changing brake pads???
Discussion in '1st Gen. Tacomas (1995-2004)' started by pinktaco808, Aug 12, 2010.
  1. Aug 12, 2010 at 6:55 AM
    pinktaco808
    pinktaco808 [OP] Hot Steppa
    how easy is it???
  2. Aug 12, 2010 at 6:57 AM
    98tacoma27
    Ben
    Not Beech Creek
    Very easy.
  3. Aug 12, 2010 at 6:58 AM
    98tacoma27
    Ben
    Not Beech Creek
  4. Aug 12, 2010 at 7:00 AM
    jester156
    jester156 Well-Known Member
    Cumberland, RI
    2021 GMC Sierra AT4. 3.0l Duramax
    toughest part I found on my 96 was getting the retaining pin out. it was rusted, pitted and lightly bent so it never wanted to come out well. the rest is pretty straight forward.
  5. Aug 12, 2010 at 7:17 AM
    LoudDog
    LoudDog Active Member
    Washington
    2005 Tacoma 4x4 Double Cab
    K&N CAI, NWOR HD Rear Leaf Springs
    Simple. Just put it all back together the way it was and bleed the brakes when done.
  6. Aug 12, 2010 at 7:43 AM
    Space Wrangler
    Space Wrangler Well-Known Member
    JCT
    Ga
    04 DC 4x4
    04 Tacoma 4x4 Double Cab SAW 2.0's Alcan's Ion 171 wheels 15x8 (-27mm bs) 32" BFG AT's
    i've never lost any fluid when changing pads. ....i just remove a little bit from the reservoir before i push the calipers back. ...no need to bleed!
  7. Aug 12, 2010 at 8:22 AM
    nelson18matt
    nelson18matt Well-Known Member
    Goodyear, Arizona
    2004 Long Travel Tacoma
    *SOLD*
  8. Aug 12, 2010 at 9:50 AM
    wolfgang123
    wolfgang123 Well-Known Member
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
  9. Aug 12, 2010 at 10:54 PM
    pinktaco808
    thanks everyone
  10. Aug 15, 2010 at 2:42 PM
    LoudDog
    Washington
    I mostly bleed them because i'm there, it's easy to do while there, and it's a good idea. And it prevents that first press of the pedal with no brakes:eek:
  11. Aug 15, 2010 at 3:35 PM
    Barnone
    Barnone Guest
    Good time to change the fluid while you are there.
  12. Aug 15, 2010 at 3:43 PM
    mattleegee
    mattleegee Well-Known Member
    Tacoma, WA
    2020 TRD PRO 6sp
    you guys turning your rotors also?
  13. Aug 15, 2010 at 4:02 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    any time you are changing pads...its a good time to get the rotors turned, because of them already being cut, and new pads need a good clean surface to bed into.
  14. Aug 15, 2010 at 7:44 PM
    RattleTractor
    RattleTractor Lube: It's the key to penetration.
    Harry
    VT
    '04 Unicorn Tacoma
    1KZ-TE Diesel, GFC, Pizza cutters, Dorkel
    I would agree...except I didn't do it when I put new pads on about 6 weeks ago and it seems to be just fine.
  15. Aug 15, 2010 at 11:19 PM
    pinktaco808
    cant you clean it yourself
  16. Aug 16, 2010 at 6:18 AM
    LoudDog
    Washington
    I stopped getting the rotors turned awhile back. I don't unless there are some pretty good grooves on there. The new pads will form to the rotors pretty quickly if the rotor isn't too bad. Plus, I don't like taking material off of there if I don't have to.
  17. Aug 16, 2010 at 2:38 PM
    tacoman101
    tacoman101 Well-Known Member
    scott
    vermont
    2001 Tacoma sr5 xtra cab 4wd
    blue led headlights, 285/75/16 grabber AT2's, custom pedals, custom shifter, flowmaster 40 series muffler, bedlinered fender flares, 2.5" lift kit via shackles and spacers, custom exhaust out the back, chrome exhaust tip, and Herculined bed, Weathertech floormats, Cabelas Trail Gear Camo Seat Covers ... Nice thing was I got the truck for $4000
    these days its cheaper and better to just buy new rotors with your pads. Sometimes when rotors get turned brake pulsation comes about
  18. Aug 16, 2010 at 7:33 PM
    shampoop
    shampoop Well-Known Member
    southwest WA
    08 tacoma extracab v6 auto trd offroad 4x4
    pads are very easy to do. if your truck has quality rotors and they are able to be turned, do it. if you have the cheapest rotors on the market on your truck, scrap them.
  19. Aug 16, 2010 at 9:53 PM
    pinktaco808
    i have stocks
