Changing Diff Fluid ?'s and i read all the other posts
Discussion in '4 Cylinder' started by okitaco, Jun 27, 2010.
  1. Jun 27, 2010 at 2:40 PM
    okitaco
    okitaco [OP] Member
    oak island nc
    I just got my first Tacoma, 96 2.7 4x4 reg cab - just turned 237k this morning. Im going to change the diff fluid in the front and rear tomm and ive read all the posts on here and im somewhat thoroughly confused, but this is what ive gathered. - dont use syn gear oil in the rear, but maybe in the front? use lsd additive in the rear? but is my 96 limited slip?
    so basically should i be using an additive or not? and should i use synthetic in the front diff? and does additive go in the front? thanks in advance.
  2. Jun 27, 2010 at 5:05 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    You dont have an LS Diff. You can use synthetic front and rear without addative.
  3. Jun 27, 2010 at 5:13 PM
    okitaco
    okitaco [OP] Member
    oak island nc
    thanks alot, do you recommend using the synthetic or not?
    also in that motor with all the miles, would you use 5w30 synthetic or 5w30 with lucas oil stabilizer??
  4. Jun 27, 2010 at 5:19 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Do not add any addatives to the motor oil. regular 5w-30 synthetic is fine.
  5. Jun 27, 2010 at 5:34 PM
    okitaco
    okitaco [OP] Member
    oak island nc
    thanks again. well i guess i can tell you now, the guy at advance recommended that i go with 10w 30 valvoline max life syn blend and the lucas oil stabilizer, so thats what was put in it. it may be me just being nervous but i think the motor feels a little more sluggish, so im guessing that your going to recommend draining that eh?
  6. Jun 27, 2010 at 5:36 PM
    derekAV
    derekAV Well-Known Member
    derek
    Humboldt
    2000 4x4 reg. cab
    if additive was that important, it would be in the oil already..
  7. Jun 27, 2010 at 6:12 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I would. Run the oil recomended, and nothing else.
  8. Jun 28, 2010 at 6:52 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Not exactly sure what you mean by this.... When you buy 'new' gear oil off the shelves...it'll say whether or not it has LSD additives in it already. But then again....I just found out that the Mobile 1 75w-90 LS doesn't have friction modifier in it. They just advertise it as being OK to use with LSD's.
  9. Jun 28, 2010 at 6:56 AM
    Janster
    Jandy
    Lancaster, PA
    Just because your engine feels sluggish...isn't necessarily because of the oil.
    Holy crap, your truck has 237K miles on it.
    I'd run some fuel injector cleaner in the gas and start working on all the other maintenance items - and maybe, just maybe...you'll get a midlife crisis out of it. But....at 237K miles, I'd be glad she's still going!!
