gen mounting instructions should be pretty damn similar, but the measurement from bedrail down are more than likely different.
  8. Feb 24, 2019 at 9:12 AM
    #4188
    TWTaco
    Dave
    I think the bedsides can be done. Its the cutting of the sheet metal under the tail lights, like on the 2nd gens i am not sure of! Did it change any from 2nd gen to 3rd gen?
    AY_ARONTRD likes this.
  9. Feb 24, 2019 at 9:14 AM
    #4189
    Marioso
    Marioso Risueno
    San diego Ca
    2007 Toyota Fj Cruiser
    Just use bondo if you cut too much lol
  10. Feb 24, 2019 at 9:33 AM
    #4190
    T4RFTMFW
    T4RFTMFW [OP] Well-Known Member
    Bondo doesn’t work like that.. it needs a structure to adhere to.
    Run a layer of duct tape first, then bondo on top. Looks just like metal when it dries, and twice as strong.
  11. Feb 24, 2019 at 9:35 AM
    #4191
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    It will never rust either.
    Slashaar and whatstcp like this.
  12. Feb 24, 2019 at 10:06 AM
    #4192
    Drainbung
    Drainbung Somedays you are the show....
    Bob
    Fallabama, NV
    10 DCLB
    TRD Fleshlight
  13. Feb 24, 2019 at 10:08 AM
    #4193
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Just make the cut low, and if you need to take more off, take more off 1/2" at a time.
  14. Feb 24, 2019 at 10:08 AM
    #4194
    Marioso
    Marioso Risueno
    San diego Ca
    I was thinking the same thing but you gotta mock up the bumper each time. Easier said than done.
  15. Feb 24, 2019 at 10:09 AM
    #4195
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    True, but not too bad with a couple friends
  16. Feb 24, 2019 at 10:21 AM
    #4196
    kakwvu
    Kyle
    WV
    ‘24 JLURX
    I’m still trying to find a friend with a spring compressor :rolleyes:
    Drainbung and My Name is Rahl like this.
  17. Feb 24, 2019 at 10:22 AM
    #4197
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Befriend @68dave as he's not very far from you
  18. Feb 24, 2019 at 11:51 AM
    #4198
    SeatSleeper
    SeatSleeper Well-Known Member
    Evan
    09 TRD off road
    3 inch toytec lift, BFG KO2, method NV
    *FOR THOSE LOOKING FOR HC REAR INSTRUCTIONS for 3rd GEN*
    I was the installer at Pelfreybilt, and am happy to help.
    Before Cutting:
    1. Remove rear bumper (if memory serves me correct it’s 5 bolts per side 17mm) and disconnect sensor harness and trailer harness.
    2. Remove rear parts of inner fender liner, keeping the front and top part of fender liner intact and completely remove fender flare on both sides.
    Cutting:
    1. TAPE OFF WITH BLUE TAPE ABOVE AND BELOW TAILIGHT. Then mark with sharpie, a line starting at 1/4inch below the tailight. All the way to the wheel well opening.
    2. Once you have your line drawn and have verified measurements cut just below the line. (Leaving room to float in the cut with a sanding wheel.)
    3. After cut is made, re-attach fender flare. Cut flare to same height as bedside.
    4. Attach bedside supports (look like duck feet) to bed with 2 12mm screws. Then drill hole in bedside under the flare where the brackets attach.
    Mounting bumper:
    1: With the help of two people lift bumper into position while someone underneath starts two bolts on each side using OEM bolts.
    2. Adjust bumper reattach harnesses for parking sensor and tag light. OEM taglights will fit on the Pelfreybilt HC rear.
    If anyone needs any additional information shoot me a PM and I’ll respond as soon as I can. I’m not by my truck right now but I’ll try and add pictures for some more reference.
    Naumoff42, JKU3000, Slashaar and 23 others like this.
  19. Feb 24, 2019 at 11:53 AM
    #4199
    My Name is Rahl
    You da real MVP!
    SeatSleeper[QUOTED] likes this.
  20. Feb 24, 2019 at 1:21 PM
    #4200
    soup222002
    soup222002 Well-Known Member
    Amelia Virginia
    2017 DCSB TRDORD
    idk how big a compressor you need but when I lifted my wifes 4runner I rented a spring compressor from advance auto to remove and install the rear coils
    kakwvu[QUOTED] likes this.
Thread Status:
