Changing the spark plugs
Discussion in '1st Gen. Tacomas (1995-2004)' started by 707tothe907, Dec 7, 2010.
  1. Dec 7, 2010 at 12:21 PM
    707tothe907
    707tothe907 [OP] Superior Member
    Jake
    Chico NorCal
    05 DCSB Off Road
    1st gen. I've searched but haven't found anything. Any guides or write ups on how to change the sparks on a 1st gen? Any links would be helpful thanks.
  2. Dec 7, 2010 at 12:36 PM
    vantaco
    vantaco Well-Known Member
    02 Taco Xtracab TRD Step Side
    what's the lifetime on these plugs?
  3. Dec 7, 2010 at 12:42 PM
    jjsask
    jjsask Well-Known Member
    Regina, Saskatchewan, Canada
    2002 XtraCab 4x4 TRD
    If you are talking about the V6 its super easy to change the plugs. On the driver's side head just pull the wires and change the plugs. Passenger side you remove the air intake hose and unbolt the 3 coils, pull them out, change the plugs and reassemble keeping the coils in the same position as before. Use a light coating of anti-seize on the plug threads only and do not over tighten.
    Plugs are Denso K16TR11 Dual Ground Copper Plugs. $2.75 Canadian each at the Dealer
    Plug life is 30,000 Kms
  4. Dec 7, 2010 at 12:43 PM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    Put a little Anti-seize on the threads, and some dielectric grease in the spark plug boots.
  5. Dec 7, 2010 at 12:46 PM
    Max-4_Yota
    Max-4_Yota The Welfare Cadilac
    Michael
    South Carolina
    3rd gen Tacoma
    Chicken lights, chrome and smoke tunes.
    factory plugs are $3.13 here
  6. Jan 9, 2011 at 6:43 PM
    Mike R.
    Mike R. New Member
    Simpsonville, SC
    Denso Iridium Long-Life SK20R11 spark plugs
  7. Jan 9, 2011 at 9:40 PM
    Flash1034
    Flash1034 Well-Known Member
    N/W Montana
    2023 Toyota Tacoma TRD Pro, Solar Octane, Automatic
    MESO Stage 1.5 LED Taillights Falken Wildpeak AT3W Tires in 265/75-16
    Is the copper anti-sieze ok to use?
    Thanks,
    Flash
  8. Jan 18, 2011 at 4:05 PM
    SlimDigg
    SlimDigg We Back!!
    Calgary, AB
    Coming Soon....
    So should I be using 6 densos or 3 densos 3 ngk in my 2001?
  9. Jan 18, 2011 at 7:02 PM
    crazyasu45
    crazyasu45 Well-Known Member
    Canada
    2013 MGM DCLB 4X4 TRD SPORT
    3" SUSPENSION LIFT
    6 Densos is just fine...
  10. Jan 18, 2011 at 8:27 PM
    crazyasu45
    Canada
    3" SUSPENSION LIFT
  11. Jan 19, 2011 at 9:09 AM
    twfsa
    twfsa Well-Known Member
    Tom
    Omaha Ne
    04 TRD 4X4
    881 Front coils, Bilstien 5100's all the way front set to "0" Icon Dynamic's mini leafs in rear, stock tires.
  12. Feb 12, 2011 at 9:26 AM
    747 function > form
    1st Gen.
    ^ agreed.
    ^ again, agreed. twfsa, you're one of the sharper tools in the shed.:thumbsup:
