Change to Intermittent Wipers
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Willyj11, Nov 15, 2011.
  1. Nov 15, 2011 at 5:14 AM
    Willyj11
    Willyj11 [OP] New Member
    Bill
    Jacksonville, FL
    Toyota Tacoma
    I have a 2010 Toyota Tacoma that came with two speed wipers and would like to change over to Intermittent Wipers. Toyota tells me it can not be done. Does anyone know the solution? Hard for me to believe this cannot be done. Thanks
  2. Nov 15, 2011 at 5:48 AM
    wolftree
    wolftree Well-Known Member
    Rick
    Ohio
    2011 Tacoma 4x4 Regular cab automatic trans,
    Rear Leaf TSB, Bilstein 5100s, extra leaf added
    Willyj11, Yes it can be done. Here is the new Toyota switch part number 84652-02610. Price is approximately $90-100 for switch.
    There are several write ups already posted here on how to change. Do a search to find.
  3. Nov 15, 2011 at 5:51 AM
    90YotaPU
    90YotaPU The Messiah
    Union County, NJ
    1990 Toyota 4x4 (Pre-Taco)
    Aftermarket Stereo, Spidertrax Wheel Spacers, HF Air Horns, 3" Lift
    Can be done I did it on my 2010 just do as said above
  4. Nov 15, 2011 at 6:02 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    If you wanted cruise control, it's just as easy to do.
  5. Nov 16, 2011 at 3:49 AM
    rjbb2
    rjbb2 Member
    Bob
    NC
    2011 4x4
    Lighted 4x4 switch, Ipod direct adapter, Intermittent wiper, cruise control.
    Can be done. X2 2011 Base, took 15 minutes. $110 or so for part
    with shipping. (I used 2010 part...same---same 2011)
    I have part number posted in another thread if you need it.
  6. Nov 16, 2011 at 3:52 AM
    rjbb2
    rjbb2 Member
    Bob
    NC
    2011 4x4
    Agreed, cruise is almost easier to install. I think that took me 14 minutes. :D
  7. Nov 16, 2011 at 12:36 PM
    Quo Fan
    Quo Fan Well-Known Member
    Paul
    Southwest Virginia
    2017 Barcelona Red TRD Off-Road
    Nerf bars
    I did this mod to my truck today. It took me longer to get the plastic off the column than to change the switch. 2 connectors, unhook the old one, snap in the new one, connect the 2 connectors, done.
  8. Nov 16, 2011 at 1:27 PM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    Only easy on auto. Clutch switch it a PITA!
  9. Nov 17, 2011 at 2:33 AM
    rjbb2
    rjbb2 Member
    Bob
    NC
    2011 4x4
    I should have included that.
