Slash's First Home 'Build' and Questions
Discussion in 'Garage / Workshop' started by Slashaar, Nov 30, 2018.
  1. Nov 30, 2018 at 5:02 PM
    Slashaar
    Slashaar [OP] Trail Limo Supreme & Certified Hole Massager
    Josh
    Kansas City, MO
    2015 Tacoma TRD-Sport DC LB
    Coastal HC Front, 6112s+650lb King Coils, JD 62 Swap + 14" Fox 2.0s
    Thread changed to home 'build'. In quotes because it's a built home, I'll just be fixing up a few things and making it better.
    Closed on December 28th, 2018! :bananadance:
    Went ahead and snagged a Lowes Card for the 5% off or the 6 months no interest.
    Things to Tackle:
    • Rear Patio: Has sunk and cracked.
    • Patio Door: Old and barely moves. Replace with something like this. (I feel like the price goes up every time I look at it...)
    • Kitchen: New cabinets, stainless steel appliances, and removing the linoleum and installing nice tile.
    • (FIXED) Upstairs Bathroom: Fix GFCI
    • Garage: Workbenches (DONE) and shelving, New Garage doors and openers, redo the drywall (It's really bad. I'll have to upload photos.), paint and seal floors and concrete walls.
    • Master Bathroom: Not sure what I'm gonna do yet. Possibly tile in a nicer shower.
    • Basement: Temporary 'T' wall, with two doors to create two separate spaces (Studio and rented bedroom). Either pull out the drop ceiling completely, raise it, or leave it. Insulate and seal where ever the drafts are coming from above the drop ceiling.
    • Basement Bathroom: COMPLETE overhaul. It's bad. Shower was done really poorly, and its all wallpaper and linoleum. Very dated.
    • Laundry Room: Renovate to be nicer. Poorly drywalled, open portions of wall where the cat could get in and get trapped in the walls. Eventually replace dated HVAC system (1988).
    • Exterior: Fill in any gaps/holes in exterior to prevent water and pest intrusion. Replace rotten fascia board. Replace all siding/soffit and gutters.
    • Attic: Install some form of entry other than tiny access in closet, and put down plywood so it can be used for long term storage.
    • Security: Door chimes, and cameras.
    • Game/Computer Room: Made a half door for air circulation and to keep cats out.
    • Master Bedroom: Fix weird hole in the closet that goes through the backside of the tub faucet in hallway bathroom...
    • And probably more to come... :bananadead:
    Currently:
    Living in for over a 3 years now, having issues with water pooling in garage. Suspected foundation issue.
    Original Post:
  2. Nov 30, 2018 at 9:03 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    I dont know a lot about it but it looks like it would be too much draw if you had anything else like you want in the panel. Basically 30 spaces would need to add up to 200amp including the welder. you arent going to get much with 20amp after the welder if that makes sense. You should run a dedicated 200amp panel for the welder then a 30-space panel for the other stuff. Others can chime in but thats a start...or at least how I'd look at it.
    Comatose and Slashaar[OP] like this.
  3. Nov 30, 2018 at 10:13 PM
    Slashaar
    Josh
    Kansas City, MO
    Yeah I didn't know if 200 amp is per circuit or max draw for the whole panel. Or if I actually need to have a 180 amp. I'm coming into this with zero knowledge, my dad(an Electrical Engineer with ~30 years exp in the trade and wired our family home when it was built in '94) will be there to help with the wire in if I don't decide to have an electrician just do it. Really depends on what one quotes for the job.
    Comatose likes this.
  4. Nov 30, 2018 at 10:36 PM
    Tom Servo
    Tom Servo Dickweed
    Thornton, CO
    2013 DCSB TRD Sport
    The actual input current at 230V for that welder is about 20 amps. You'll be fine with a 200 amp panel. The "180 amps" in the description is the welder output (at a voltage much less than 230V).
    However, just because you install a 200 amp panel doesn't mean you have a 200 amp service. The amp rating of the main breaker or main fuses and the service entrance wire size is what defines the service amps. If you have a 200 amp main and #2/0 copper or #4/0 aluminum service entrance wires, then you have a 200 amp service.
    Comatose, wilcam47 and Slashaar[OP] like this.
  5. Nov 30, 2018 at 11:13 PM
    Slashaar
    Josh
    Kansas City, MO
    Thanks. I'll have to take a look. I close Dec 31st so I was just trying to get ahead of the curve and learn what I can.
    Comatose and Tom Servo[QUOTED] like this.
  6. Dec 1, 2018 at 6:29 AM
    Martyinco
    Martyinco Well-Known Member
    Who do you think you are, some sort of “Electrical Engineer” or something?!? :boink:
    :bowdown:
    Comatose, Slashaar[OP] and wilcam47 like this.
  7. Dec 1, 2018 at 7:44 AM
    Tom Servo
    Tom Servo Dickweed
    Thornton, CO
    2013 DCSB TRD Sport
    Haha, nobody listens to me when I'm on the clock, so I thought I'd try dropping some knowledge on TW.
  8. Dec 10, 2018 at 1:09 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    As long as the Sum Total of the Electrical Load at one time is no more then your Main 200 amp breaker you will be fine.
    How often do you have all the electrical loads on at once I guess with some people it might be possible
    As a after thought I have a main 200 Amp Service with a 200 amp panel being used as a sub panel in the shop fed by a 100 amp breaker allowing for breakers for all the goodies instead of plugging and unplugging all the time
  9. Dec 31, 2018 at 3:21 PM
    Wsidr1
    Wsidr1 Well-Known Member
    Indiana
    2 x 95.5 Ext 2.7L & 3.4L A/T 4x4
    @Slashaar
    Just reading this thread today. Apparently congratulations are in order: closing TODAY! :kona:
    Slashaar[OP] likes this.
  10. Jan 2, 2019 at 1:14 PM
    Slashaar
    Josh
    Kansas City, MO
    Thanks! We actually had the date moved up and closed the 28th! Had some Taco Friends show up Saturday and got everything moved in! :burnrubber:
    Only one casualty. Had my red HF top load tool box get launched out at an f150. Paint is scuffed, parts tray bent, latch broken, but no tools lost that I could tell. I need to dig through everything and see if I lost any screw drivers. All the big stuff was there. Oh and the F150 was old and rusty and didn't have paint on its bumper anyway so I got off the hook after showing the guy there was no dents and no damage. He just got back in his truck like it never happened. :anonymous:
    Scooped it up before the light changed, then the three of us hoisted it back in the trailer and made sure it was secured properly.
    Only have a few more things to move.
    Learned today that the taco is some kinda time machine because I moved what should be enough to triple my commute to work but somehow its the same?? :notsure:
    Back to the topic at hand. Electrician was supposed to come check out the panel the 31st, but was a no show....
    Comatose and wilcam47 like this.
  11. Jan 2, 2019 at 6:26 PM
    Martyinco
    You had a sparky scheduled for New Years Eve?!?!? I know lots of sparkies, that guy was 3 sheets to the wind on the 29th, you’d be lucky if he answers his phone this Friday :rofl:
    Slashaar[QUOTED][OP] likes this.
  12. Jan 2, 2019 at 7:18 PM
    Slashaar
    Josh
    Kansas City, MO
    Yeah lol. Also found out I have a GFCI next to the Master bathroom sink with no power. :frusty:
  13. Jan 2, 2019 at 7:35 PM
    Slashaar
    Josh
    Kansas City, MO
    Think I may just turn this into my home improvement thread. I have a lot of various questions and don't want to clutter the 'Home Improvement Today' thread.
    Comatose and Martyinco like this.
  14. Jan 2, 2019 at 8:13 PM
    Martyinco
    When you do your new panel, not sure what code is in KC, but don’t let them talk you into the AFCI breakers unless you HAVE to, fucking things are overly sensitive and trip for no freaking reason :frusty:
  15. Jan 2, 2019 at 8:17 PM
    Sociopenguin
    Sociopenguin 2 Fang Engineering
    Tate
    NW MO
    DevilPenguin
    Schtuff
  16. Jan 2, 2019 at 8:29 PM
    Slashaar
    Josh
    Kansas City, MO
    Well I may be doing it DIY. Guess I better check code first!
    Welcome to the party! :fistbump:
    Comatose and Martyinco[QUOTED] like this.
  17. Jan 3, 2019 at 5:22 AM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    I hope you aren’t hiring the no show electrician.
    There are certain like unforgivable acts IMO that totally show a persons level of professionalism (or lack thereof). That is one.
    I’m glad you made a thread on this. The house you bought would scare the shit out of me and I’m fairly handy. I’m really excited to see the transformation. :popcorn:
    I’m in to learn a few things.
    shakerhood, Slashaar[OP] and wilcam47 like this.
  18. Jan 3, 2019 at 8:06 AM
    wilcam47
    Will
    Bourbon state
    only thing missing ;)
    might check the bathroom nearest the master or all the other GFCI's it might just be tripped. Our house they wired the spare and master bath outlets together with GFCI's, if the spare gets popped the master goes out.
    Clayfri77 and TK-422 like this.
  19. Jan 3, 2019 at 1:07 PM
    Slashaar
    Josh
    Kansas City, MO
    :redxfall:
    I'll have to check that!
    EDIT: if that's imgur its blocked at work :/
    Comatose and wilcam47[QUOTED] like this.
  20. Jan 3, 2019 at 1:14 PM
    Slashaar
    Josh
    Kansas City, MO
    It's a solid house. I could live fine in it the way it is, but it's human nature to want more! So, upgrades are inevitable.
