Changing oil this weekend
Discussion in '3rd Gen. Tacomas (2016-2023)' started by forana, Oct 11, 2024.
  1. Oct 11, 2024 at 4:29 PM
    forana
    forana [OP] Well-Known Member
    Kaneohe, Hawaii
    2022 DCSB OR Lunar Rock
    No money, all went to truck...
    Hi All, I'll be changing the oil in my truck for the first time myself this weekend(Toyota care ended). I've bought the change kit, filter, oil, and fumoto valve. I've read and watched the videos. Changed oil in all my previous trucks but I know the 3rd gen is a little different.
    Anything I might have missed and should consider? Thank you!
    Williston likes this.
  2. Oct 11, 2024 at 4:32 PM
    BigTang
    BigTang Well-Known Member
    C
    2022 SR
    can of brake cleaner and a rag?
    BlackTRD4Me likes this.
  3. Oct 11, 2024 at 4:34 PM
    RichochetRabbit
    RichochetRabbit Bing Bing Bing
    Motivx wrench to remove the filter housing ... if you want to wait a short bit ... https://www.motivxtools.com
    Get the oil warm to flow freely. Be sure you get the big filter housing O-ring in the correct slot ... it is possible to have it on the housing not fall off but not seal properly.
  4. Oct 11, 2024 at 4:36 PM
    CB350G
    CB350G Trust you inner Hobbes
    Western PA
    2023 SR Access Cab 3.5V6 A/T 4x4 MGM
    WTT: hood for skewp WTT: seats for util pkg
    Rule #1 - Never change your oil on a Friday. :bananadead:
    JasonT87 and BlackTRD4Me like this.
  5. Oct 11, 2024 at 4:37 PM
    forana
    Kaneohe, Hawaii
    thank you, I do have the motive kit already. Will check the o ring well
    boston23 likes this.
  6. Oct 11, 2024 at 4:38 PM
    forana
    Kaneohe, Hawaii
    My Rule is Sunday evening. Cause if something goes wrong, you're SOL on Monday...from experience...
    mquibble, Taco22trdor and 02Duck like this.
  7. Oct 11, 2024 at 4:39 PM
    RichochetRabbit
    I mean no offense with the O-ring warning ... just install the filter housing may dislodge ring if not fully seated. Oil coat the ring a little to prevent dislodging.
  8. Oct 11, 2024 at 4:39 PM
    Koolbreeze7
    Koolbreeze7 GRILL MAN
    Jon
    Jersey
    2017 TRD Sport 4x4 DCLB Black, Trail Limo. RIP- 2009, 2000, 91,89,87 trucks
    Rigid pod fogs, SpartanX stealth grill and hood LED's, 17" SEMA's on 275/70/17 Falken Wildpeak AT3W's, Fox 2.0 on all corners , TRD CAI, LEER 100XQ Blacked out, w/ Thule racks, and Cargo slider Flow master American Thunder "dual" exhaust, remote start, tint, TRD Pro grill and TRD shadow graphics, Alcan custom 8 leaf Spring Pack
    4 Hail Mary's, a rabbits foot and 911 on speed dial....
    Taco_mike73 and boston23 like this.
  9. Oct 11, 2024 at 4:41 PM
    RichochetRabbit
    The wife needs to be ready with 911, yes ...
    RIX TUX likes this.
  10. Oct 11, 2024 at 4:43 PM
    Koolbreeze7
    Jon
    Jersey
    was just mulling going outside and changing mine tonight in the dark and I have a pelfreybilt skid that I need to remove each time...
  11. Oct 11, 2024 at 4:45 PM
    GawainXR
    GawainXR Well-Known Member
    William
    2020 TRD Off-Road
    DashCam
    Why the fumoto valve? I'd just get the motivx assembly, and a ratcheting wrench for it.
  12. Oct 11, 2024 at 4:45 PM
    canuck guy
    canuck guy Well-Known Member
    Alberta
    23TRDOR
    You seem to have it all covered. O ring placement is good advice.
    Make sure old oil pan drain plug gasket is not stuck to pan.
    Basically the only thing different than other vehicle oil changes is that the filter is in a housing rather than a 1 piece unit.
    You probably know that though.
    Enjoy the process.
    I actually find changing oil and doing maintenance therapeutic.
  13. Oct 11, 2024 at 4:48 PM
    RichochetRabbit
    The valve opens with a lever to control outflow. Attach a tube to direct oil flow exactly where you want, maybe. Allows taking small samples or drain excess oil if needed. Replaces the standard bolt-plug.
    https://www.fumotousa.com/cars-pickups-toyota-2022-tacoma-3-5l-v6
    mquibble likes this.
  14. Oct 11, 2024 at 4:58 PM
    CB350G
    Western PA
    ^ This ^
    Getting the o-ring in the proper position is probably the biggest difference from other oil changes/oil filters. After the housing starts threading on, the o-ring -really- gets squeezed. ( So make sure the o-ring stays in the slot. ) Once the o-ring is in, the resistance goes way up. Keep turning until you feel the housing seat, metal-to-metal. At this point - you can either snug it ‘by feel’ (using your years of experience) or torque it by the book.
    Either way, I don’t think the filter housing would ever come off on its own, with how tight the o-ring is getting squeezed. And you definitely don’t need to crank down on it like a traditional oil filter that seals on the face.
    IMHO YMMV TGIF :cheers:
  15. Oct 11, 2024 at 5:02 PM
    forana
    Kaneohe, Hawaii
    This is good to know. I was not aware the o ring was different.
  16. Oct 11, 2024 at 5:10 PM
    Williston
    Williston Well-Known Member
    New England
    2014 Tacoma 040 SR5 4x4 DC SB V6 AT5 Tow Pkg Entune+ Mostly stock with a few OEM mods.
    Stock (99.999%) OEM Bed Floor Mat, Front Bed Rail Cargo Net and hooks, Auto-Dim mirror w/Compass and outside Temperature display, TRD Pro Grille, Uni-Filter air pump modification, WeatherTech floor liners f/r. (winter) OEM All-Weather floor mats (summer).
    Drain pan/container. Don't get the cheap one: you'll have it for a long time and you don't want one that can't hold at least 6 qts and leaks through the vent, drain cap or the center disc when it's time to take it to recycle the oil
    Shop Rags.
    RocTaco likes this.
  17. Oct 11, 2024 at 5:12 PM
    CB350G
    Western PA
    Traditional oil filters seal on the face. Loosen just a little and they can leak or dump all your oil.
    The Toyota filter housing is a cylinder seal. The entire housing would have to unscrew all the way out before it started to leak. I think you’ll see that that is not too likely. Still need to tighten the center drain plug properly.
  18. Oct 11, 2024 at 5:17 PM
    Phlogiston
    Phlogiston There are no victims, only volunteers.
    A@!#$@$%#$%
    The wild west
    2016 SR5 DCSB
    Definitely heed all warnings in regards to the O ring.
    Last weekend we did some cooking with Ghost peppers, by Monday afternoon i about blew my O ring out, so take it serious!
    Kolohe07 likes this.
  19. Oct 11, 2024 at 5:47 PM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    Make sure you are removing the engine drain plug not the automatic transmission plug.
    It happens sometimes on the first service -- most folks don't do it twice however. ;)
    OZ TRD, dryheat, RIX TUX and 2 others like this.
  20. Oct 11, 2024 at 6:03 PM
    RocTaco
    RocTaco Free stun!
    Pete
    Green Mtns
    21' SR5 Trail AG
    To add to this, the oil is going to come out fast as fuck and splash everywhere if you aren't careful.
    Only have to deal with that once tho if you are adding a drain valve.
