Changing differential fluid - A step by step "HOW TO"
Discussion in 'Technical Chat' started by brianr, Jan 21, 2009.
  1. Jan 22, 2014 at 10:32 AM
    #1561
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    If you're finding articles documenting a change to synthetic oil causing seals to leak, check out the date of the article. It was a common issue when they first came out but modern synthetics aren't plagued by the same issues. Now, you can switch between synthetic and dino oil every other oil change and you'll be just fine.
  2. Jan 22, 2014 at 10:48 AM
    #1562
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    Good 4 U:D
  3. Jan 30, 2014 at 3:34 PM
    #1563
    aleok
    aleok Active Member
    What a great thread! I'm sure the answers in here somewhere, but can someone tell me which fluid (and additive if needed) for my 2009, 4.0, 4x4, trd sports to change the front and back? Thank you
  4. Jan 30, 2014 at 4:50 PM
    #1564
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
  5. Jan 31, 2014 at 4:36 AM
    #1565
    eaglesfn5402
    eaglesfn5402 Well-Known Member
    so just to make sure I'm clear on what I've read here about the rear diff, it takes 3QTs and Royal Purple 75w-90 synthetic gear oil can be used and I do not need LSD additive since I have a 2013 TRD Sport, correct? and for the front diff it takes 1.6Qts and the same Royal Purple oil can be used and the transfer case takes 1.1QTs and it to can be filled with Royal Purple?
  6. Jan 31, 2014 at 6:11 AM
    #1566
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    Sounds correct to me.
    Tools:
    - 10mm hex head socket for front drain and fill plugs
    - 24mm socket for rear drain and fill plugs and transfer case plugs
  7. Jan 31, 2014 at 7:51 AM
    #1567
    eaglesfn5402
    Roger that, ordering royal purple off Amazon now.
  8. Feb 9, 2014 at 4:44 PM
    #1568
    14TACO4X4
    14TACO4X4 Mmmmm... Beer
    Shawn
    Temecula
    18 RAM EcoDiesel
    Laramie
    *sigh* I've probably read 50 of these 79 pages...
    2014 TRD Sport... do I have to add the LSD additive on the '14 for the rear or not?
    My truck doesn't even have 1000 miles on it yet, but I am doing a lot of reading to get smarter for when I have to do this stuff. That way when it comes time to do it, I ain't waiting for an answer.
  9. Feb 9, 2014 at 4:53 PM
    #1569
    DryCreek
    DryCreek Well-Known Member
    Utah
    08 DCLB TRD Sport
    Pioneer AVH-X2600BT Fog Anytime Trailer Plug Relocate (bullaculla) Ride Rite Air Bags OEM Roof Rack Rearview Camera Wet Okole Seat Covers Maxpedition Holster SOS Sliders Washable Cabin Filter Access Bed Cover K&N Drop In Filter Rearview Mirror Relocate (ImMrYo)
    Crawl under and check your differential. It will say LSD if it is a limited slip diff. I believe that if you have atrac it is not a LSD. Best bet is to check it out. If it is there would be a LSD sticker by your fill plug.
  10. Feb 9, 2014 at 4:59 PM
    #1570
    14TACO4X4
    Shawn
    Temecula
    18 RAM EcoDiesel
    Laramie
    HA! Just after I posted that I went down stairs to crawl under the truck... as I said, I have the Sport and there is no LSD sticker there. While I was under there I located all the plugs I'd need to remove from both pumpkins and the xfer case. Looks easy enough.
  11. Feb 18, 2014 at 4:04 PM
    #1571
    MTopp
    MTopp Professional bear handler
    05 SR5 4x4
    trifecta tonneau, pop n' lock, Depo black bezel headlights, mb 352 wheels, 265/75r16 cooper at3s, visors, colormatched 2011 grille with raptor LEDs, much LEDs in and out Future/wanted: black valence, hood scoop, catback, CAI, 285/75r16s, OMD leaf pack mod
  12. Feb 18, 2014 at 4:20 PM
    #1572
    MTopp
    05 SR5 4x4
    With the sr5 model, I have no LSD(pretty sure) so I don't need the additive, right? Just the oil?
  13. Feb 18, 2014 at 4:54 PM
    #1573
    TACO TX
    TACO TX Well-Known Member
    Kelly
    Denison ,Texas
    2017 DC TRD Off Road 4x4(Barcelona red)
    Weather tech liners, Ranch Sierra truck cap
    I believe you would be correct. As stated above you there should be a sticker if otherwise.
  14. Feb 18, 2014 at 6:45 PM
    #1574
    Sandman614
    Tim
    '06 SR5 Off Road
    '05 sr5 no LSD = no additive, correct.
  15. Feb 19, 2014 at 6:10 PM
    #1575
    MTopp
    05 SR5 4x4
    Nice, just double checking, maybe do this when it gets warmer or could I drive around to warm up the oil a little then do the change?
  16. Feb 19, 2014 at 6:36 PM
    #1576
    TACO TX
    Kelly
    Denison ,Texas
    Where your at, you could drive around and do rear, then drive around and do T case and so on. Bbbbbuuuuurrrrrr!!!!!!
  17. Feb 19, 2014 at 6:42 PM
    #1577
    MTopp
    05 SR5 4x4
    Hahaha, yeah, I'll be lucky if it gets above 38 in the next 2 weeks
  18. Feb 23, 2014 at 7:30 AM
    #1578
    carcharias
    carcharias Giggiddy what what
    Los Angeles, CA
    SOLD: '11 AC MGM OR
    Kings all-around w/ 700lb coils, Dakar leaf pack, TC uca's, DO single hoop bumper, BAMF bolt-on sliders w/ kickouts, Rigid 20" e-series spot/flood, aFe pro-dry, BFG KM2 255/85/16, silver TRD FJ wheels, WARN M8000-s, Access LE, Grillcraft, BAMF lightbar, BAMF rear dif skid, BAMF LCA skids, window tint, Wet Okoles, WeatherTech floorliners, Silverstar lights, led dome lights, Redline Tuning hood struts, center console lock mod, mag-lite mod, extra d-rings, re-routed exhaust, ATO skids, ATO Hi-Lift mounts, pipe tailgate lock, seatbelt alarm delete, wheel/spare locks, Viper 5901, LoJack... WISHLIST: a golden canary that poops platinum
    Brianr and Chris4x4 for the win!! Extremely helpful, guys, thanks!
  19. Feb 25, 2014 at 3:38 PM
    #1579
    smtaco73
    smtaco73 Well-Known Member
    South Louisiana
    2008 and 2009 TRD Sport 4x4 DCLB
    TOYOTA FAMILY Three Tacomas and one corolla.
    Is this the correct additive that I need? It's what the dealership sold me and I just want to make sure it's the correct one. Came in a 6 oz bottle.
  20. Feb 25, 2014 at 3:49 PM
    #1580
    Menj309
    Menj309 Well-Known Member
    Richard
    SoCal 909
    13 trd sport
    CB Radio
