Changing differential fluid - A step by step "HOW TO"
Discussion in 'Technical Chat' started by brianr, Jan 21, 2009.
  1. Jan 31, 2012 at 12:17 PM
    #841
    MQQSE
    MQQSE I take naps
    MooseMan
    Palmer, Alaska
    "Stitch" & "Sumbitch"
    Have you done yours yet?
  2. Jan 31, 2012 at 12:20 PM
    #842
    Rusty 06 4x4
    Rusty 06 4x4 NBHNC
    Rusty
    West Georgia
    2006 4x4 Tacoma TRD DCSB
    nope as soon as I get taxes back it will be that.. the brakes and a few other thing..cough cough MODS Cough
  3. Jan 31, 2012 at 12:22 PM
    #843
    MQQSE
    MQQSE I take naps
    MooseMan
    Palmer, Alaska
    :D ;) Gotcha' .... "necessary preventative maintenance to my truck dear. You don't want it to fall apart on me...then I'd have to buy a new one. :rolleyes:"
  4. Jan 31, 2012 at 12:23 PM
    #844
    Rusty 06 4x4
    Rusty 06 4x4 NBHNC
    Rusty
    West Georgia
    yeah it need the Zombie TRD and the blacked out emblems and black head light mod
  5. Jan 31, 2012 at 12:24 PM
    #845
    MQQSE
    MQQSE I take naps
    MooseMan
    Palmer, Alaska
    All critical to the proper and safe operation of the vehicle. "*APPROVED*"
  6. Jan 31, 2012 at 12:46 PM
    #846
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    Correct me if I am wrong: Most gear oils these days do not require the friction modifier additive -- even the picture above of the Valvoline gear oil indicates it is for Limited Slip. This freaked me out when I did mine, but all the research I did told me that it was not necessary to add and was already contained in the oil. That said, I also read that it didn't hurt to add it. I did not add it and have had no issues.
    I also learned that there is not much benefit from synthetic, and many differential manufacturers recommend dino oil and not synthetic.
    For those of you that have tons of miles and have never changed it, I would recommend changing it, running for a few hundred miles and changing it again. I have never "flushed" a differential, but running new oil for a bit and letting it clean out the gunk would be a good idea. Then do it every 30K, especially if towing or carrying heavy loads. Same goes for the manual gearbox.
  7. Jan 31, 2012 at 8:07 PM
    #847
    clcoyle
    clcoyle Well-Known Member
    good stuff
  8. Jan 31, 2012 at 11:32 PM
    #848
    tacorescuemedic
    tacorescuemedic Member
    Eric
    Central Texas
    07 TRD 4X4 SR5
    BHLM
    Changed mine tonight-- did 2 Quarts of Valvoline 75-90 and a quart of lucas heavy duty oil stablizer.....ill let yall know how that works
  9. Feb 1, 2012 at 7:55 AM
    #849
    GP3
    GP3 Well-Known Member
    California
    4X4 TRD Off Road
    Front: stock suspension, 12" wide fiberglass fenders Rear: stock suspension, 10" wide fiberglass fenders
    If you don't have a Limited Slip rear dif, you don't need Limited Slip specific gear oil, or additive.
    You do not have a Limited Slip rear dif.
  10. Feb 1, 2012 at 7:55 AM
    #850
    Manwithoutaplan
    ID
    when doing these changes for both the diff's, transfer case and trans. does it matter whether to warmup the vehicle or not???
  11. Feb 1, 2012 at 8:30 AM
    #851
    theduck911
    theduck911 Max's Canadian Twin
    Max
    Northwestern Ontario, Canada
    Locked and Geared!
    Assuming you're talking mileage...
    15,000 for the Rear Diff (Front too if you want)
    30,000 for the transfer case (also depends how much you actually use 4WD):cool:
  12. Feb 1, 2012 at 1:26 PM
    #852
    NwiTACO
    NwiTACO Big tars, little/no bed.
    Mark
    Indiana
    05 TRD Sport
    Custom Everything, 1 Ton Axles F & R
    Warm the engine up? NO
    Warm the various gearcases? YES
    Drive it to work and change them when you get home. Being warm sure helps gear oil flow better.
  13. Feb 1, 2012 at 1:28 PM
    #853
    Manwithoutaplan
    ID
    ok cool thank you
  14. Feb 2, 2012 at 10:11 AM
    #854
    Adam Baum
    Adam Baum Well-Known Member
    PCS
    01 PreRunner SR5 debadged
    oh crap....i have never changed out the differential fluid in my 01 DC Prerunner SR5 w/ automatic transmission. It looks like I have something else to do this weekend. For some reason I thought I was not supposed to change it out because it is sealed.....am I wrong? 140,000 and counting...
  15. Feb 2, 2012 at 2:38 PM
    #855
    Manwithoutaplan
    ID
    :eek::eek::eek:
    i hope you havent done alot of water crossing with the truck
  16. Feb 2, 2012 at 3:38 PM
    #856
    Adam Baum
    PCS
    Never. It is just a city/highway truck.
  17. Feb 2, 2012 at 3:46 PM
    #857
    Manwithoutaplan
    ID
    ok good i would get on that asap. that oil is probably black as shit :/
  18. Feb 2, 2012 at 9:05 PM
    #858
    tacoman15
    tacoman15 Boobies
    Northeast Georgia
    2015 Tacoma TRD OR & 1985 SR5 4Runner
    A few quick questions...
    I have a 4x4 with standard transmission and I am thinking about changing it but I am only at 50,000 miles (I bought the truck used and have no idea if previous owner had routine maintenance done). Should I wait until 60K to change it? Also, what type of oil should I use?
  19. Feb 2, 2012 at 9:07 PM
    #859
    Manwithoutaplan
    ID
    you could change and check out my thread that i made :D tells what you need to get
    here you go man i made a thread while ago [​IMG]
    http://www.tacomaworld.com/forum/2nd...-change-5.html
  20. Feb 3, 2012 at 5:32 AM
    #860
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    If you don't know the maintenance history, change it!!!
