Changing the tailgate lock cylinder
Discussion in '3rd Gen. Tacomas (2016+)' started by foxtrapper, Oct 16, 2018.
  1. Oct 16, 2018 at 10:58 AM
    foxtrapper
    foxtrapper [OP] Well-Known Member
    Not real happy about using the key imbedded in the key fob. It was pouring rain ,key and me soaked ,and was not happy shoving the wet key back into the expensive fob. Think it’s worth having the cylinder changed to a “ normal “ key?
  2. Oct 16, 2018 at 11:28 AM
    beergeek
    beergeek Well-Known Member
    RI
    2017 Black Tacoma Limited
  3. Oct 16, 2018 at 11:38 AM
    foxtrapper
  4. Oct 16, 2018 at 11:45 AM
    beergeek
    RI
    Paying someone to install the Pop & Lock would be a much better solution than paying someone to replace the lock cylinder.
    Or, you could probably get a conventional key cut to fit the existing cylinder.
  5. Oct 16, 2018 at 11:45 AM
    dilbert
    dilbert Well-Known Member
    PNW
    2019 DCLB TRD Off-Road
    Pop & Lock is probably the most convenient choice long term.
    Couldn't you just have a normal key cut to use as your tailgate key? I'm sure the dealer or a locksmith could cut that type of key.
    beergeek likes this.
  6. Oct 16, 2018 at 11:55 AM
    ST77
    ST77 Wandering doesn't mean you're lost
    Brian
    Sandy, Or
    2018 TRD OR DCSB
    Bone Stock
    My 2018 came with a conventional key, I’m heading towards the pop n lock solution.
    Boyitz likes this.
  7. Oct 17, 2018 at 2:26 PM
    foxtrapper
    Locksmith wanted $45 to make a key , only option was with the same “top” as the fob key. Passed
  8. Oct 17, 2018 at 4:07 PM
    Dacon
    Dacon 2017 Tacoma TRD PRO Quikrete
    Danny
    Gilbert, Arizona.
    2017 TRD PRO DCSB. DOP 02.20.2017
    TRD PRO Cement 2017 TRD CAI and AFE Magnum Flow Dry Air Filter Camburg KINETIK Series Billet UCA Icon LCA skid plates Icon Coilover extended travel shocks with 700# springs Icon 2" rear shocks Icon RXT leaf springs full pack (new rims and tires soon)
    I got 2 fobs (with a key inside) and also a normal key to open the driver door, glove compartment and tail gate lock.
    I thought it was normal.
