Changed plugs. . . now starting problems
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacomaRXP, Aug 13, 2010.
  1. Aug 13, 2010 at 6:49 PM
    TacomaRXP
    TacomaRXP [OP] Active Member
    Bryan
    NC
    05 TRD 4x4 SR5
    K&N CAI
    67k miles i just changed my plugs. i put denso plugs back in with anti seize. this is very odd, and it only happens around 3 times a week and besides that it runs great and starts normal. when i go to crank it it will turn over around ten seconds and ill let off and crank again and it will fire. just worrying cause i couldnt get it to fire in charlotte the other day. any ideas guys??
  2. Aug 13, 2010 at 6:55 PM
    SKINUM
    SKINUM Well-Known Member
    Garry
    Va/Tn/KY border
    07 FJC
    a lot!
    Did u make sure they were gap'd properly?
  3. Aug 13, 2010 at 7:03 PM
    ToucanV13
    ToucanV13 You think I was rollin out here naked?
    San Diego and Colorado
    Infideled out TRD Sport 4X4
    285/70 Hankook AT-M, Window vents, TRD CAI, TRD Cat-back exhaust with WickedFlow can, AFE Throttle Body Spacer, Billy 5100 @ 2.5 and 1" block rear, RBP nerf bars, Halo HIDs, 20% tint up front
    ^ This Should be between .40 and .44. If oyu bought and just threw em in, they were not gapped more than likely
  4. Aug 13, 2010 at 7:15 PM
    johnny12345
    johnny12345 Well-Known Member
    vancouver island, canada
    09 tacoma SR5
    Don't plugs come pre gapped? Did you put the plug wires on the the right plugs? (firing order)
  5. Aug 13, 2010 at 7:16 PM
    moto932
    moto932 What's the matter, Colonel Sandurz? CHICKEN?
    Eric
    Dayton, Ohio
    04 TRD Off Road
    Basically stock. OME 882s, HD Dakars and nitrochrgers, TG front bumper, custom rear bumper, 4Xinnovations sliders, RAT skids, Softopper, 255/85/16 ST MAXX's on 16" steelies, 1" B.O.R.A. wheel spacers Scangaugae II, deck plate mod, grey wire mod,ECGS bushing, diff breather relocation, alarm mod, defrost w/o compressor mod, de-badged, sockmonkey beside decals.
    they say they are but most arent gapped right. i changed mine a few months back and 2 of the 6 were gapped correctly.
  6. Aug 13, 2010 at 7:20 PM
    TacomaRXP
    Bryan
    NC
    05 TRD 4x4 SR5
    K&N CAI
    yes they were all gapped at .42 and plug wires hooked up correctly. im baffled and it only does it occasionally
  7. Aug 13, 2010 at 7:27 PM
    ToucanV13
    Distributor? Cap? Had a mazda and that shit got all wet. All I needed was a new cap and rotor but it wouldn't start and on the off cahnce it did, wouldn't go over 25mph
  8. Aug 13, 2010 at 7:29 PM
    SKINUM
    Garry
    Va/Tn/KY border
    07 FJC
    a lot!
    Did u use a torque wrench, hand tighten?
  9. Aug 13, 2010 at 7:30 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    If the OP had a distributer cap, I would DEFINATLY say it is the problem. Hopefully, his truck is stock, and has the OEM coil on plug ignition....
  10. Aug 13, 2010 at 7:31 PM
    moto932
    Eric
    Dayton, Ohio
    04 TRD Off Road
    fuel pump? fuel filter?
  11. Aug 13, 2010 at 7:40 PM
    larryde09
    larryde09 Well-Known Member
    Larry
    Boston, MA
    2019 TRD Sport, White Double Cab "Yeti"
    Current: DR750S-2CH Dash Cam, USB Fast Charger in stock blank, Hondo Garage phone mount Previous: 2006 Black 2.7L 5-spd SR5 4x4 Access Cab - K&N Cold Air Intake, Modified Magnaflow Cat-back Exhaust, Altezza Tail Lights, Pop&Lock Tailgate Lock, Extang Trifecta Tonneau Cover, PIAA foglights with stock switch, DrawTite Hitch, OBX Shift Knob, Hood Protector, Vent Visors, DIY step bars, DIY Bed Lights, DIY Ground Lights, DIY Tailgate Electrical Box, Aftermarket switches in stock dash blanks, Sony Head Unit, Illuminated 4x4 switch mod
    plugs come "pre-gapped", but don't trust that, always check/adjust with a gauge. Be sure to use Dielectric grease to ensure a good connection w/ the cable/coil.
  12. Aug 13, 2010 at 10:03 PM
    tacobox
    tacobox Evasive Maneuvers PMKMS
    yeah man we have COP. haha If the plugs are gapped correctly, that's more than likely not the problem and it's probably a coincidence that it happend after a plug replacement.
    To the OP
    This has actually happen to me two or three times since I've owned my truck. It's happend before and after I replaced my plugs with denso iridiums.
    If a cam sensor, crank sensor, MFI relay, ect.... doesn't send a signal to the ecu, and or the ecu doesn't give a signal, fuel or timing (whatever is malfunctioning) will be cut and the engine will just crank and crank. The ecu need to see all ha. Personally, it's not happening enough for me to look into a cause.
    How long has your truck doing it? 3 times a week for how long?
  13. Aug 13, 2010 at 10:06 PM
    SKINUM
    Garry
    Va/Tn/KY border
    07 FJC
    a lot!
    Looks like about 3 times a week.
  14. Aug 13, 2010 at 10:13 PM
    tacobox
    I know;) it's late. I reworded it
  15. Aug 13, 2010 at 10:31 PM
    jdtemple
    jdtemple Well-Known Member
    Bay Area CA
    08 DBLCAB LB TRD Sport
    Lift & Tires, in cab power outlets, Locking Bed Boxes, K&N
    is it possible you bumped a sensor wire when working on the plugs. Go back and recheck all the stuff you touched.
  16. Aug 14, 2010 at 5:33 AM
    buddywh1
    buddywh1 Well-Known Member
    Philly PA
    07 DC SR5 4x4
    Is it possible you accidently got some of the anti-seize on any part of the ceramic insulators or coil towers? Many formulations of antiseize have powdered metal in it and can make a high-resistance short that bleeds off some of the energy, weakening the spark. Even if you thought you wiped it off some will remain in microscopic crevices and voids.
    The powdered metal will burn up in the high voltage or high temp of combustion and leave ever so tiny carbon tracks that do the same thing, forever. Only thing really is to put new plugs in.
  17. Aug 14, 2010 at 11:18 AM
    JKD
    JKD Well-Known Member
    Using too much anti-sieze can also foul the plugs if it gets onto the tip during installation.
  18. Aug 14, 2010 at 6:15 PM
    tacobox
    It's not a fouled plug and more than likely, has nothing to do with the plug install. Mine has done it before and after my plug install.
    It seems to be a communication error between a sensor or relay and the ecu. Maybe a issue with the imobilizer. Problem is its hard to chase this problem cause it doesn't happen often and when it does, the problem doesn't repeat itself. For me, I'll have to wait till it does it more frequently to diagnose it.
  19. Nov 29, 2010 at 1:25 PM
    Desert Fox
    Desert Fox New Member
    mike
    Gilbert,AZ.
    10 Prerunner OffRoad
    This is the reason I joined TW. My 2010 v6 after changing plugs at 28500 miles,now at 31k it turns over after warm about 10-15 seconds before firing. Had it to the dealer twice and they have experienced the problem and say it is within toyota specs. Tried 91 octane gas, ran lucas injector cleaner all with no change. Anyone have any ideas. Thanks
  20. Nov 29, 2010 at 1:33 PM
    SantaCruz'n
    SantaCruz'n Well-Known Member
    Logan
    Temecula
    Saving for the 2013
    Sounds like a user error. I would put a new set of plugs in and triple check the gap. It may cost an extra 25 bucks and a half an hour of your time, but at least there is no question in the back of your mind you made a mistake.
    I wouldnt be able to sleep until I fixed it :/ I hate issues like this.
    Sorry to hear.
