Changing Dome Light Bulb
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Rockstar Junkie, Aug 28, 2008.
  1. Aug 28, 2008 at 3:26 PM
    Rockstar Junkie
    Rockstar Junkie [OP] Well-Known Member
    Springville,UT
    06 4x4 TRD Sport
    How do you go about changing the dome light in the Tacoma's? I was wondering if one of those colored bulbs would work. I tried to get the cover off, but didnt want to break anything. Any insight would be great. Thanks!
  2. Aug 29, 2008 at 8:27 AM
    Rockstar Junkie
    Springville,UT
    06 4x4 TRD Sport
  3. Sep 8, 2008 at 10:57 AM
    Agent475
    Agent475 "Mark It Zero"
    Waldorf, MD
    2006 Red TRD Sport
    Hood Struts, 3" Tuff Country Lift, Shortie Antenna, WeatherTechs, Tinted front windows, custom TRD seat covers, custom pedals, debadged, custom USMC badging, quasi-functional hoodscoop (i.e. I cut it open), black front Yota emblem, Tailgate Theft-Prevention mod, Horn Relocation mod, Old Man Emu Carrier Bearing Drop, Brighter Backup Lights Mod, Smittybilt Reciever Hitch Tow Point, currently working on Satoshi Grill Mod
    Not sure what you are trying to do, but Pepboys has these blub sleeves that I put over the lights themselves so that I had RED lights vs. the white on both my map lights and the dome.... Looks pretty sick at night. :)
    Good Luck...
  4. Sep 8, 2008 at 11:05 AM
    05PreRunner
    05PreRunner "Living life in the FAST lane..."
    <-(714)-> SO-CAL
    TRD intake, JBA "shorty" headers, URD y-pipe
    my friend tried the bulb "sleeves" on his truck and the sleeve started smoking like crazy...:eek:
    Rockstar, you should get an LED dome light bulb... i got mine on ebay and it had 48 LED llightbulbs...it's bright as hell.
    Here's a link to the one i got:
    http://shop.ebay.com/merchant/bliss-star?_nkw=48+led&_fromfsb=0&_trksid=m270.l1313
    I got mine in Blue. It looks like he only had blue, or white as of now.
    About the cover, i took mine off using a key... i wrapped a thin towel around it so it wouldn't scratch anything... you could also use a flat screwdriver
  5. Sep 8, 2008 at 11:07 AM
    Agent475
    Waldorf, MD
    2006 Red TRD Sport
    Wow - that sucks!! I will have to watch for it... At the moment I do not have my doors open long enough for them to heat up and smoke... Either way, thanks for the heads-up!!
    Cheers,
    D.
  6. Sep 8, 2008 at 12:26 PM
    Rockstar Junkie
    Springville,UT
    06 4x4 TRD Sport
    My question is how do i get the stock one out? Can't figure how to get the cover off!
  7. Sep 8, 2008 at 12:34 PM
    Agent475
    Waldorf, MD
    2006 Red TRD Sport
    The light cover? Use a flat head screw driver and GENTLY pop it off... You will see a section on the light that should fit the tip in.
    If you mean getting the bulb out - the map lights were a pain... Gotta just carefully pull em out with your fingertips... The Dome light should pry out with a finger...
  8. Sep 8, 2008 at 12:48 PM
    neontrail
    neontrail ✈ ✈ ✈ ✈ ✈ ✈ ✈
    Idaho
    2004 NISSAN XTERRA XE/SE
    De-badged, Tint 20%, Blue 48 LED dome-light, .......
  9. Sep 8, 2008 at 1:12 PM
    Casey05Taco
    Casey05Taco Well-Known Member
    Casey
    Penngrove, CA
    05 Tacoma Prerunner
    trd seat covers, bed mat, tinted windows, debadged, mud flaps removed, tinted tails, blacked out center console, Black Rims, 6000k HID in highs and fogs, blacked out front emblem, Pioneer AVH-4300DVD, Gauge Cluster, lower valence, retrofitted, audio system, Maxtrac Spindles, Billies
    can you post some pics of these. seems like something i might be interested in
  10. Sep 8, 2008 at 1:45 PM
    Rockstar Junkie
    Springville,UT
    06 4x4 TRD Sport
    Ok, I got the cover off, and the local Checkers doesnt have the right size colored bulb. Have to stop by another place on my way home from work.
  11. Sep 8, 2008 at 1:50 PM
    05PreRunner
    <-(714)-> SO-CAL
    I'll take pictures later on tonight.
  12. Dec 16, 2009 at 1:09 AM
    MadeInMaine
    MadeInMaine MadeInMaine
    Owen
    Biloxi, MS
    2014 4Runner
    So, use a small screw driver to remove the dome light cover.... i see the little slot on the driver side.
    what about for the map lights? do i have to take the entire console off? or just the covers? how do I do that?
    thanks
  13. Dec 16, 2009 at 1:49 AM
    Kelson
    Kelson Well-Known Member
    Kelson
    Honolulu, Hawaii
    08 5-Lug Reg. Cab SR5
    SR5 Exterior/Interior (Color matched Front Bumper, Chrome Grille Surround and Chrome Rear Bumper/Silver Scoshe Dash Kit, A/C Bezel, A/C Vent Surround) LED license plate and white interior lights, Wet Okole Seat Covers, iPad in-Dash, JL CL-RLC, JL 13TW5 sub, JL 500/1 Slash V1 amp, JL XR 6.5 Components, Rockford Fosgate 6X9s in Boxes Front XRunner Coils, DJM Control Arms and Rear 4X4 Leafs, Custom 2" Angled Streetacos.com Blocks Front XR Bilstien Struts and Rear XR Bilstien Shocks, CravenSpeen Antennae, RX-8 Rims w/ Fronts:235/40-R18 Sumitomo HTR Rears:245/40-R18 Goodyear Eagle GT, 35% Tint front windows, OEM Sliding Privacy Glass w/ 5% Ceramic Tint, Flowmaster Super 44 dumped before the axle, URD Short Throw Shifter, Door Sill Protectors, Door Edge Guards, OEM Sport Pedals,The Retrofit Source Morimoto Mini D2S Stage III 35W 5K HID Headlights, OEM Fog Lights w/ piss yellow bulbs, OEM Cruise Control, Porsche 944 Bucket Seats, BeefedTaco Skid Plate, Whale
    pop the covers out with a screwdriver. the bulbs are a PITA to get out....
  14. Dec 16, 2009 at 5:00 AM
    Mark C.
    Mark C. If you want it bad, you usually get it bad!
    Mark
    Connecticut
    2010 MGM SR5 4WD AC
    LED Dome, Reed Switched LEDs in Glove Box and Center Console, Bumper Fogs, Tailgate anti-theft, LEDs over Cig lighter, Back-up camera anytime, Outside Temp add-on, Hidden GPS power, Sockmonkey 3rd Brakelight decal, 4X4 switch illumination, reed switch controlled engine compartment Flood LEDs, Elite Hitch Cover, Plasti-dipped cupholders and door switch control panels, Elite Hitch Cover.
    For the dome light, I purchased a 15-LED set that had adapter "bulbs" and an interface connector. Just remove the backing on the LEDs and stick it in place. Much brighter........I bought the plain white.
    I got them at Autozone. If I remember correctly, I paid about $15 for them.
  15. Apr 19, 2010 at 8:38 PM
    tacomarich
    tacomarich luvsoffroading
    rich
    arizona
    trd 4x4 offroad
    so what if the door dome light goes out? replace the bulb or is it a fuse?
  16. Feb 9, 2011 at 4:34 AM
    nadera17
    nadera17 Well-Known Member
    Nader
    Virginia Beach
    I4 SR5
    http://www.tacomaworld.com/forum/audio-video/101933-my-audio-deadening-project.html, Drone Mobile alarm by Compustar, ARE camper shell for the dogs
    Here are some pics on how to remove the dome light. There's more info on some of the head liner removal posts.
  17. Feb 9, 2011 at 4:43 PM
    4getful
    4getful Senior Junior Member In Training
    Dan
    Gilbert, AZ
    09 DCLB 4X4
    6" Pro-Comp Stage 2, 35x12.50x20 ProComp Xtreme All Terrain, 20" KMC Revolvers, 4.88 Gears, Banks Exhaust De-Badged
    This is where I order all of my stuff and they have been great-- Oznium.com
  18. Nov 11, 2012 at 5:28 PM
    LennyF
    LennyF New Member
    Davie FL
    06 Tacoma Extended Cab
    Replacing the dome light is explained it my owners manual, but I need to replace the “map” light bulb, also called the “personal light”.
    No mention of it in the manual. :confused:
    Any help out there?
  19. Dec 7, 2015 at 7:43 AM
    mdlester
    mdlester Member
    2003 Limited
    *** just realized this is a gen 2 thread... I have an '03
    Quick question related to this - what size screw is used to secure the dome light fixture to the ceiling? I had to replace my fixture and have lost the screw/s.
    I've done some searching online and on TW and haven't been able to find what I need. I also called my local dealer and they didn't know or have any on hand.
    Thanks in advance!
