Changed oil - TOO FULL?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Krusey1011, Dec 6, 2010.
  1. Dec 6, 2010 at 6:38 PM
    jandrews
    '09 FourDubDee TRD OR
    RP turns clear after about 30 seconds of engine idling. I know from quite a few oil changes with it.
  2. Dec 6, 2010 at 6:50 PM
    Snipe
    Snipe Well-Known Member
    Pacific NW
    08 TRD Off Road
    Just count how many empty jugs you have, that will tell you if you miscounted
  3. Dec 6, 2010 at 7:15 PM
    Krusey1011
    Krusey1011 [OP] Well-Known Member
    Kyle
    Washington
    Alright, I had just about 5 qts of oil in my drain pan so I'm going with some how some way a qrt or so didn't drain out. Either way I've spent too much time on an oil change. Weird, but problem solved.
    Thanks for the input TW :thumbsup:
  4. Dec 6, 2010 at 7:38 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    You may have 5 quarts in the pan, but does that account for the oil in the filter?
  5. Dec 6, 2010 at 8:02 PM
    Krusey1011
    Kyle
    Washington
    It should, I drained the filter into the pan. I just took out about 3/4 a quart from my truck and she's right about where she should be. When I said way over I might have exaggerated.
