Changing differential fluid - A step by step "HOW TO"
Discussion in 'Technical Chat' started by brianr, Jan 21, 2009.
  1. Jul 11, 2013 at 10:17 AM
    #1381
    Jayhawker
    Jayhawker New Member
    Kansas
    stock 06
    At 60k I changed the oil in the rear on my 06 Taco. 80W-90 with a LSD additive.
    I'm 18K down the road and I noticed a chatter. So here's the question.
    More additive or drain and start over?
  2. Jul 11, 2013 at 11:26 AM
    #1382
    Gene563
    Gene563 Well-Known Member
    Eugene
    Lanoka Harbor, NJ
    08 Double Cab, LB, TRD Sport
    TRD catback exhaust, Undercover hard tonneau, Vent visors, Husky liners, customized seat covers, front license plate bracket, rear suspension TSB, Eibach springs w 5100s@0, & General Grabber AT2 (265.70.17).
    In my situation, I overfilled and syphoned some out. I didn't really notice chatter, but did experience the inside wheel spinning where it normally wouldn't.
    I added a little more additive. Also, someone here mentioned "figure 8s"; I went to an open parking lot and did a couple slow, tight, figure 8s, and gave it some more time. It seems fine now. It may just take a while to mix all the fluids properly.
  3. Jul 11, 2013 at 3:28 PM
    #1383
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    Maybe your fluid is low?
  4. Jul 15, 2013 at 1:09 PM
    #1384
    Gitmo
    Gitmo Well-Known Member
    Justin
    Couple questions before I change the diff oil front & rear as well as the t case oil..
    What should the fill and drain plug be torqued at for the front & rear? This thread says 36lb-ft for both while another thread says the front diff fill plug should be torqued at 29lb-ft and the drain plug at 48lb-ft. Doesn't say anything about the rear..
    http://www.tacomaworld.com/forum/2n...ront-diff-transfer-case-oil-change-howto.html
    So what should I torque the fill/drain plugs for the front & rear diff?
  5. Jul 15, 2013 at 1:33 PM
    #1385
    byrd
    byrd Unknown
    David
    Kansas
    '06 Access SR5 4x4 6 speed
    Manual states this:
    Front Differential: Fill Plug 29 ft-lbs Drain Plug 48 ft-lbs
    Rear Differential: Fill/Drain plugs 36 ft-lbs
    Transfer Case: Fill/Drain plugs 27 ft-lbs
    Manual Transmission: Fill/Drain plugs 27 ft-lbs
    Automatic Transmission: Filter bolts 84 in-lbs....Fluid pan bolts 65 in-lbs....Drain plug 15 ft-lbs.......Overflow plug 15 ft-lbs......Refill plug 29 ft-lbs
    Jeez, glad I don't have an automatic :goingcrazy:
  6. Jul 15, 2013 at 1:53 PM
    #1386
    Gitmo
    Justin
    I have an auto :(. Thanks for the info, though!
  7. Jul 19, 2013 at 6:12 AM
    #1387
    Sje1124
    Sje1124 Well-Known Member
    Sean
    Louisiana
    2010 DBL Cab TRD OR 4x4
    Just a few
    Need to do this soon
  8. Jul 19, 2013 at 6:15 AM
    #1388
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    115,xxx miles. Yea me too.
  9. Jul 19, 2013 at 6:16 AM
    #1389
    Sje1124
    Sean
    Louisiana
    Just a few
    I've got about 55k on mine
  10. Jul 19, 2013 at 3:52 PM
    #1390
    kingston73
    kingston73 Well-Known Member
    North eastern Ohio
    09 SR5 4.0L 4x4
    Just did mine today and have 1 question, I used 3 bottles of mobile 1 75/90 and I know the manual says it takes 2.8 qts and the generally accepted way to fill a diff is put oil in until it starts to run out BUT I put all 3 bottles in my rear diff and it still wasn't full enough for oil to start running out. I thought my drive was level but is it possible it was just tilted and not level? Basically, should I worry about adding more oil or just be satisfied that there's a bit less than 3 qts in?
  11. Jul 24, 2013 at 6:44 PM
    #1391
    Scorpo900
    Scorpo900 Well-Known Member
    luis
    So. Florida, West Palm
    good truck.
    A few
    Weld a piece of rebar for leverage, get it loose, then cut the rebar. Will be pita, but can't think of any other way...
  12. Jul 24, 2013 at 6:46 PM
    #1392
    Scorpo900
    luis
    good truck.
    A few
    I had the same issue, took a lot in like 3.7 QTS, to the bottom of the filler plug.. Weird. I drive slow anyways, but will be keeping an eye on it for any weird behavior.
  13. Jul 24, 2013 at 7:09 PM
    #1393
    TacoMan1911
    TacoMan1911 Well-Known Member
    LA
    2015 TSS DCSB Black DENALI EATER
    I have a 2008 2.7l reg cab base. Just did the rear diff fluid change with 75w90 mobil 1. Do i have a lsd? The bottle says it has lsd additive in it. is mobil 1 ok to use since a synthetic in a diff. Any help would be appreciated.
    Thanks!!
    PS - manual says 3.5qts, but took 4 full quarts til the top of the filler plug
  14. Jul 25, 2013 at 4:24 PM
    #1394
    Scorpo900
    luis
    good truck.
    A few
    Read the entire thread, it clearly explains which have the LSD diff. Also, to avoid Mobil 1 on LSD. I think you don't have an LSD , but double check by reading. :)
  15. Jul 25, 2013 at 4:31 PM
    #1395
    ImpulseRed008
    Susan
    SC
    read this http://www.tacomaworld.com/forum/te...ntial-fluid-step-step-how-70.html#post7099282
  16. Jul 25, 2013 at 5:05 PM
    #1396
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Avoid Mobile 1 on the mechanical LSD?
    Hogwash!!
  17. Jul 25, 2013 at 6:30 PM
    #1397
    quantum
    quantum Well-Known Member
    :confused:
  18. Jul 26, 2013 at 10:51 AM
    #1398
    Scorpo900
    luis
    good truck.
    A few
    Some have wrote about problems with mob 1, and gone back to conventional + friction modifier. I personally used Castrol gear with transx modifier and no problems so far, besides apparently taking in more lube than what I anticipated, I'll double check level this weekend, since I'm doing the transmission flush..
  19. Jul 26, 2013 at 11:09 AM
    #1399
    Janster
    Jandy
    Lancaster, PA
    They had problems because they didn't use enough friction modifier. The diff will grumble at you when making turns.
    The first time I did it, used about 2 bottles of FORD XL3 at 26k. A couple months ago, I changed oils again at 60k and used 1.5 bottles of XL3.
  20. Jul 26, 2013 at 11:10 AM
    #1400
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Where is the oil level? Can you stick your finger in and feel the oil close to the fill hole? I took barely over 3 qts to get it to where it was just at the bottom of the fill hole.
