Changed to winter tires and rims
Discussion in 'Wheels & Tires' started by 709GADE, Nov 2, 2011.
  1. Nov 2, 2011 at 4:47 AM
    709GADE
    709GADE [OP] Well-Known Member
    '09 Toyota Tacoma 4X4 SR5 DC LB - Pyrite Mica
    Toyota aluminium side steps, Toyota door sill protectors Extang trifecta tonneau cover, U-Haul Class 3 hitch, Black Weathertech's, Front mudflaps trimmed 4", OEM Fog Lights, WeatherTech Bug Deflector, 13" Stubby antenna, TRD Skid Plate, ScanGaugeII, Carriage Works Billet Grille, Plasti Dipped overhead temp/compass console, LT265/75/16 Duratrac's LR C
    I just changed to my winter tires and rims (2nd set) and rotated them front to back from last winter and now I have steering wheel shake at highway speeds. Should I rotate them back to what the were to see if it corrects the problem. I haven't had this issue before and there was absolutely no shake with my summer tires and rim combo.
    Thanks
  2. Nov 2, 2011 at 4:52 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    You could try rotating them to where they were last season but it sounds like a wheel balance issue.
  3. Nov 2, 2011 at 5:01 AM
    709GADE
    I think I will try that first. If it works do I have to worry about getting them balanced...will it cause any damage?
  4. Nov 2, 2011 at 6:01 AM
    Simon's Mom
    Judy or Jude :)
    NEK Island Pond VT
    24 Tundra Trd Sport former 13 TRD OR
    Stock for now
    You may not have felt the imbalance in the back when it was mounted there. Did you check the lugs nuts? Not trying to ask a stupid question but maybe forgot that wheel? What speed is the shake?
    Whenever I did my winter swap over, the tires always felt weird for the first hundred miles or so verses the non-winters. Once they set, it was good to go.
  5. Nov 2, 2011 at 6:34 AM
    709GADE
    Lug nuts are all torqued to spec, shake is around 65 mph. I've only driven about 80 miles since the change over, maybe I'll give it a bit more time to see if the shaking goes away.
    Thanks
  6. Nov 2, 2011 at 7:03 AM
    Simon's Mom
    Judy or Jude :)
    NEK Island Pond VT
    Stock for now
    you are welcome.
    I was having a shake at 65 (not winter tires) & was told it was a balance issue. The tire company tried to put the tire on the back & now feel the shake in the seat.
    Am going to Toyota tomorrow to have it them all rebalanced & tire checked. The tire shop was no help. Good luck with your tire problem as well.
  7. Nov 2, 2011 at 7:15 AM
    709GADE
    Thanks and hope you have good luck too :)
  8. Nov 29, 2011 at 6:38 AM
    709GADE
    Wheels balanced yesterday and everything is back to normal!!
