Changing differential fluid - A step by step "HOW TO"
Discussion in 'Technical Chat' started by brianr, Jan 21, 2009.
  1. Sep 3, 2015 at 6:47 PM
    #1861
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    You don't need any additive, as it uses the brakes to mimic an LS Diff.
    DoorDing likes this.
  2. Sep 3, 2015 at 7:05 PM
    #1862
    allur4
    allur4 Well-Known Member
    North Carolina
    How many quarts for the front diff?
  3. Sep 3, 2015 at 7:24 PM
    #1863
    allur4
    North Carolina
  4. Sep 3, 2015 at 7:35 PM
    #1864
    thewarriordinghy
    thewarriordinghy General Lee's Titan
    Ben
    Georgia
    2017 Nissan Titan 4x4
    Temporarily Stock
    subd. has me confident to do it.
  5. Sep 4, 2015 at 6:44 AM
    #1865
    xJuice
    xJuice My spoon is too Big!
    Josh
    N. Texas
    19 Tundra MGM
    TRD Front & Rear Sway Bar, TRD Pro LED Headlights, Undercover SE, Rear diff. Relocate, console organizer, debadged, color matched handles, mirror caps, and grill
    I know there's already a couple notes and one with tiny text, but could we explain the Sport LSD/ALSD/etc. diff thing a little better in the op and make it a little clearer? With like model years and such?
    @chris4x4
  6. Sep 4, 2015 at 11:37 AM
    #1866
    Dirtboyz
    Dirtboyz Well-Known Member
    Spanaway, WA
    DCSB trd sport 4x4
    Front bilstein 5100 with OME 884 w/trim pack, 17" fuel trophy wheels wrapped with 32" toyot open country m/t, bakflip fibermax tonneau cover, Avec 30" led light bar behind lower grille, marathon seat covers in max 5 camo pattern, trimmed front and rear mud flaps, more to come.
    Have a quick question guys. I know the manual calls for 75w85 for rear and for some reason it's difficult to find that in stores. I am one who doesn't use the dealer as much as possible and I asked the service guy there if if would be ok to use 75w90 in the rear. His response which I already knew the answer was no, stick was is recommended in the manual. And he goes on to tell me that Toyota only recommends changed those fluids every 30k. I go on to tell him that my manual states every 15 k for front and rear and 30k for trans case. I am at 10k now and was going to go ahead and do the change due to the long weekend and was planning on changing the front and rear with RP 75w90 so it's an easy go in grab a few quarts of the same product and be out. What do you guys think? Will putting 75w90 in the rear hurt anything? And he was crazy to tell me that 15k was to early for a change unless I do a lot of towing. I don't but I do do some minor off roading, tow a boat during duck season and live in Washington where it rains all the time. I do t think it will hurt but what do you guys think. Is the dealer just trying to get Neto buy their products and service? A quick response will be truly great full since I am on my way to the store now. Thanks.
  7. Sep 4, 2015 at 11:38 AM
    #1867
    Dirtboyz
    Spanaway, WA
    DCSB trd sport 4x4
    He also told me my manual was wrong! And he didn't like it when I told him then they gave me the wrong manual haha
  8. Sep 4, 2015 at 12:11 PM
    #1868
    Dirtboyz
    Spanaway, WA
    DCSB trd sport 4x4
    I didn't think it would be a problem and I don't need it I have a 14' so I am good there. Thanks. I hate stealerships and try to avoid them at all cost. I know there are prolly some good ones out there but they are like robots.
  9. Sep 4, 2015 at 12:14 PM
    #1869
    xJuice
    Josh
    N. Texas
    19 Tundra MGM
    Well for regular driving, it calls for 30k diff changes. Like he said 15k if you do a lot of towing or dirt driving. Occasional tow/dirt I wouldn't consider as the 15k route. If you live on dirt roads and it's an all day every day thing, or you have a trailer you haul every day for work, then that's another story.
    Edit: Definitely won't hurt to change more often, but your money and your time. Do as you wish.
  10. Sep 4, 2015 at 3:25 PM
    #1870
    thewarriordinghy
    Ben
    Georgia
    Temporarily Stock
    What is recommended viscosity? 70w90?
  11. Sep 4, 2015 at 4:19 PM
    #1871
    thewarriordinghy
    Ben
    Georgia
    Temporarily Stock
    One other question. Does an 07 trd off-road have the limited slip diff? Is there anything special since it has the locker?
  12. Sep 4, 2015 at 4:31 PM
    #1872
    thewarriordinghy
    Ben
    Georgia
    Temporarily Stock
    Which viscosity 70w90?
  13. Sep 4, 2015 at 4:35 PM
    #1873
    thewarriordinghy
    Ben
    Georgia
    Temporarily Stock
    And just fill it with 3quarts? Seems to easy. Do you have to tourque the bolt to spec, or just tight like an oil drain plug?
  14. Sep 4, 2015 at 4:46 PM
    #1874
    thewarriordinghy
    Ben
    Georgia
    Temporarily Stock
    I'll borrow my uncles. Is royal purple a good brand to use?
  15. Sep 5, 2015 at 1:47 AM
    #1875
    Dirtboyz
    Spanaway, WA
    DCSB trd sport 4x4
    Lowes has a kobalt torque wrench for 60 bucks. Life time warranty. If it breaks, gets out of specs take it back and they will replace it. Just bought mine the other day!
  16. Sep 5, 2015 at 9:13 AM
    #1876
    thewarriordinghy
    Ben
    Georgia
    Temporarily Stock
    I'll have to borrow one this time, next time I'll have enough to buy one
  17. Sep 5, 2015 at 1:43 PM
    #1877
    thewarriordinghy
    Ben
    Georgia
    Temporarily Stock
    Well all the auto stores had was 75w90. Guess that's what I'm using...
  18. Sep 5, 2015 at 2:51 PM
    #1878
    thewarriordinghy
    Ben
    Georgia
    Temporarily Stock
  19. Sep 5, 2015 at 10:04 PM
    #1879
    Dirtboyz
    Spanaway, WA
    DCSB trd sport 4x4
    Does anyone know the part numbers for the plug gaskets? I know three of them are the same and one is different. I have a 14' sport BTW. Don't think it matters. Would rather order on Amazon and get a bundle if possible and not have to go to the dealer every time I need to change the diff and trans case oil.
  20. Sep 6, 2015 at 12:11 PM
    #1880
    beavis87
    beavis87 Well-Known Member
    El Paso
    '10 Silver TRD OR
    Found on this thread: https://www.tacomaworld.com/threads...er-case-oil-change-howto.147631/#post-2933081 over in the 2nd Gen Tacomas (2005-2015) forum.
    Also, does anyone know where to buy quality replacement fill plugs for the front and rear diffs and transfer case. My TC and rear diff fill plugs are pretty rounded off and I hate hex bit bolts with a passion.
    Researching Amazon I found this: http://www.amazon.com/Genuine-Toyot...F8&qid=1438295840&sr=8-1&keywords=90430-24003
    That looks to be the standard plug gasket for everything but the oil drain plug. Also on this page: http://www.amazon.com/Genuine-Toyot...=1441591896&sr=1-4&keywords=differential+plug I found this:
