Changing spark plugs on my 2008 for the first time, help.
Discussion in '4 Cylinder' started by vln, Jul 31, 2012.
  1. Jul 31, 2012 at 2:27 PM
    vln
    vln [OP] New Member
    Regular Cab
    Hey guys! I've been a lurker here for a while, but I am in need of some help.
    My taco just passed 60,000 miles, and I thought it would be a good time to change the plugs.
    http://www.amazon.com/Bosch-9613-Iridium-Fine-Spark/dp/B00515NJB6/ref=au_pf_ss_4?ie=UTF8&Make=Toyota|76&Model=Tacoma|1037&Year=2008|2008&carId=001&n=15684181&s=automotive
    Are those ok? Or should I just call toyota and order the stock ones? I have had good experience with bosch in the past.
    Also, what is a good anti-seize to use? Anybody have a recommendation? And just to be clear, on a 2008 2.7, I torque the plugs to 15 ft lbs, correct?
    Thanks.
  2. Jul 31, 2012 at 2:34 PM
    dudewheresmytaco
    dudewheresmytaco Member
    North Texas
    06 PreRunner Doublecab TRD Offroad
    06 PreRunner Doublecab TRD Offroad, 3" toytec lift, 16" MotoMetal Wheels, Nitto Terra Grappler Tires - 285 75 16
  3. Jul 31, 2012 at 2:59 PM
    Hard
    Hard Well-Known Member
    H
    4X4X4
    That is REALLY helpful for the OP with a 2tr......ok honest mistake.
    OP I would stick to Denso or NGK. OEM uses them for a reason. You dont have to get the Denso iridiums at the dealer, lots of souces.
    Toyota says no anti-seize FWIW.
    http://www.tacomaworld.com/forum/4-cylinder/157316-how-change-sparkplugs-2tr-fe.html
  4. Jul 31, 2012 at 3:01 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I thought the 4 Banger used iridium plugs and didn't need to be changed until 100k :notsure:
  5. Jul 31, 2012 at 3:55 PM
    vln
    vln [OP] New Member
    Regular Cab
    Thanks so far guys, is it really that bad to use anti-seize?
    So I'm guessing 15 ft lbs is the right torque for the plugs?
  6. Jul 31, 2012 at 4:09 PM
    mick478
    mick478 He is The STig
    Bott
    Stockton, CACA
    2011 White TRD Sport, 4x4 doublemint cab
    Ome 885 coils Ome n9000 front shocks Ome n182 rear shocks K&n drop in filter Duratracs Kenwood kac 90210d Kicker 12" Alpine 800 watt 4 channel Pioneer 430w 6x9 Firestone ride rite air springs
    X2
  7. Jul 31, 2012 at 4:10 PM
    mick478
    Bott
    Stockton, CACA
    HAHAHAHA i laugh.
  8. Jul 31, 2012 at 4:15 PM
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    I'll have to look, but you need it on certain plugs... depends on what the plug is made of. I found the info last year when I was getting ready to change mine.
  9. Jul 31, 2012 at 5:57 PM
    vln
    vln [OP] New Member
    Regular Cab
    Ok, just found out I don't know where my torque wrench is, how tight should the plugs be if I just use a ratchet? 1/2 turn after hand tight? :confused:
  10. Aug 1, 2012 at 4:55 AM
    Ga tacoguy
    Ga tacoguy Well-Known Member
    Rudy
    Augusta Ga.
    Extended cab Base model 4 cyl
    Tailgate mod, horn mod,storage door mod
    :) I think that a 1/2 turn may be too much torque on the spark plugs. I would just tighten them 1/4 turn after being snug to set the torque.
    I would use the anti seize on the plugs, but I believe that Toyota is afraid that anti seize and torque would pull out threads on the head. You just need to use your own judgement on this.
    I would use some di-electric grease on the spark plug top and on the wire's female connector. It will waterproof the connector and the plug.
    Good Luck.
  11. Aug 1, 2012 at 11:38 AM
    azreb
    azreb Geezer
    TN
    '20 SR5 crew cab; gray
    camper shell, front camera, floor mats, cheap bed mat, dash camera, catalytic converter cover, fumoto
    For antiseize I just rub a pencil lead over the threads. Seems to work fine.
  12. Aug 1, 2012 at 11:46 AM
    Pugga
    Massachusetts
    That's all it really is anyways, just graphite with some other crap mixed in. Graphite works very well though.
  13. Aug 25, 2012 at 1:54 PM
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    New 1 on me. Tx.
