Change the front bushings in your Dakars
Discussion in 'Suspension' started by GHOST SHIP, Mar 5, 2017.
  1. Mar 7, 2017 at 6:51 PM
    SoJersey
    SoJersey South Jersey Defense
    Brandon
    08302
    '12 DC Offroad
    Pelfrey Armor Baja Designs Lights 6112/Camburg/Dakar Suspension Method Wheels / BFG KO2 ARE Z-Series More coming soon...
    I just ordered Dakars and the OME bushings (for the rear eye) and upon receiving one of the leaf springs, my front bushing looks like the one in your picture already... I'm still waiting on the arrival of the other one, we'll see what that one looks like. Wish you had noticed this before I bought the OME bushing kit, I would have just ordered the wheelers kit and replaced them all. I guess I'll just order 1 set to replace the original front ones.
    bjs045 likes this.
  2. Mar 7, 2017 at 7:10 PM
    REDdawn6
    REDdawn6 Well-Known Member
    Redlands CA.
    2011 Tacoma TRD 4x4
    That is what I did.. Waiting on install
  3. Mar 7, 2017 at 7:38 PM
    yeos
    yeos OCD Member
    Moses Lake, WA
    2007 Lexus GX
    That's 89 ft/lb, not 120. I run into the same issue reading torque values on these manuals.
    DrFunker, Pportera, EDDO and 3 others like this.
  4. Mar 7, 2017 at 9:21 PM
    GHOST SHIP
    GHOST SHIP [OP] hates you.
    GHOST
    So the torque value is the last number in the group? Good thing I never use actual torque values. Haha. Still good information though. Thank you for correcting me.
    Blackout14 likes this.
  5. Mar 8, 2017 at 4:32 AM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    Look at the bottom left of the pic, foot pounds(force)
    N*m(kgf*cm, ft*lbf)
  6. Mar 8, 2017 at 7:22 AM
    yeos
    yeos OCD Member
    Moses Lake, WA
    2007 Lexus GX
    No problem. Thanks for the bushing write up. I will be working on my dakars this weekend.
  7. Mar 8, 2017 at 7:36 AM
    GHOST SHIP
    GHOST
    Thank you.
    :facepalm:
  8. Mar 16, 2017 at 2:29 PM
    heffer
    heffer Well-Known Member
    Jeff
    Los Angeles
    '15 Magnetic Grey 4X4 TRD Off Road
    Icon Extended Travel, SPC control Arms, OME Dakars, B110's
    I'm planning on doing this this weekend. Would you happen to know the size of the pipe you used for your puller is?
  9. Mar 16, 2017 at 2:53 PM
    Sandman614
    Tim
    '06 SR5 Off Road
    Do you know if the wheelers bushings(energy suspension) are the same as stock leaf(es)?
  10. Mar 16, 2017 at 2:55 PM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    Very nice write up!
    GHOST SHIP[OP] likes this.
  11. Mar 16, 2017 at 2:57 PM
    GHOST SHIP
    GHOST
    I actually don't know off hand. I got it from the remnant pile at my local shop and used what I had left over for this. I know it's bigger than 1.75 od, because i tried that too and it would contact the rubber bushing and wouldn't work as a puller.
    heffer[QUOTED] likes this.
  12. Mar 16, 2017 at 2:59 PM
    GHOST SHIP
    GHOST
    Wheeler's sources their own "house brand" bushings, not energy suspension.
    Not sure if they are a standard size, but since Dan just showed up maybe we can ask him?
    @YotaDan ?
    YotaDan likes this.
  13. Mar 16, 2017 at 3:00 PM
    GHOST SHIP
    GHOST
    Thanks Dan. :thumbsup: I originally bought all my suspension from you way back when and should've done this at that time. Chalk it up to experience.
    YotaDan[QUOTED] likes this.
  14. Mar 16, 2017 at 3:17 PM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    Depends on the bushing kit, but some are Energy and some are Daystar. Typically the bushings like the ones you got are the same for OEM springs as well, although there can be some variances in shoulder design/thickness depending on whose brand of springs they are going to be used with.
  15. Mar 16, 2017 at 3:30 PM
    #35
    Sandman614
    Tim
    '06 SR5 Off Road
    The reason I asked is because on Wheelers the grease pack says ES and I have 2 boxes of these sitting around because no one seems sells just the shackle to frame bushing. I'm also picking up a set of dakars this weekend.
  16. Mar 16, 2017 at 3:36 PM
    #36
    GHOST SHIP
    GHOST
    Might work. When you get the Dakars, try them in the rear eye and report back. I honestly don't see why aftermarket manufacturers would make them so different that they would not fit in various models. But people do strange things.
  17. Mar 16, 2017 at 3:42 PM
    #37
    GHOST SHIP
    GHOST
    I will add that one thing I found with the Wheelers bushings that I have not seen on a couple other manufacturers that I've dealt with is the bushings themselves have the grooves on the inner bushing hole. This is to accommodate adding a zerk fitting and allow grease to travel from the zerk to the inner sleeve and out to the bushing faces. Effectively allowing you to add grease everywhere you need it. If I cared more about it, I would've added a zerk fitting to the spring eye. Maybe next time I'm working on the truck, I'll look into this.
    Without those grooves, the grease would have nowhere to go even if you added a zerk fitting and the bushings would start to bulge out if you were to overgrease. @Sandman614 , check to see if the ES bushings have these.
  18. Mar 16, 2017 at 3:45 PM
    #38
    Sandman614
    Tim
    '06 SR5 Off Road
    Yea those are a common thing for poly bushings. It's not necessarily for a grease fitting. You are supposed to grease the inside and it keeps the grease from all being pushed out when installing the inner sleeve. My ES bushings have them. P/N on the inner edge of my bushing is 02P02842
  19. Mar 16, 2017 at 3:47 PM
    #39
    GHOST SHIP
    GHOST
    I've purchased some poly bushing kits from various manufacturers for fab projects and some have them, some don't. Just one thing I though was worth mentioning.
  20. Mar 16, 2017 at 3:49 PM
    #40
    Sandman614
    Tim
    '06 SR5 Off Road
    Yea, I'd say the better manufacturers have them.
