Changing my spark plugs this weekend, couple questions
Discussion in '1st Gen. Tacomas (1995-2004)' started by Madjik_Man, Jun 20, 2012.
  1. Jun 21, 2012 at 8:08 PM
    #41
    Madjik_Man
    Madjik_Man [OP] The Rembrandt of Rattle Can
    Colorado Front Range
    This is like one of those games out of a Highlights magazine... "can you spot the difference between these two pictures."
    I have no idea what I'm looking at. I see in the top pic that black hose making a loop and coming back to the IAC (?) but I really don't see wtf I'm supposed to be seeing.
  2. Jun 21, 2012 at 10:08 PM
    #42
    scocar
    scocar hypotenoper
    In the top pic, the hose is bent forward and stressed/kinked.
    The the bottom pic, I loosened the clamp, rotated the hose back toward the intake plenum, and released the clamp. It is a molded hose and wants to be in a certain shape. You will be able to tell once you have taken it apart and see where stuff connects.
    Dood, you can do this. :wink: Feel the Taco. Be the Taco. You're the Taco be and see. You.
  3. Jun 21, 2012 at 10:11 PM
    #43
    scocar
    scocar hypotenoper
    No. You'll get a little dribble out of the two hoses you disconnect. Not even enough to top off coolant. Just clamp both coolant lines wtih vide grips/ C clamps before you take them off, and be ready to catch a little fluid in a tuna can. Or stick a rag under them.
  4. Jun 21, 2012 at 10:17 PM
    #44
    Madjik_Man
    How ironic... that's my pregame hype speech to myself just before I hook up with a chick
  5. Jun 21, 2012 at 10:34 PM
    #45
    MapleMoose
    MapleMoose Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
    It makes it more fun when you have cruise control...
  6. Jun 21, 2012 at 10:37 PM
    #46
    Madjik_Man
    Great...
    About halfway down on this guy's write up: http://www.top4runners.com/ja/cleantb.html he says, "Then, remove the throttle cable and transmission throttle-pressure (kickdown) cable ends from the linkage assembly. To do so, first rotate the linkage by hand to provide slack in the cable, then push the cable end out of the linkage mechanism. You can leave the cruise control cable in place"
    Can you see the cruise control cable in either of these pics? If so, could you point it out to me
  7. Jun 21, 2012 at 11:56 PM
    #47
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
    Thats your throttle cable. Thats what opens the butterfly valve in your throttle body
  8. Jun 21, 2012 at 11:57 PM
    #48
    scocar
    scocar hypotenoper
    I don't see it in the pics, but it comes from the left side (from this perspective, looking toward the windshield). The CC controller sits on top of the passenger side wheel wheel. Black box with a cable going to the same location as these.
    Bascically, disconnect all the shit preventing you from taking the TB off. Installation is the reverse. Everything can go back only one way.
  9. Jun 22, 2012 at 5:25 AM
    #49
    Robertgeejr1
    Robertgeejr1 Well-Known Member
    Robert
    Aorora, Ill, yeah!
    1996 Toyota Tacoma SR5 4x4
    I have done all the hi-pro mods for a life time, since I got this truck at a great price, I will be happy with showroom new.
    that's right, that is why I suggested to just take your time, and do it in steps.
    its a simple operation that will make your truck run good and last. part of the carbon buildup is from e10. keeping the engine well tuned, i like to change plugs 25,000 miles period, taking your pvc valve out and spraying it with carb cleaner will help keep the build up down.
  10. Jun 26, 2012 at 5:22 PM
    #50
    Madjik_Man
    When I take the throttle body off, I keep all the brackets (eg throttle cable bracket) and such still attached, right?
    Obviously I remove hoses and sensors that prevent its removal, but the brackets that are merely attached to the TB itself, I just leave those on, yeah?
  11. Jun 26, 2012 at 5:52 PM
    #51
    Robertgeejr1
    Robert
    Aorora, Ill, yeah!
    yes, you leave them on.
  12. Nov 19, 2012 at 6:11 PM
    #52
    Mrogers33
    Mrogers33 The way is open, the time is now
    Columbus, OH
    03 doublecab 4x4 grocery getter
    Subscribing to this so I can find it later this weekend for attempt #1 at plugs/wires/TB/MAF cleaning, keep me in your thoughts... I am the taco... eek :/
  13. Nov 19, 2012 at 6:29 PM
    #53
    Madjik_Man
    I mean this when I say it:
    If I can do it... anyone can.
  14. Nov 19, 2012 at 7:14 PM
    #54
    scocar
    scocar hypotenoper
    It's true. This was a huge leap beyond the rattle can for you, I know.
  15. Nov 19, 2012 at 7:16 PM
    #55
    Madjik_Man
  16. Nov 19, 2012 at 10:07 PM
    #56
    scocar
    scocar hypotenoper
    :laughing:
